22-2228947-PDA-optimized
Model(s): Roxtec SPM Seal Series – SPM 39- 279 Roxtec SPM Blind Seal Series (Steel Divisions)
Product Design Assessment (PDA) 22-2228947-PDA 25-MAY-2022 24-MAY-2027
Single pipe penetration in Class A-0, A15, A30 and A60 bulkheads and decks for Marine and Offshore
Applications. Penetration of watertight and gas-tight steel bulkheads and decks up to rated pressure.
Roxtec Sealing System, Roxtec SPM seal series consisting of halogen free rubber seal in sizes 39-279
attach through expansion to steel sections.
Roxtec SPM Blind seal series consisting of halogen free rubber seal in sizes 39/0 to 92/0 attached
Roxtec SPM seal series 39 to 279 / Roxtec SPM Blind seal series 39/0 to 92/0
Fire Resistance - bulkheads and decks A0, A15, A30, and A60 Bulkheads and Decks,
Water tightness test pressure: 1.5 bar g.
Gas tightness test pressure: 1.0 bar g.
a) Outside diameter 8 to 220mm for steel pipes for bulkheads and decks.
b) Outside diameter 8 to 220mm for copper pipes for bulkheads.
c) Outside diameter 8 to 222mm for copper pipes for decks.
02/12/2024 9:24:21 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 1 of 3
Certificate Number: 22-2228947-PDA
e) Transits are to be insulated as per the approved ABS drawing for all fire division ratings.
f) Unit Certification is not required for this product. If the manufacturer or purchaser’s request an ABS
a) All seal types should be installed in accordance with the manufacturer’s instructions in accordance
with ABS approved installation drawings.
b) Insulation material is to be A60 approved type and properly installed in accordance with ABS
approved drawings to the satisfaction of the Surveyors
c) Watertight bulkheads or decks are to be tested as per ABS Marine Vessel Rules 3-7-1/Table 1.
penetration system has to comply with the requirements given in SOLAS Ch. II-1 Reg. 13.2.3 (2020
Consolidated Edition or latest issue).
e) This approval of penetrations passing through watertight bulkhead is not to be construed as a
substitute for flag Administration’s approval for the purpose of SOLAS 2020 Consolidated Edition.
f) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
Drawing No. S1502970, SPM 41-279 Assembly, Revision: F
Drawing No. S1524712, SPM BLIND SEAL SPECIAL SPM 39-92/0, Revision: C
Drawing No. S15766842, SPM Blind Seal A-0 Steel Deck/Blkhd, Revision: A
Drawing No. S1576841, SPM Blind Seal A-60 Steel Deck/Blkhd, Revision: A
Drawing No. S1576843, SPM seal W steel pipe A-0 Steel Deck/Blkhd, Revision: A
Document DOC-0000116, Installation Instructions Roxtec SPM Seal, Version E
This Product Design Assessment (PDA) Certificate remains valid until 24/May/2027 or until the Rules
2022 Rules for Conditions of Classification, Part 1 - Marine Vessel Rules 1-1-4/7.7, 1-1-A3, 1-1-A4,
which covers the following:
2022 Rules for Building and Classing Marine Vessel Rules: 4-6-2/9.7.
2022 Rules for Conditions of Classification, Part 1 - Offshore Units and Structures 1-1-4/9.7, 1-1-A2,
1-1-A3, which covers the following:
02/12/2024 9:24:21 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 2 of 3
2022 Rules for Building and Classing Mobile Offshore Units: 4-2-1/11.15.
2022 Rules for Building and Classing Facilities on Offshore Installations: 3-8/9.13, 4-8/9.13.
Regulation II-2/ 9.3.1 of SOLAS (2020 Consolidated Edition);
This PDA conforms to Transport of Canada requirements
Print Date and Time: 12-Feb-2024 9:24
02/12/2024 9:24:21 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 3 of 3
