Certificate number: 53012/A0 BV
File number: ACI 4010/030/005
Product code: 5301H
This certificate is not valid when presented without the
full attached schedule composed of 7 sections
Sleev-it FC and Sleev-it WT for plastic pipes in Aluminium divisions
SOLAS 74, as amended, Regulations II-2/9.3.1
IMO Res MSC.307(88) (2010 FTP Code)
This certificate will expire on: 01 Aug 2023
At BV GOTHENBURG, on 01 Aug 2018,
Torbjorn Ygesjo
| BV Mod. Ad.E 530 June 2017 | This certificate consists of 3 page(s) |
1. PRODUCT DESCRIPTION :
Penetration system consisting of a stainless steel casing containing intumescent material.
It has also an additional rubber grommet that is engineered for a wide range of pipe sizes. Roxtec Sleev-it penetration series
consisting of seal in sizes 16-225 for aluminium sections.
| Penetration type | Pipe material | Pipe Outer diameter | Installation | Insulation drawing |
| Sleev-it FC | Plastic Pipe | 16 to 225 mm | Bulkhead/ Deck | S1530946, rev A, dated 2018-03-08 |
| Sleev-it WT | Plastic Pipe | 16 to 225 mm | Deck | S1530951, rev A, dated 2018-03-07 |
- DOCUMENTS AND DRAWINGS :
- Insulation Drawings S1530946, rev A, dated 2018-03-08 and S1530951, rev A, dated 2018-03-07
- Information Drawings S1507771, rev B, dated 2016-05-26 and S1507772, rev D, dated 2017-06-08
3. TEST REPORTS :
- Test report N° PGA10801A, dated August 29, 2016, as per IMO 2010 FTP Code Annex 1 Part 3, from DBI, Denmark
- Test report N° PGA10802A dated August 29, 2016, as per IMO 2010 FTP Code Annex 1 Part 3, from DBI, Denmark
- Test report N° RS-17/B-209/E, dated June 2, 2017, as per IMO 2010 FTP Code Annex 1 Part 3, from CTO, Poland
- Test report N° RS-17/B-210/E, dated June 2, 2017, as per IMO 2010 FTP Code Annex 1 Part 3, from CTO, Poland
- Test report N° RS-17/B-555/E, dated January 15, 2018, as per IMO 2010 FTP Code Annex 1 Part 3, from CTO, Poland
4. APPLICATION / LIMITATION :
4.1- The fitting aboard to be the same as used for the test.
4.2- Not for use in tank boundaries.
4.3- The insulation material shall be type approved. The fire tests were conducted with various types of insulation materials;
alternative ones (duly type approved) may be used provided their insulation performance are equivalent/appropriate.
4.4- Approved for use as pipe penetrations in A-0, A-15, A-30 and A-60 class steel divisions. For A-0 class divisions, local fire
insulation arrangement shall be installed (on the penetration itself - i.e. as per fire tests - and further extended 200 mm around).
5.1 -The Sleev-it FC & WT penetration seals are to be supplied by Roxtec International AB in compliance with the type
described in this certificate.
5.2 -This type of product is within the category HBV of Bureau Veritas Rule Note NR320 and as such does not require a BV
5.3 - Roxtec International AB has to make the necessary arrangements to have its office and production site(s) recognised by
Bureau Veritas in compliance with the requirements of NR320 for HBV products.
The product or packing is to be marked with manufacturer name, type designation and fire technical rating.
7. OTHERS :
7.1- It is Roxtec International AB responsibility to inform shipbuilders or their sub-contractors of the proper methods of
7.2- Watertightness and Gastightness (before fire exposure) for Sleev-it WT penetration seal: Inspection report N° N141EX90,
dated June 30, 2017, from DNV-GL:
• Tested watertightness : 1,5 bar during 60 min.
• Tested gastightness : 1 bar during 30 min.
