24-2397982-PDA-optimized
Model(s): Roxtec S Series Frames for steel divisions for Marine and Offshore Applications.
Product Design Assessment (PDA) 24-2397982-PDA 02-FEB-2024 01-FEB-2029
Approved for use as empty, single or multiple cable penetration system in class A-0, A-15, A-30 and
A-60 steel bulkheads and decks for approved ship cables, inc. continuously welded aluminium clad
cables (e.g. CLX type) and fiber optic conduits and cables, within type and size limitations indicated in
the attached tables. Penetrations of watertight and gastight bulkheads and decks up to the specified
pressure indicated in the rating section.
Roxtec sealing system with multidiameter™ technology, S-series consists of Roxtec S-series frames
with a depth of 60 mm (S, S Ex, SF, SFHM, SO, SFO, SFOH, SR/T, SR/S, SRC r20, SRC r40, SRC r60)
in height 1-8 and width 60-120, and combinations as indicated in the attached tables. welded or bolted to
the steel sections. Also included in the S-series is the subgroup of SK-series frames with a single barrier
with a depth of more than 60 mm (SK, SK Ex, SFK, SFOK, SFOHK, SRCK r20, SRCK r40, SRCK r60)
and a subgroup SBTB-series frames with two barriers (SBTB, SBTB Ex, SFBTB, SRBTB, SRCBTB r20,
SRCBTB r40, SRCBTB r60).
The S-series (including subgroups) is filled with Roxtec halogen free RM modules (Notes 1,2) .
Assembled with Roxtec Wedge, Roxtec ES Wedge, Roxtec Ex Wedge and corresponding stay plates.
1 Standard RM, RM Ex, RM FOC, RM ES, RM ESB, RM PE, RM PE B, RM BG, RM BG B, RM ES BG,
RM ES BGB
2 RMX, RX BG, RX BG B.
02/09/2024 2:48:12 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 1 of 6
Certificate Number: 24-2397982-PDA
For penetrations incorporating FOC-modules, watertight test pressure is 3 bar and gastight test pressure
is 1 bar.
For penetrations incorporating RMX modules, watertight test pressure is 3 bar and gastight test pressure
is 1.5 bar
See the attached tables for detailed ratings.
a) Maximum tested frame sizes for S-Series Frames with RM Modules. :
1) Single - 8x1 ( One frame of size 8)
2) Multiple Frames - see Below
2.1) For bulkheads/ decks up to A60 rating, two frames of size 8 arranged vertically and ten arranged
horizontally, designated S 8+8x10., Maximum Cable size 90 mm ( Marine) and 18 mm ( Fiber Optic)
2.2) For bulkheads up to A60 rating, two frames of size 8 arranged vertically and three arranged
horizontally, designated S 8+8x3., Maximum CLX Cable size 98 mm
2.3) For decks up to A60 rating, two frames of size 8 arranged vertically and two arranged vertically,
designated S 8+8x2., Maximum CLX Cable size 98 mm
2.4)For bulkheads A-0 rating with out insulation , two frames of size 8 arranged vertically and five
arranged horizontally, designated S 8+8x5., Maximum Cable size 86 mm ( Marine) and 18 mm ( Fiber
Optic)
2.5) For decks A-0 rating with out insulation , two frames of size 8 arranged vertically and three arranged
horizontally, designated S 8+8x3., Maximum Cable size 88 mm ( Marine) and 18 mm ( Fiber Optic)
b) Minimum Tested Frame Size 1x1 ( size 1 Frame)
c) See attached tables for all tested combinations and cable sizes for all frame types. Other applications
are subject to case-by-case approval.
d) Not for use in tank boundaries
e) For detail information about insulation arrangement, please see ABS approved drawings specified in
the Notes, Drawings and Documentation section of this Certificate..
f) Unit Certification is not required for this product. If the manufacturer or purchaser request an ABS
a) All seal types should be installed with the manufacturer’s instructions in accordance with ABS
approved drawings.
b) Watertight or fire rated bulkheads or decks for cable penetrations are to be examined and tested as
c)This approval of penetrations passing through watertight bulkhead is not to be construed as a
substitute for flag Administration’s approval for the purpose of SOLAS (2020 consolidated edition).
d)When requested to be used in watertight bulkheads or decks on passenger ships or special purpose
ships, the penetration system has to comply with the requirements given in SOLAS (Consolidated
Edition 2020), Ch. II-1 Reg.
