Model(s): Roxtec R Series Frames in A-Class Steel Divisions
| Product Design Assessment (PDA) | 24-2519751-PDA-DUP | 23-APR-2024 | 22-APR-2029 |
| Manufacturing Assessment (MA) | 23-6047656 | 28-SEP-2023 | 27-SEP-2028 |
Multi and single pipe penetrations in Class A0, A15, A30 and A60 bulkheads and decks for ship or
offshore applications. Penetrations of watertight and gastight steel bulkheads and decks up to the
specified pressure.
Roxtec sealing system with multidiameter technology: R-series (Steel division). The R-Series sealing
system consists of a rubber frame that are filled with Roxtec RM modules of different sizes depending on
number/diameter of the pipes. It is available in standard and EMC versions depending on application.
The R-seal is installed into a steel sleeve that is welded, bolted (only for deck) or attached by expansion
(SLFR X) onto the steel division.
A-0, A-15, A-30 and A-60 Steel Bulkheads and Decks.
SLR-Series (Welded) - Watertightness 4 bar & Gas Tightness 2 bar.
SLFR-Series (Bolted) - Watertightness 2.5 bar & Gas Tightness 1 bar.
SLRF X (Expansion) - Watertightness 4 bar & Gas Tightness 2 bar.
SL-Series (Welded) - Watertightness 1.33 bar & Gas Tightness 0.67 bar.
a) Minimum and maximum pipe outside diameters for bulkhead:
| 04/29/2024 5:40:13 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 1 of 5 |
| Certificate Number: 24-2519751-PDA-DUP |
SLR-Series & SL-Series - 6mm up to 54 mm for steel and copper pipes, & 8mm up to 50mm for bundle
pipes.
SLFR X - 6mm up to 53 mm for steel pipes.
b) Minimum and maximum pipe outside diameters for deck:
SLR-Series & SL-Series - 6mm up to 95 mm for steel pipes, 6mm up to 54 mm for copper pipes, & 8mm
up to 50mm for bundle pipes.
SLFR X - 6mm up to 54 mm for steel pipes.
c) Minimum and maximum frame sizes tested:
SLR-Series & SL-Series - Size 50 up to size 200.
SLFR X - Size 70 up to Size 200.
e) For fire class A-0, A-15 and A-30, sleeves are to be insulated as for class A-60 and in addition the
division is to be insulated at least 200 mm around the penetration, except for sizes that are approved
without insulation.
f) Unit Certification is not required for this product. If the manufacturer or purchaser request an ABS
g) Continued compliance with the statutory requirements requires maintenance of fully Type Approval
(PDA+MA). The scope of Type Approval is to comply with MSC.1/Circ.1221 dated 11 December 2006.
a) All seal type should be installed in accordance with the manufacturer’s instructions in accordance with
b) Insulation material is to be A-60 approved type and properly installed in accordance with ABS
approved drawings to the satisfaction of the Surveyors.
c) Watertight bulkheads or decks are to be tested as per ABS Marine Vessels Rules 3-7-1/Table 1.
penetration system has to comply with the requirements give in SOLAS Ch. 11-1 Reg. 13.2.3 (2020
Consolidated Edition).
e) This approval of penetrations passing through watertight bulkhead is not to be construed as a
substitute for flag Administration’s approval for the purpose of SOLAS (2020 Consolidated Edition).
f) The product or packing is to be marked with name of manufacturer, type designation and fire rating
g) Any component of penetration systems shall not be replaced by materials that have not been tested in
accordance with the IMO FTP Code and/or accepted by the Flag Administration.
h) Installation of transits are only permissible where strength and fatigue characteristics are not
diminished or where satisfactory structural compensation has been provided.
i) This certificate may not be used for EU and US flagged vessels (MED and/or USCG have their own
specific requirements).
j) Approval not performed on behalf of any Flag Administration
k) The Manufacturer has provided a declaration about the control of, or the lack of Asbestos in this
| 04/29/2024 5:40:13 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 2 of 5 |
Test Reports:
a) DBI Fire Test Reports:
PGA10723A dated 04 February 2016, PGA10724A dated 05 February 2016, PGA10799A dated 24 May
2016, PGA10800A dated 26 May 2016, PGA11301A dated 22 November 2018, PGA11302A dated 16
January 2019, PGB10046A dated 16 November 2020, PGB10118A dated 15 November 2021,
PGB10174A dated 13 July 2022, and PGB10176A dated 04 November 2022.
b) SP Fire Test Reports:
8P04039 dated 06 August 2018, 8P04040 dated 13 August 2018, and 4P08662 dated 08 June 2015.
c) CTO Fire Test Reports:
RS-18/B-292/E dated 13 September 2018,RS-19/B-225/E dated 01 August 2019, RS-22/B-153/E dated
04 May 2022, RS-22/B-336/E dated 28 October 2022, RS-22/B-337/E dated 28 October 2022,
RS-22/B-338/E dated 28 October 2022, RS-22/B-395/E dated 28 November 2022, RS-23/B-339/E dated
03 November 2023, and RS-23/B-340/E dated 03 November 2023.
d) DNV Water and Gas Tightness Test Reports:
N1429Y4V dated 21 March 2022, N142G50V dated 11 November 2022, and N142JK51 dated 27
February 2023.
