23-2456071-PDA-optimized
Model(s): Roxtec RS PPS and RS PPS/S Seals in Aluminium Divisions
Product Design Assessment (PDA) 23-2456071-PDA 20-NOV-2023 19-NOV-2028
Single plastic pipe penetrations in Class A0, A15, A30 and A60 aluminium bulkheads and decks for
marine and offshore applications. Penetrations of watertight and gastight aluminium bulkheads and
decks up to the specified pressure.
RS PPS - Consisting of an extended aluminium sleeve bolted or welded to an aluminium section. The
sleeve is fitted at both ends with Roxtec RS seals (standard or EMC versions) including inserted
intumescent material in between.
RS PPS/S - Consisting of an aluminium sleeve, bolted, welded or SLX-type sleeve attached through
expansion, on to the steel sections. The sleeve is fitted with one single RS PPS/S seal with integrated
intumescent material. Minimum thickness for aluminium sleeve is 1.5 mm.
RS PPS
RS PPS/S
02/13/2024 1:20:57 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 1 of 5
Certificate Number: 23-2456071-PDA
Gastight test pressure 3 bar (except bolted versions test pressure at 2.5 bar)
a) Maximum and Minimum tested RS PPS:
- PVC: 16 mm to 160mm outside diameter.
- PE Pipe: 16 mm to 355mm outside diameter.
- PE/ALU/PE flexible pipe: 16 mm to 110mm outside diameter.
- Coolfit 4.0 Pipe: 90 mm to 315mm outside diameter.
b) Maximum and Minimum tested RS PPS/S:
- PE Pipe: 16 mm to 110mm outside diameter.
- PE/ALU/PE flexible pipe: 16 mm to 63mm outside diameter.
- Coolfit 2.0 Pipe: 75 mm to 110mm outside diameter.
c) Maximum / Minimum Size of Transit Frame tested :
- RS PPS 200 / RS PPS 31 for PVC pipes
  • RS PPS 450 / RS PPS 31 & RS PPS/S 150 / RS PPS/S 31 for PE pipes.
  • RS PPS 150 / RS PPS 31 & RS PPS/S 100 / RS PPS/S 31 for PE/ ALU/ PE flexible pipes.
- RS PPS 400 / RS PPS 125 for Coolfit 4.0 Pipe
- RS PPS/S 150 / RS PPS/S 125 for Coolfit 2.0 Pipe
d) For frame arrangements larger than those tested, special approval is to be requested.
e) Not for use in tank boundaries.
f) For fire class A-0, A-15 and A-30, sleeves are to be insulated as for class A-60 and in addition the
division is to be insulated at least 200 mm around the penetration.
g) Unit Certification is not required for this product. If the manufacturer or purchaser’s request an ABS
a) All seal type should be installed in accordance with the manufacturers instructions and ABS approved
installation drawings.
b) Insulation material is to be A60 approved type and properly installed in accordance with ABS
approved drawings to the satisfaction of the Surveyors.
c) Watertight bulkheads or decks are to be tested as per ABS Marine Vessel Rules 3-7-1/Table 1.
penetration system has to comply with the requirements given in SOLAS Ch. 11-1 Reg. 13.2.3 (2020
Consolidated Edition).
e This approval of penetrations passing through watertight bulkhead is not to be construed as a
substitute for flag Administration’s approval for the purpose of SOLAS 74/78 (2020 Consolidated
02/13/2024 1:20:57 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 2 of 5
Edition).
f) The product or packing is to be marked with name of manufacturer, type designation and fire rating.
g) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
Installation instructions, RS PPS
Installation instructions, RS PPS/S
Test Matrix, RS PPS
Test Matrix, RS PPS/S
CTO, Fire test report, RS-22/B-246/E, dated 02 January 2023
CTO, Fire test report, RS-20/B-408/E, dated 02 January 2023
DBI, Fire test report, PGB10016A, dated 27 February 2023
DBI, Fire test report, PGB10076A, dated 04 January 2023
DBI, Fire test report, PGB10031A, dated 27 February 2023
DBI, Fire test report, PGA11371A, dated 20 February 2019
CTO, Fire test report, RS-19/B-224/E, dated 01 August 2019
CTO, Fire test report, RS-20/B-082/E, dated 21 April 2019
CTO, Fire test report, RS-19/B-020/E, dated 27 May 2019
DBI, Fire test report, PGA11370A, dated 20 February 2019
ROXTEC, Tightness report, SKM-04-4088, dated 16 June 2004
ROXTEC, Tightness report, N141ZEM1, dated 15 May 2020
ROXTEC, Tightness report, MLM070656, dated 18 April 2007
ROXTEC, Tightness report, N141ZEM2, dated 15 May 2010
ROXTEC, Tightness report, MLM020408-23, dated 03 June 2002
Certificate drawing, S1595597, RS PPS with A60 Aluminium Deck
Certificate drawing, S1595650, RS PPS/S with A60 Aluminium Deck & Bulkhead
Certificate drawing, S1595633, RS PPS with A60 Aluminium Bulkhead
DBI, Fire test report, PGA10802A, PGA 10801A both dated 29 August 2016
ROXTEC, Tightness report, MLM 010247, dated 29 September 2001
This Product Design Assessment (PDA) Certificate remains valid until 19/Nov/2028 or until the Rules
02/13/2024 1:20:57 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 3 of 5
ABS Rules for Marine Vessel (2023) 1-1-4/7.7, 1-1-A3, 1-1-A4, 4-6-3/7.11
ABS Rules for Mobile Offshore Units (2023) 1-1-4/9.7, 1-1-A2, 1-1-A3, 4-2-2/7.7.4
Regulation II-2/ 9.3.1 of SOLAS (2020 Consolidated Edition)
A8706-1 RDIMS#1961446 dated 15 November 2006
Print Date and Time: 13-Feb-2024 1:20
02/13/2024 1:20:57 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 4 of 5
02/13/2024 1:20:57 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 5 of 5