02/09/2024 2:48:12 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 2 of 6
13.2.3.
f) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
1) Test Reports
1.1) SP Technical Research Institute of Sweden
• PX05454 A-60, Insulated Steel Bulkhead, dated 8th September 2011
• 4P07023 A-60 Steel deck SP report dated 4th February 2015
• 4P08662 A-60 Steel bulkhead SP report dated 8th June 2015
• 4P04959, IMO test of cable penetration seals in A60 Steel Bulkheads, dated 24 March 2015
• 6P07563, IMO test of cable penetration seals in A60 Steel Deck, Dated 20 Dec 2016
• 6P02249, IMO test of cable penetration seals in A60 Steel Deck, Dated 17 August 2016
• 6P02516, IMO test of cable penetration seals in A60 Bulkhead, Dated 29 August 2016
• 6P10022 A-60 Steel deck SP report dated 7th October 2017
• 8P04039 A-60 Steel bulkhead SP report dated 6th August 2018
• 8P04040 A-60 Steel deck SP report dated 13th August 2018
1.2) Danish Institute of Fire and Security Technology.
• PGA10024, Penetrations through “A” Class Bulkhead, dated 21st December 2011
• PGA10025, Penetrations through “A” Class Deckhead, dated 22nd December 2011
  • PGA10453 A-60 Steel bulkhead DBI report dated 28th May 2014
• PGA10651, Cable Transits a steel deck, dated 3rd July 2015
• PGA10652, Cable Transits in a steel bulkhead, dated 3rd July 2015
• PGA10723A, Cable Transits and Pipe Penetration in class A-0 Steel Deck, dated 4 February 2016
• PGA10871Arev1, Cable Transits and Pipe Penetration in class A-60 Steel Deck, dated 09 Dec 2016
• PGA11301A A-0 Steel bulkhead DBI report dated 22nd November 2018
• PGA11302A A-0 Steel deck DBI report dated 16th January 2019
• PGB10116A A-60 Steel deck DBI report dated 2nd August 2021
• PGB10117A A-60 Steel bulkhead DBI report dated 2nd August 2021
• PGB10119A A-0 Steel deck DBI report dated 15th November 2021
02/09/2024 2:48:12 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 3 of 6
• PGB10172A A-60 Steel deck DBI report dated 17th June 2022
• PGB10176A A-60 Steel bulkhead DBI report dated 4th November 2022
• PGB10177A A-60 Steel deck DBI report dated 4th November 2022
1.3) Japan Ship Machinery Quality Control Association – Research Institute of Marine engineering – Test
Report 09-344(E), dated 11th December 2009
1.4) Centrum Techniki Okrtowej S.A. - Maritime Advanced Research Centre:
• RS-17/B-176/E A-0 Steel bulkhead CTO report dated 5th May 2015
• RS-17/B-177/E A-0 Steel deck CTO report dated 26th May 2017
• RS-18/B-293/E A-0 Steel bulkhead CTO report dated 13th September 2018
• RS-18/B-484/E A-60 Steel deck CTO report dated 10th December 2018
• RS-19/B-355/E A-60 Steel bulkhead CTO report dated 16th October 2019
• RS-19/B-356/E A-60 Steel deck CTO report dated 18th October 2019
• RS-20/B-409/E A-60 Steel bulkhead CTO report dated 21st December 2020
• RS-22/B-337/E A-60 Steel deck CTO report dated 28th October 2022
• RS-22/B-394/E A-60 Steel bulkhead CTO report dated 28th November 2022
• RS-22/B-425/E A-60 Steel bulkhead CTO report dated 2nd January 2023