Drawings:
a) Drawing No. S1598932, Rev. A, Roxtec R-Series with Pipes - A-60 Class Steel Bulkhead/Deck -
SLR-Series.
b) Drawing No. S1598934, Rev. A, Roxtec R-Series with Pipes - A-0 Class Steel Bulkhead/Deck -
SLR-Series.
c) Drawing No. S1598936, Rev. A, Roxtec R-Series with Pipes - A-60 Class Steel Deck/Bulkhead -
SL-Series.
d) Drawing No. S1598938, Rev. A, Roxtec R-Series with Pipes - A-0 Class Steel Deck/Bulkhead -
SL-Series.
e) Drawing No. S1598967, Rev. B, Roxtec R-Series with Pipes - A-60 Class Steel Bulkhead/Deck -
SLFR X.
f) Drawing No. S1598968, Rev. A, Roxtec R-Series with Pipes - A-0 Class Steel Bulkhead/Deck - SLFR
X.
This Product Design Assessment (PDA) Certificate remains valid until 22/Apr/2029 or until the Rules
2024 ABS Rules for Building and Classing Marine Vessels 1-1-4/7.7, 1-1-A3, 1-1-A4, and 4-6-2/9.7.
2024 ABS Rules for Conditions of Classification - Offshore Unit and Structures 1B-1-4/9.7, 1B-1-A2, and
| 04/29/2024 5:40:13 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 3 of 5 |
1B-1-A3.
2024 ABS Rules for Building and Classing Mobile Offshore Units 1-1-4/9.7, 1-1-A2, 1-1-A3, 4-2-1/11.15
Regulation II-2/ 9.3.1 of SOLAS (2020 Consolidated Edition).
The products comply with the following sections of the Canadian Vessel Fire Safety Regulations
(SOR/2017-14): Part 2 - 209 & 227, Part 3 - 325 (1) and C.R.C., c. 1431 Canada Consolidation Hull
Construction Regulations (Last amended 20 Dec. 2023), Part 1 / Section 14(7)(b), and when produced at
a facility with an ABS manufacturing assessment (MA) is approved on behalf of the Minister of Transport
in accordance with TP14612E - Procedures for Approval of Life-Saving Appliances and Fire Safety
Systems, Equipment and Products (4th Ed., Feb. 2019 - Ch. 2).
Print Date and Time: 29-Apr-2024 5:40
| 04/29/2024 5:40:13 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 4 of 5 |
| 04/29/2024 5:40:13 AM | Copyright 2019 American Bureau of Shipping. All rights reserved. | Page 5 of 5 |
| ROXTEC INTERNATIONAL AB |
Roxtec R-Series Frames in A-Class Steel Divisions
PDA No. 24-2519751-PDA
Issue Date: 23 APR 2024
Expiry Date: 22 APR 2029
Revision 0
Table 1: A-60 Bulkhead
| Pipe | Sleeve | Sleeve |
| R-series | Sleeve | Pipe |
| Diameter | Length | Thickness |
| Size | Type | Material |
| (OD)[mm] | [mm] | [mm] |
S1598932
| SLR- | Symmetric, |
| 50 - 200 | Steel |
| Series1 | Insulated side |
| No. 8 – 10 | |
| S1598932 |
SLR-
| 50 - 200 | Cu | 6 – 54 | 55 | 4–7 | Symmetric | Rev A |
| Series1 | ||||||
| No. 11 – 12 | ||||||
| S1598932 |
SLR-
| 50 - 200 | CuNi | 6 – 54 | 55 | 4–7 | Symmetric | Rev A |
| Series1 | ||||||
| S1598932 | ||||||
| SLR- | Bundle | |||||
| 50 - 200 | 8 – 50 | 55 | 4–7 | Symmetric | Rev A | |
| Series1 | Pipe | |||||
| No. 13 | ||||||
| S1598932 | ||||||
| SLR- | No | |||||
| 50 - 200 | N/A | 55 | 4–7 | Symmetric | Rev A | |
| Series1 | Service | |||||
| No. 14 | ||||||
| S1598967 | ||||||
| 70 - 200 | SLFR X | Steel | 6 – 53 | 55 | 5–6 | Any |
| No. 3 | ||||||
| S1598936 | ||||||
| SL- | Up to | |||||
| 50 – 200 | Steel | 6 – 54 | 4–7 | Any | Rev A | |
| Series2 | 400 | |||||
| No. 7 – 8 | ||||||
| S1598936 | ||||||
| SL- | Up to | |||||
| 50 – 200 | Cu | 6 – 54 | 4–7 | Any | Rev A | |
| No. 9 – 10 | ||||||
| S1598936 | ||||||
| SL- | Up to | |||||
| 50 – 200 | CuNi | 6 – 54 | 4–7 | Any | Rev A | |
| No. 9 – 10 | ||||||
| S1598936 | ||||||
| SL- | Bundle | Up to | ||||
| 50 – 200 | 8 – 50 | 4–7 | Any | Rev A | ||
| Series2 | Pipe | 400 | ||||
| No. 11 |
- SLR-Series includes the following sleeve types: SLR, SLR EX or sleeves equal to dimensions specified in
drawing S1587721.
