46362_B0 BV-optimized
Certificate number: 46362/B0 BV
File number: ACI4000/032/011
Product code: 5301H
Roxtec sealing system: Roxtec SPM seal series in steel divisions
SOLAS 74 convention as amended, Regulations II-2/9
IMO Res. MSC.307(88) (2010 FTP Code)
IMO MSC.1/Circ.1276
IMO MSC.1/Circ.1488
This certificate will expire on: 08 Jul 2027
At BV GOTHENBURG, on 08 Jul 2022,
Torbjorn Ygesjo
signature
BV Mod. Ad.E 530 June 2017 This certificate consists of 5 page(s)
1. PRODUCT DESCRIPTION :
1.1 - Roxtec SPM Seal Series in steel divisions
Single-pipe non-weld penetration system in A-0 to A-60 Class watertight and gastight steel bulkheads and decks up to
specified pressure, for Marine and Offshore applications.
Penetration system consisting in Roxtec SPM rubber sealing body between steel front and rear fittings, in sizes 39-279,
attached through expansion to steel sections.
Details of pipe penetrations
Type of Size Pipe Pipe diameter Mounting in Insulation arrangement Achieved
division material (OD) division classification
As per drawings in §2.2.1.
Bulkhead 39 - 279 Steel 8 – 222 mm General application A-60
See arrangement (1)
39 - 279 Copper 12 – 222 mm
See arrangement (2)
39 - 279 Steel 8 – 220 mm As per drawings in §2.2.1.
Deck General application A-60
See arrangement (3)
39 - 279 Copper 8 – 222 mm As per drawings in §2.2.1.
See arrangement (4)
39 - 279 Steel 12 – 222 mm General application A-0
See arrangement (5)
Design of insulation arrangement
N° of insulation Division Insulation arrangement
arrangement
(1) A-60 As per drawings in §2.2.1.
Bulkhead On unexposed side,
. for sizes 39-119: 50 mm thick, 300 mm long;
. for sizes 119-226:
Same insulation as for A-60 bulkhead, 200 mm wide from penetration edge
  • 50 mm thick, 400 mm long on pipe;
    . for sizes 226-279:
  • 100 mm thick, 500 mm long on pipe.
On exposed side,
    | (2) | A-60 | As per drawings in §2.2.1. |
    | Bulkhead | On unexposed side, |
    . for sizes 39-119:
    Same insulation as for A-60 bulkhead, 100 mm wide from penetration edge
  • 50 mm thick, 600 mm long on pipe;
  • 100 mm thick, 700 mm long on pipe.
On exposed side,
(3) A-60 Deck On exposed side,
. for sizes 69-119: 50 mm thick, 300 mm long on pipe;
. for sizes 119-226: 50 mm thick, 400 mm long on pipe;
. for sizes 226-279: 100 mm thick, 600 mm long on pipe.
(4) A-60 Deck On exposed side,
. for sizes 39-69: 50 mm thick, 400 mm long on pipe;
. for sizes 69-138: 100 mm thick, 800 mm long on pipe;
. for sizes 138-196 : Same insulation as for A-60 deck, 100 mm wide from penetration
edge
  • 100 mm thick, 800 mm long on pipe;
    . for sizes 196-279, 100 mm thick, 1200 mm long on pipe.
    | (5) | A-60 Deck | On exposed side, |
    . for sizes 39-138: Same insulation as for A-60 deck, 100 mm wide from penetration
edge;
. for sizes 149-279: Same insulation as for A-60 deck, 200 mm wide from penetration
edge.
1.2 - Roxtec SPM Blind Seal Series in steel divisions
No-pipe non-weld penetration system in A-0 to A-60 Class watertight and gastight steel bulkheads and decks up to specified
Consisting in Roxtec SPM rubber sealing body between steel front and rear fittings, in sizes 39/0 to 92/0, attached through
Type of Size Pipe Pipe Mounting in division Insulation arrangement Achieved
division material diameter classification
(OD)
Bulkhead 39/0 N/A N/A General application As per drawings in §2.2.2. A-60
For size 92/0, additional
insulation (30 mm thick,
250 mm diameter)
41/0 – 92/0 Exposed side (restricted A-60
application - see §4.1)
Deck 39/0 – 92/0 N/A N/A General application As per drawings in §2.2.2. A-60
N/A : not applicable
2. DOCUMENTS AND DRAWINGS :
As per Manufacturer’s drawings:
2.1 - Design of products
S1502970 Rev F dated 18.10.2021: SPM 39-279 Assembly
S1524712 Rev C dated 12.10.2020: SPM Blind Seal Special 39-92/0
2.2 - Installation / insulation arrangement:
2.2.1 – SPM Seals
For A-60 Class penetrations:
S1522746 Rev A dated 10.05.2017 A-Class Steel Bulkhead Steel pipe
S1522747 Rev B dated 03.06.2022 A-Class Steel Bulkhead Copper pipe
S1522742 Rev A dated 10.05.2017 A-Class Steel Deck Steel pipe
S1522749 Rev A dated 10.05.2017 A-Class Steel Deck Copper pipe
For A-0 Class penetrations:
S1522750 Rev A dated 10.05.2017 A-0 Class Steel Bulkhead Steel pipe
S1522751 Rev A dated 10.05.2017 A-0 Class Steel Deck Steel pipe
S1566686 Rev. A dated 04.05.2021 A-0 Class Steel Deck Steel pipe
S1522756 Rev A dated 10.05.2017 A-0 Class Steel Deck Copper pipe
2.2.2 – SPM Blind Seals
S1566688 Rev A dated 04.05.2021: SPM Blind Seal / A-60 class steel deck/bulkhead
S1566700 Rev A dated 04.05.2021: SPM Blind Seal / A-0 class steel deck/bulkhead
2.3 - Manufacturer’s installation instructions:
DOC-000116 Rev E: SPM Seals
DOC-003725 Rev A: SPM Blind Seals.