• RS-22/B-427/E A-60 Steel bulkhead CTO report dated 2nd January 2023
1.5) Watertightness and Gas Tightness Test Reports:
• MLM 020133 dated 26 Feb 2002
• SKM-04-4088 dated 16 June 2004
• N141805F Tightness report dated 27th February 2018
• N142G5DA Tightness report dated 14th November 2022
2) Drawings
Drawing No. S1589708, Revision: A, A-60 Class Steel Bulkhead & Deck – S Series
Drawing No. S1589709, Revision: A, A-60 Class Steel Bulkhead & Deck – S Ex Series
Drawing No. S1589710, Revision: A, A-60 Class Steel Bulkhead & Deck – SK Series
Drawing No. S1589711, Revision: A, A-60 Class Steel Bulkhead & Deck- SBTB Series
Drawing No. S1589712, Revision: A, A-0 Class Steel Bulkhead & Deck- S Series
Drawing No. S1589713, Revision: A, A-0 Class Steel Bulkhead & Deck- S Ex Series
02/09/2024 2:48:12 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 4 of 6
Drawing No. S1589714, Revision: A, A-0 Class Steel Bulkhead & Deck- SK Series
Drawing No. S1589715, Revision: A, A-0 Class Steel Bulkhead & Deck- SBTB Series
Drawing No. S1589727, Revision: A, A-60 Class Steel Bulkhead & Deck – S Series with CLX Cables
Drawing No. S1589728, Revision: A, A-0 Class Steel Bulkhead & Deck- S Series with CLX Cables
Drawing No. S1589729, Revision: A, A-60 Class Steel Bulkhead & Deck – SK Series with CLX Cables
Drawing No. S1589730, Revision: A, A-60 Class Steel Bulkhead & Deck- SBTB Series with CLX Cables
Drawing No. S1589735, Revision: A, A-0 Class Steel Bulkhead & Deck- SK Series with CLX Cables
Drawing No. S159046, Revision: A, A-0 Class Steel Bulkhead & Deck- SK Series with CLX Cables
This Product Design Assessment (PDA) Certificate remains valid until 01/Feb/2029 or until the Rules
2024 ABS Rules for Building and Classing Marine Vessels 1-1-4/7.7, 1-1-A3, 1-1-A4, 4-8-4/21.13,
4-8-4/29.15
2024 ABS Rules for Building and Classing Facilities on Offshore Installations 1-1-4/9.7, 1-1-A2, 1-1-A3,
3-8/9.13, 4-8/9.13
2024 ABS Rules for Building and Classing Mobile Offshore Units 1-1-4/9.7, 1-1-A2, 1-1-A3, 4-3-3/5.13
Regulation II-2/ 9.3.1 of SOLAS (2020 Consolidated Edition);
IMO Resolution MSC.307(88) - (2010 FTP Code), Annex I: Part 3, adopted 3 December 2010
This PDA conforms to Transport Canada Requirements
02/09/2024 2:48:12 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 5 of 6
Print Date and Time: 09-Feb-2024 2:48
02/09/2024 2:48:12 AM Copyright 2019 American Bureau of Shipping. All rights reserved. Page 6 of 6
PDA Number : 24-2397982-PDA
Issue Date: 02 Feb 2024
Expiry Date:01 Feb 2029
Revision: 0
Table 1: approved cable penetration in A-60 Bulkhead
Max. cable
Frame Frame
Cable diameter
Frame type Size
type (OD)
[mm] [mm]
[mm]
S1589708
1-8x1 Marine
No.1
S1589708
1-8+8x3 Marine
No.2
S1589708
1-8+8x10 Marine
no 3
Symmetric,
S1589708
S-series 1-8+8x10
No.4
frames side
with RM S1589708
modules1 1-8+8x10
No.5
S1589727
1-8+8x3 CLX
No.1
Fiber Any,
1-8+8x10 18
optic3 Symmetric
Symmetric,
Fiber S1589708
1-8+8x10 18
optic3 No.4
side
S-series
frames S1589709
