Certificate number: 46362/A1 BV
File number: ACI4000/032/011
Product code: 5301H
This certificate is not valid when presented without the
full attached schedule composed of 7 sections
Roxtec sealing system: Roxtec SPM seal series in steel divisions
SOLAS 74, as amended, SOLAS 2000 Regulations II-2/9.3.1
IMO Resolution MSC.307(88) Annex 1 Part 3 (FTP Code 2010)
This certificate will expire on: 05 Sep 2021
At BV GOTHENBURG, on 18 Sep 2017,
Magne MOLLER
| BV Mod. Ad.E 530 June 2017 | This certificate consists of 3 page(s) |
1. PRODUCT DESCRIPTION :
Single pipe penetration in Class A0, A15, A30 and A60 bulkheads and decks for Marine and Offshore Application. Penetrations
of watertight and gastight steel bulkheads and decks up to specified pressure
Roxtec sealing system, Roxtec SPM seal series consisting of rubber seal in sizes 39-279 attached through expansion to steel
sections.
The sealing system is made for steel pipes with outside diameter 8 to 220 mm for bulkhead and deck, with Roxtec SPM seal in
size 39-279. Outside diameter for copper pipes to be between 8 to 222 mm for bulkhead and deck, with Roxtec SPM seal in size
39-279.
Insulation of the penetration to be carried out as shown in manufacturers drawings:
| S1522746 | Rev A. dated 10.5.2017 | A-Class Steel Bulkhead Steel pipe |
| S1522747 | Rev A. dated 10.5.2017 | A-Class Steel Bulkhead Copper pipe |
| S1522742 | Rev A. dated 10.5.2017 | A-Class Steel Deck Steel pipe |
| S1522749 | Rev A. dated 10.5.2017 | A-Class Steel Deck Copper pipe |
Penetrations through A-0 divisions are to be provided with the insulation as per manufacturers installation drawings for the
penetration and 200 mm around the penetration.
| S1522750 | Rev A. dated 10.5.2017 | A-0 Class Steel Bulkhead Steel pipe |
| S1522751 | Rev A. dated 10.5.2017 | A-0 Class Steel Bulkhead Copper pipe. |
| S1522755 | Rev A. dated 10.5.2017 | A-0 Class Steel Deck Steel pipe. |
| S1522756 | Rev A. dated 10.5.2017 | A-0 Class Steel Deck Copper pipe |
- DOCUMENTS AND DRAWINGS :
As per Manufacturer’s drawingns N° S1502970 Rev D dated 2016-08-25.
Manufacturers Installation instruction DOC-0000116 version B.
3. TEST REPORTS :
3.1 - Test report N° 5P03451, dated 03.11.2015, as per IMO 2010-FTP Code from SP, Sweden
3.2 - Test report N° 5P03457, dated 12.11.2015, as per IMO 2010-FTP Code from SP, Sweden
3.3 - Test report N° 5P08343, dated 21.12.2015, as per IMO 2010-FTP Code from SP, Sweden
3.4 - Test report N° 5P08346, dated 21.12.2015, as per IMO 2010-FTP Code from SP, Sweden
3.5 - Test report N° 5P08395, dated 17.3.2016, as per IMO 2010-FTP Code from SP, Sweden
3.6 - Test report N° 5P05989, dated 24.10.2016, as per IMO 2010-FTP Code from SP, Sweden
3.7 - Test report N° 5P05990, dated 16.11.2016, as per IMO 2010-FTP Code from SP, Sweden
3.8 - Test report N° 6P07565, dated 20.12.2016, as per IMO 2010-FTP Code from SP, Sweden
3.9 - Test report N° PGA10870A, dated 13.12.2016, as per IMO 2010-FTP Code from DBI, Denmark
4. APPLICATION / LIMITATION :
4.1 - The fitting aboard to be the same as used for the test.
4.2 - Approved for use as pipe transits in A-0, A-15, A-30 and A-60 class steel divisions, with limitations contained in §1.
4.3 - Not to be used in tank boundaries.
4.4 - All seal types should be installed in according with manufactures installation drawings.
4.5 - The insulating material(s) shall have to comply with the requirements of BV Rules and be type approved.
5.1 - The “SPM seal series” are to be supplied by "ROXTEC International AB " in compliance with the type described in this
certificate.
5.2 -This type of product is within the category HBV of Bureau Veritas Rule Note NR320 and as such does not require a BV
5.3 - "ROXTEC International AB " has to make the necessary arrangements to have its works recognised by Bureau Veritas in
compliance with the requirements of NR320 for HBV products :
BOX 540
371 23 KARLSKRONA
6. MARKING OF PRODUCT :
7. OTHERS :
7.2 -This certificate supersedes BV type approval certificate 46362/A0 BV issued by the Society.
7-3 - Tested for water tightness (before fire exposure): 1.5 bar during 60 min. Tested gas tightness (before fire exposure): 1.0 bar
during 30 min in 4-15mm Structure.
- Third Party Inspection report N° N417RRN dated 29.01.2016, from DNV-GL, Sweden
- Third Party Inspection report N° N1419WS4 dated 22.06.2016 from DNV-GL, Sweden
