Certificate number: 63792/A0 BV
File number: ACI4010/030/007
Product code: 5301H
A-Class divisions “Cable sealing system with multidiameter technology, Roxtec S-Series”
SOLAS 74, as amended, Regulations II-2/9.3.1
IMO Res MSC.307(88) (2010 FTP Code)
IMO Res. MSC.61(67)-(FTP Code) with IMO Res MSC.307(88) (2010 FTP Code) article 8
IMO MSC/Circ.1120
This certificate will expire on: 27 Jan 2026
At BV GOTHENBURG, on 27 Jan 2021,
Magne MOLLER
| BV Mod. Ad.E 530 June 2017 | This certificate consists of 3 page(s) |
1. PRODUCT DESCRIPTION:
Consisting of Roxtec S-series frames (S, SO, SF, SFO, SR, SK, SRC r20&r40 and BTB) in sizes 1-8 and combinations thereof,
welded or bolted on to the steel divisions; filled with Roxtec (standard or Ex, EMC) halogen free insert modules. Assembled
with Roxtec Wedge kit or Roxtec EMC, Ex Wedge kit.
Pipe outer
| Type of pipe | Insulation arrangement on pipes |
| diameter | |
| Bulkhead: | two layers (45 mm thick and 350 mm long) of mineral wool(3) |
| Steel pipe / Titanium pipe 6 - 50 mm | Deck: |
| ∅6-50: one layer (50 mm thick and 350 mm long) of mineral wool(2) |
| Bundle pipes (in stainless | Bulkhead / deck: two layers (30 mm thick and 500 mm long) of mineral wool(1) |
| steel and copper version) 16 - 50 mm | compressed to 50 mm (space between pipes filled of wool) |
| (1) (2) (3) see §4.3 |
2. DOCUMENTS AND DRAWINGS:
As per the Manufacturer’s drawings:
2.1 - Steel pipe / Titanium pipe: N° S1561814 Rev.A dated 07/12/2020 (A-60 Class division) and N° S1561862 Rev.A dated
07/12/2020 (A-0 Class division)
2.2 - Bundle pipes (in stainless steel and copper version): N° S1561835 Rev.A dated 04/12/2020 (A-60 Class division) and
N° S1561866 Rev.A dated 07/12/2020 (A-0 Class division)
3. TEST REPORTS:
3.1 - Steel bulkhead:
Test report N° P602999 dated 23/01/2007, as per IMO FTP Code Annex 1 Part 3 [test standard : IMO Resolution A.754(18)],
from SP, Sweden.
Test report N° RS-18/B-485/E dated 10/12/2018, as per IMO 2010 FTP Code Annex 1 Part 3, from CTO, Poland.
3.2 - Steel deck:
Test report N° P603000 dated 23/01/2007, as per IMO FTP Code Annex 1 Part 3 [test standard : IMO Resolution A.754(18)],
from SP, Sweden.
Test report N° RS-17/B-395/E dated 30/10/2017, as per IMO 2010 FTP Code Annex 1 Part 3, from CTO, Poland.
3.3 - Technical assessment:
Report “Comparison of titanium and steel pipes in a fire test”, N° 9P02428 dated 13/09/2019, from RISE, Sweden.
4. APPLICATION / LIMITATION:
4.1 - Approved for use with pipe penetrations in A-15, A-30, A-60 class steel divisions, with fire insulation as described in §1.
For A-0 class divisions, penetrations shall be installed with fire insulation as described in §1 and the division shall be fitted with
insulation 200 mm around the penetration.
4.2 - The arrangement of the pipe penetration (with fire insulation, if any) is subject to approval in each case.
4.3 - The tests have been carried out with fire insulating materials (1)“Rockwool Firemat 100” (thickness 30 mm; nominal
density 125 kg/m³), (2)“SeaRox SL 620” (thickness 50 mm; nominal density 100 kg/m³) or (3)“SeaRox WM 620” (thickness 45
mm; nominal density 90 kg/m³) manufactured by Rockwool International A/S; any alternative A-class insulation material,
previously proven and approved, giving at least an equivalent insulation performance, can be used.
5.1 - The A-Class divisions “Cable sealing system with multidiameter technology, Roxtec S-Series” are to be supplied by
ROXTEC International AB in compliance with the type described in this certificate.
The product or packing is to be marked with Manufacturer name, type, designation and fire-technical rating.
7. OTHERS:
It is ROXTEC International AB’s responsibility to inform shipbuilders or their sub-contractors of the proper methods of
