73351_A0 BV-optimized
Certificate number: 73351/A0 BV
File number: ACI 4000/032/014
Product code: 5300H
PIPE, CABLE, DUCT PENETRATIONS IN FIRE DIVISIONS
A-Class Penetration Systems with Multidiameter Technology, in 60 min load-bearing composite divisions:
S-, R-, RS- and RS PPS/S-series
(For details of approved configurations, see §1)
For bulkheads only, Restricted application (see §4.1)
BUREAU VERITAS Rules for the Classification of High Speed Craft, Chapter 7
SOLAS 74, as amended, Regulations X/3
IMO Res. MSC.307(88) (2010 FTP Code)
This certificate will expire on: 19 Oct 2028
At BV COPENHAGEN, on 19 Oct 2023,
Hans-erik ERICSSON
signature
BV Mod. Ad.E 530 June 2017 This certificate consists of 4 page(s)
1. PRODUCT DESCRIPTION:
A-60 Class Cable or Pipe Penetration System with Multidiameter Technology, in 60 minutes Load-Bearing Composite
Divisions
S-series consisting of aluminium, steel or GRP frames (SFHM, SRC), filled with Roxtec halogen free RM modules and
assembled with Roxtec wedge kit. Frame installation method based on frame material, aluminium and steel frames are bolted
whereas GRP frames are laminated/glued onto the division.
R-series consisting of aluminium, steel or GRP sleeves, fitted with R frame and filled with Roxtec halogen free RM modules.
Sleeve installation method based on frame material, aluminium and steel frames are bolted whereas GRP frames are
RS-series consisting of aluminium, steel or GRP sleeves, fitted with RS or RS OMD seals. Sleeve installation method based on
frame material, aluminium and steel frames are bolted whereas GRP frames are laminated/glued onto the division.
RS PPS/S-series consisting of aluminium, steel or GRP sleeves, fitted with RS PPS/S seals with integrated intumescent
material. Sleeve installation method based on frame material, aluminium and steel frames are bolted whereas GRP frames are
Additional insulation on penetrations and/or cables/pipes:
  • should be approved as having the same level of performance as the penetrated division and expected classification of
penetration,
  • is to be fitted as shown in the referred Manufacturer’s drawings (see §2) and also according to Manufacturer’s insulation
guidelines.
1.1 – Penetration systems for 60 minutes Load-Bearing Composite Bulkheads
Service Filling Frame/
Seal type Size Sleeve type
[mm] position
| SLF R | S1582729 rev. A dated |
| R-series | 50 - 200 | Cables | Up to 82 | Max. | Any | 26/08/22 – ID 1 |
| Alu/Steel | 100 % |
S1582736 rev. A dated
R-series 50 - 200 SL GRP Cables Up to 82 Max. Any 26/08/22 – ID 1
100 %
SFHM S1582726 rev. A dated
S-series 1x1 - Cables Up to 82 Max. Any 29/08/23 - ID 1
8x1 Alu/Steel 100 %
SRC GRP S1582727 rev. A dated
S-series 4x1 – Cables Up to 90 Max. Any 26/08/22 – ID 1
6x1 100 %
SRC GRP S1582728 rev. A dated
S-series 4x1 – Steel pipes / 6 - 30 - Any 26/08/22 - ID 1
6x1 Titanium pipes
SLF RS S1582739 rev. A dated
RS-series 23 - 150 Steel pipes / 6 - 114 - Any 26/08/22 - ID 1-2
Alu/Steel Titanium pipes
RS-series 23 – 150 Copper pipes 6 - 108 - Any 26/08/22 - ID 3-4
Alu/Steel / Cu/Ni pipes
SLF RS S1582738 rev. A
RS-series 50 - 450 GRE pipes 30 - 360 - Any dated
Alu/S teel
26/08/22 - ID 1-2
S1582737 rev. A dated
RS-series 25 - 125 SL GRP Cables Up to 90 N/A Any 26/08/22 - ID 1
S1582740 rev. A
RS-series 25 - 150 SL GRP Steel pipes / 6 - 114 - Any dated
Titanium pipes 26/08/22 - ID 1-2
S1582740 rev. A dated
RS-series 25 - 150 SL GRP Copper pipes 6 - 108 - Any 26/08/22 - ID 3-4
/ Cu/Ni pipes
Service Filling Frame/Seal
Seal type Size
[mm]
RS PPS/S-series SLF RS
31 16
pipes*
Alu/Steel
SLF RS S1582741 rev. A dated
RS PPS/S-series 31 - 125
Alu/Steel
Thermoplastic S1582742 rev. A dated
RS PPS/S-series 50 - 150
pipes*
PE/Alu/PE S1582742 rev. A dated
RS PPS/S-series 50 - 125
pipes
*PP, PVC, PB, ABS, PE, PVDF
1.2 – Penetration systems for 60 minutes Load-Bearing Composite Decks
Seal type Size
[mm]
SLF R S1582729 rev. A dated
R-series 50 - 200
Alu/Steel 100 %
R-series 50 - 200
100 %
S-series 1x1 - 8x1
Alu/Steel 100 %
S-series 4x1 – 6x1
100 %
RS-series 23 - 150
RS-series 23 – 150
SLF RS S1582738 rev. A dated
RS-series 50 - 450
Alu/Steel
RS-series 25 - 125
RS-series 25 - 150
Titanium pipes
RS-series 25 - 150
/ Cu/Ni pipes
SLF RS Thermoplastic
RS PPS/S-series 31 - 150
Alu/Steel
Alu/Steel
PE/Alu/PE pipes S1582742 rev. A dated
2. DOCUMENTS AND DRAWINGS:
As per the Manufacturer’s insulation drawings quoted in tables in §1.
3. TEST REPORTS:
All as per IMO 2010 FTP Code, Annex1, part 3, from CTO laboratory, Poland.
3.1 - Bulkhead:
Test report Date
N° RS-20/B-253/E 09/07/2020
N° RS-20/B-426/E 23/11/2020
N° RS-20/B-417/E 19/01/2021
3.2 - Deck:
Test report Date
N° RS-20/B-254/E 04/08/2020
N° RS-20/B-341/E 22/10/2020
4. APPLICATION / LIMITATION:
4.1 - Restricted application (for bulkheads only): installation on board should be such as the insulated side of the 60 minutes
load-bearing composite bulkhead is exposed to the fire hazard.
4.2 - Approved for use in 60 minutes load-bearing composite bulkhead or deck with fire insulation as described in §1.
5.1 - The “A-60 Class Cable or Pipe Penetration System with Multidiameter Technology, in 60 minutes Load-Bearing
Composite Divisions” are to be supplied by ROXTEC International AB in compliance with the type described in this
certificate.
The product or packing is to be marked with Manufacturer name, type, designation and fire-technical rating.
7. OTHERS:
7.2 - Testing of the penetrations for gastightness and watertightness as per following inspection reports, witnessed by Third
Party surveyor (DNV):
Product Report Dated Performance
R frames N141XE2C 19/02/2020 Watertightness: 3 bars for 60 min
(sizes 50 & 200) Gas tightness: 1.5 bars for 30 min
RS seals N141XE2C 19/02/2020 Watertightness: 3 bars for 60 min
(sizes 25 & 200) Gas tightness: 1.5 bars for 30 min
RS PPS/S seals N142177N 01/09/2020 Watertightness: 3 bars for 60 min
(sizes 50 & 150) Gas tightness: 1.5 bars for 30 min
SRC R20 GRP N142846G 02/11/2021 Watertightness: 3 bars for 60 min
frame Gas tightness: 1.5 bars for 30 min
(sizes 4x1 & 6-1)