2) SL-series are longer versions of sleeves in SLR-series.
Revision 0
Table 2: A-60 Deck
S1598932
SLR-
| 50 - 200 | Steel | 6 – 95 | 55 | 4–7 | Any | Rev A |
| Series1 | ||||||
| No. 1 – 3 | ||||||
| S1598932 |
SLR-
| 50 - 200 | Cu | 6 – 54 | 55 | 4–7 | Any | Rev A |
| Series1 | ||||||
| No. 4 – 5 | ||||||
| S1598932 |
SLR-
| 50 - 200 | CuNi | 6 – 54 | 55 | 4–7 | Any | Rev A |
| Series1 | ||||||
| No. 4 – 5 | ||||||
| S1598932 | ||||||
| 50 - 200 | 8 – 50 | 55 | 4–7 | Any | Rev A | |
| No. 6 | ||||||
| S1598932 | ||||||
| SLR- | No | Symmetric, | ||||
| 50 - 200 | N/A | 55 | 4–7 | Rev A | ||
| Series1 | Service | Top | ||||
| No. 7 | ||||||
| S1598967 | ||||||
| 70 - 200 | SLFR X | Steel | 6 – 54 | 55 | 5–6 | Any |
| No. 1 – 2 | ||||||
| S1598936 | ||||||
| SL- | Up to | |||||
| 50 – 200 | Steel | 6 – 95 | 4–7 | Any | Rev A | |
| No. 1 – 3 | ||||||
| S1598936 | ||||||
| SL- | Up to | |||||
| No. 4 – 5 | ||||||
| S1598936 | ||||||
| SL- | Up to | |||||
| No. 4 – 5 | ||||||
| S1598936 | ||||||
| No. 6 |
- SLR-Series includes the following sleeve types: SLR, SLR EX, SLFR, SLFR Ex or sleeves equal to dimensions
specified in drawing S1587721.
2
Revision 0
Table 3: A-0 Bulkhead
S1598934
| SLR- | Symmetric, |
| 50 - 200 | Steel |
| Series1 | Insulated Side |
| No. 9 – 12 | |
| S1598934 |
SLR-
| Series1 | ||||||
| No. 13 – 14 | ||||||
| S1598934 |
SLR-
| Series1 | ||||||
| S1598934 | ||||||
| No. 15 | ||||||
| S1598934 | ||||||
| SLR- | No | |||||
| No. 16 | ||||||
| S1598968 | ||||||
| No. 3 | ||||||
| S1598938 | ||||||
| SL- | Up to | |||||
| No. 7 – 8 | ||||||
| S1598938 | ||||||
| SL- | Up to | |||||
| No. 9 – 10 | ||||||
| S1598938 | ||||||
| SL- | Up to | |||||
| No. 9 – 10 | ||||||
| S1598938 | ||||||
| No. 11 |
drawing S1587721.
3
Revision 0
Table 4: A-0 Deck
| (OD) [mm] | [mm] | [mm] |
| S1598934 |
SLR-
| Series1 | ||||||
| No. 1 – 4 | ||||||
| S1598934 |
SLR-
| Series1 | ||||||
| No. 5 – 6 | ||||||
| S1598934 |
SLR-
| Series1 | ||||||
| No. 5 – 6 | ||||||
| S1598934 | ||||||
| No. 7 | ||||||
| S1598934 | ||||||
| No. 8 | ||||||
| S1598968 | ||||||
| No. 1 – 2 | ||||||
| S1598938 | ||||||
| SL- | Up to | |||||
| No. 1 – 3 | ||||||
| S1598938 | ||||||
| SL- | Up to | |||||
| No. 4 – 5 | ||||||
| S1598938 | ||||||
| SL- | Up to | |||||
| No. 4 – 5 | ||||||
| S1598938 | ||||||
| No. 6 |
4
Revision 0
Table 5: Water and Gas Tightness Performance
| Sleeve Type | Mounting Option | Watertightness | Gas tightness |
| SLR-Series1 | Welded | 4 bar | 2 bar |
| SLFR-Series | 2 |
| Bolted | 2.5 bar | 1 bar |
| SLFR X | Expansion | 4 bar | 2 bar |
| SL-Series3 | Welded | 1.33 bar | 0.67 bar |
drawing S1587721.
- installed with pre-punched gasket and sealing washers on both sides of the division.