3. TEST REPORTS :
All tests carried out as per IMO 2010 FTP Code, Annex 1, Part 3.
For SPM Seals:
3.1 - Bulkhead: test report N° 5P03451, dated 03.11.2015, from SP, Sweden
3.2 - Bulkhead: test report N° 5P08346, dated 21.12.2015, from SP, Sweden
3.3 - Bulkhead: test report N° 6P05990, dated 16.11.2016, from SP, Sweden
3.4 - Bulkhead: test report N° 6P07565, dated 20.12.2016, from SP, Sweden
3.5 - Bulkhead: test report N° PGA10870A, dated 13.12.2016, from DBI, Denmark
3.6 - Bulkhead: test report N° RS-18/B-022/E dated 29.01.2018, from CTO, Poland
3.7 - Deck: test report N° 5P03457, dated 12.11.2015, from SP, Sweden
3.8 - Deck: test report N° 5P08343, dated 21.12.2015, from SP, Sweden
3.9 - Deck: test report N° 5P08395, dated 17.03.2016, from SP, Sweden
3.10 - Deck: test report N° 6P05989, dated 24.10.2016, from SP, Sweden
3.11 - Deck: test report N° RS-17/B-177/E dated 06.05.2017, from CTO, Poland
3.12 - Deck: test Report N° PGA11302A dated 16.01.2019, from DBI, Denmark
For SPM Blind Seals:
3.13 - Bulkhead: test Report N° RS-18/B-022/E dated 29.01.2018, from CTO, Poland
3.14 - Bulkhead: test Report N° RS-18/B-181/E dated 07.05.2018, from CTO, Poland
3.15 - Deck: test Report N° RS-18/B-023/E dated 29.01.2018, from CTO, Poland
4. APPLICATION / LIMITATION :
4.1 - Restricted application (for SPM Blind Seals in sizes above 39/0): the seals are to be fitted as per tested configuration (i.e.
fitted with rubber seal on the side of A-Class bulkhead exposed to the fire hazard).
4.2 - Approved for use in A-15, A-30, A-60 class steel divisions, with fire insulation as described in drawings referenced in
§2.2. For A-0 class divisions, local insulation arrangement shall be installed (on the penetration itself and 200 mm around) as
described in drawings referenced in §2.2.
4.3 - Not to be used as penetrations in tank boundaries.
4.4 - All seal types should be installed according with Manufacturer’s installation drawings and installation instructions (see
§2.3).
4.5 - The insulating material(s) shall have to comply with the requirements of BV Rules and be type approved.
4.6 - The tests have been carried out with different A-60 class insulating materials; any alternative insulation material is subject
to case by case approval providing that it has been approved as giving at least an equivalent insulation performance.
5.1 - The “SPM Seal series / SPM Blind Seal series” are to be supplied by ROXTEC International AB in compliance with
the type described in this certificate.
5.4 - For information, ROXTEC International AB has declared to Bureau Veritas the following production site(s):
BOX 540
371 23 KARLSKRONA
6. MARKING OF PRODUCT :
7. OTHERS :
7.2 -This certificate supersedes BV type approval certificate 46362/A1 BV issued on 18/09/2017 by the Society.
7.3 - For SPM 39 - 279: tested for water tightness (before fire exposure): 1.5 bar during 60 min and gas tightness (before fire
exposure): 1.0 bar during 30 min, in 4-15 mm structure.
  • Third Party Inspection report N° N141805A dated 20.12.2016, from DNV-GL, Sweden
  • Third Party Inspection report N° N417RRN dated 29.01.2016, from DNV-GL, Sweden
  • Third Party Inspection report N° N1419WS4 dated 22.06.2016 from DNV-GL, Sweden
7.4 - For SPM Blind 39/0 – 92/0: tested for water tightness (before fire exposure): 1.5 bar during 60 min. Tested gas tightness
(before fire exposure): 1.0 bar during 30 min.
  • Third Party Inspection report N° N141805C dated 22.11.2017, from DNV-GL, Sweden