1-6+6x3 Marine
with RM No.1-2
modules2
Insulated S1589710
2-8x1 Marine
side No.1
| SK-series | Insulated | S1589710 |
| 2-8+8x5 | Marine | 90 | 100-400 | 10 |
| frames | side | No.2 |
| with RM | Fiber | Insulated | S1589710 |
| modules1 | 2-8x1 | 18 | 100-400 | 10 |
| optic3 | side | No.1 |
| 2-8+8x5 | 18 | 100-400 | 10 |
| optic3 | side | No.2 |
| SBTB- | S1589711 |
| series | 2-8x1 | Marine | 90 | 200-400 | 10 | Symmetric |
No.1
frames
with RM Fiber S1589711
2-8x1 18 200-400
modules1 optic3 No.1
Standard RM, RM Ex, RM FOC, RM ES, RM ESB, RM PE, RM PE B, RM BG, RM BG B, RM ES BG, RM ES BGB
2
RMX, RX BG, RX BG B
3
Fiber optic conduits can only be installed in FOC-modules
Revision: 0
Table 2: approved cable penetration in A-0 Bulkhead
Max. cable
Frame Frame
Cable diameter
Frame type Size
type (OD)
[mm] [mm]
[mm]
S1589712
1-8+8x5 Marine
No.1-2
S1589712
1-8+8x10 Marine
No.3
S-series
frames S1589728
1-8+8x3 CLX
with RM No.1
modules1
Fiber S1589712
1-8+8x5 18
optic3 No.1-2
Fiber S1589712
1-8+8x10 18
optic3 No.3
S-series
frames S1589713
1-6+6x3 Marine
with RM No.1-2
modules2
Insulated S1589714
2-8x1 Marine
side No.1
| SK-series | Insulated | S1589714 |
| with RM | Fiber | Insulated | S1589714 |
| SBTB- | S1589715 |
| series | 2-8x1 | Marine | 82 | 200-400 | 10 | Symmetric |
No.1
frames
with RM Fiber S1589715
2-8x1 18 200-400
2
RMX, RX BG, RX BG B
3
Revision: 0
Table 3: approved cable penetration in A-60 Deck
Max. cable
Frame Frame
Cable diameter
Frame type Size
type (OD)
[mm] [mm]
[mm]
S1589708
1-8+8x2 Marine
No.6-7
Top side, S1589708
S-series 1-8+8x10
Symmetric No.8
frames
with RM S1589727
1-8+8x2 CLX
modules1 No.2
Any, Top
Fiber S1589708
1-8+8x10 18
optic3 No.6-8
Symmetric
S-series S1589709
1-6x1 Marine
frames No.5
with RM S1589709
modules2 1-6+6x3
No.3-4
S1589710
2-8x1 Marine
No.4
S1589710
2-8+8x5 Marine
No.3
SK-series
frames S1589729
2-8x1 CLX
with RM No.1
modules1
Fiber S1589710
2-8x1 18
optic3 No.4
Fiber S1589710
2-8+8x5 18
optic3 No.3
S1589711
1-8x1 Marine
SBTB- No.2
series
Symmetric, S1589730
frames 1-8x1
Top side No.1
with RM
modules1 Fiber
1-8x1 18
optic3 No.2
2
RMX, RX BG, RX BG B
3
Revision: 0
Table 4: approved cable penetration in A-0 Deck
Max. cable
Frame Frame
Cable diameter
Frame type Size
type (OD)
[mm] [mm]
[mm]
Top side, S1589712
1-8x1 Marine
symmetric No.4
S1589712
1-8+8x3 Marine
No.7
Top side, S1589712
1-8+8x10 Marine
symmetric No.5-6
S-series
frames S1589728
1-8+8x2 CLX
with RM No.2
modules1
Fiber Top side,
1-8x1 18
optic3 symmetric
Fiber S1589712
1-8+8x3 optic3
No.7
Fiber S1589712
1-8+8x10 optic3
No.5-6
S-series S1589713
1-6x1 Marine
frames No.5
with RM S1589713
modules2 1-6+6x3
No.3-4
S1589714
2-8x1 Marine
No.4
S1589714
2-8+8x5 Marine
No.3
SK-series
frames S1589735
2-8x1 CLX
with RM No.1
modules1
Fiber S1589714
2-8x1 18
optic3 No.4
Fiber S1589714
2-8+8x5 18
optic3 No.3
S1589715
1-8x1 Marine
SBTB- No.2
series
Symmetric, S1590462
frames 1-8x1
Top side No.1
with RM
modules1 Fiber
1-8x1 18
optic3 No.2
2
RMX, RX BG, RX BG B
3
