38115_B0 BV-optimized
Certificate number: 38115/B0 BV
File number: ACI4010/030/002
Product code: 5301H
This certificate is not valid when presented without the
full attached schedule composed of 7 sections
Sleev-it Steel to Plastic Pipe Transition Collar
SOLAS 74, as amended, Regulations II-2/9.3.1
IMO Res. MSC.61(67) -(FTP Code)- with IMO Res MSC.307(88) -(2010 FTP Code)- article 8
This certificate is a renewal of certificate N° 38115/A1 BV expiring on 22/05/2019
This certificate will expire on: 22 May 2024
At BV GOTHENBURG, on 05 Mar 2019,
Magne MOLLER
BV Mod. Ad.E 530 June 2017 This certificate consists of 3 page(s)
1. PRODUCT DESCRIPTION:
Sleev-It Steel to Plastic pipe transition Collar
This penetration is for connection between a single steel pipe (or steel connector) and a single plastic pipe as an A-class
penetration, at a distance less than 450 mm from the division. The penetration part fixed to the division is the steel pipe (or
drain), tack welded with 4 points to the fire division. The tightness between the steel pipe (or drain) and the plastic pipe is not
part of this approval.
The Sleev-it fire collars are clamped around the steel pipe by using the steel “Jubilee” clip 20 mm long, which tightens around
the neck of the fire collar and clamps the fire collar tightly to the steel pipe. The Sleeve-it fire collar is mechanically fixed to the
steel pipe. Each Sleev-it fire collar (except collar boxes) comprises a 110 mm-long and 0.7 mm thick tubular steel casing. A
break is incorporated in the casing so that the collar can be sprung open to permit installation around a pipe.
In the 60 mm-long base part of the collar, several layers of intumescent material are inserted between the casing and the pipe,
nominally 1.8 mm or 2.5 mm thick. The appropriate number of layers depending on the pipe diameter is given in §4.3.
Collar boxes only differs from conventional Sleev-it collars by dimensions of the steel casing (see in table).
Diameter of
Steel part welded to the Collars
Fire collar tested PPr
fire division fire rating
plastic pipe
Steel pipe In bulkheads:
SLV50M-Ext 1 collar to either side of the bulkhead, 75
for bulkheads (∅ = 50 mm
mm min. from the bulkhead or from the extent on all steel parts of the penetration
min. thickness = 1 mm) bulkhead insulation
SLV50M-Ext Blücher Connector
collar box for type 870.000.050 FS
A15, A30
decks with (∅ = 90 mm
and A60
Blücher thickness = 5 mm
Connector deepness = 155 mm)
Blücher Drain
SLV50M-Ext type 470.200.050 S
A15, A30
for decks with (hole size in deck:
and A60
Blücher Drain approx. 110 mm min. below deck
∅ = 130 mm)
Steel pipe In bulkheads: On the insulated side:
SLV75M-Ext 1 collar to either side of the bulkhead, 25 mm thick “Rockwool Firebatts 825”
for bulkheads (∅ = 75 mm 75 to 90 mm
min. thickness = 1 mm) bulkhead insulation the penetration along 300 mm max.
Blücher Connector
SLV75M-Ext type 870.000.075 FS In decks:
for decks with A15, A30
Blücher (∅ = 108 mm 75 to 90 mm
and A60
thickness = 5 mm mm min. below deck extent, on the Blücher connector
Connector
deepness = 167 mm)
Blücher Drain In decks:
SLV75M-Ext
type 470.200.075 S 1 collar box (240 x 185 x 110 mm) fixed
collar box for A15, A30
and A60
min below deck, 10-30 mm above the extent, on the Blücher Drain
Blücher Drain ∅ = 132 mm)
∅: diameter
PPr: polypropylene
Materials and/or components:
- Collar steel casing: manufactured by Geoman Pressings Ltd.
- Blücher connectors and drains: manufactured by Blücher.
- 1.8 mm intumescent material layers: type “TRP 345” manufactured by Trafford Rubber Products.
- 2.5 mm intumescent material layers: type “Promaseal PL” manufactured by Promat.
- Mineral wool used for fire tests: type “Rockwool Firebatts 825” (density 110 kg/m³) manufactured by Rockwool.
2. DOCUMENTS AND DRAWINGS:
As per Manufacturer’s drawing N° S1026334 rev.B dated 07/01/2013
3. TEST REPORTS:
3.1 - Test reports N° 175486/A dated 31/10/2008, N° 177105A dated 06/01/2009 and letter dated 18/03/2009, as per IMO FTP
Code Annex 1 Part 3 [test standard : IMO Resolution A.754(18)], from Warrington Fire laboratory, UK.
3.2 - Technical assessment N° 182483 dated 27/04/2009, from Warrington Fire laboratory, UK.
4. APPLICATION / LIMITATION:
4.1 - The fitting aboard to be the same as used for the test.
4.2 - Approved for use as pipe penetrations in A-15, A-30 and A-60 class steel divisions, with limitations contained in §1.
4.3- The arrangement of the pipe penetration (with fire insulation, if any) is subject to approval in each case.
4.4 - Penetration seal specifications :
Plastic Pipe diameter (mm) Minimum number of intumescent material layers
50 3 x 1.8 mm
75 3 x 2.5 mm
90 4 x 2.5 mm
4.5 - Additional non-combustible mineral wool: The fire tests were conducted with mineral wool type “Rockwool Firebatts 825”
(density 110 kg/m³); any approved A-class insulation of similar type giving at least an equivalent insulation performance can be
used.
5.1 - The Sleev-it pipe collars are to be supplied by ROXTEC International AB in compliance with the type described in this
certificate.
7. OTHERS:
7.2 - This certificate supersedes Type Approval Certificate N° 38115/A1 BV issued on 08/02/2017 by the Society.
