I was reading some research from Roxtec’s EMC lab regarding HEMP (High-Altitude Electromagnetic Pulse) protection, and it really highlights a massive gap in how we build critical infrastructure. Most places rely on standard lightning
protection and call it a day, but that leaves us completely exposed to nuclear or weaponized EMPs.
The Problem with HEMP
An EMP doesn’t just hit once; it hits in three phases, and our standard defenses are completely useless against two of them.
- E1 (The Fast Pulse): This hits instantly and destroys microelectronics before standard lightning arrestors can even react.
- E2 (The Medium Pulse): This mimics lightning, which is the only phase our current surge protectors can handle.
- E3 (The Long Pulse): This lasts for minutes, distorts the magnetic field, and literally overheats/blows up transformers. It destroys the grid entirely.
There are also NNEMPs (Non-Nuclear EMPs) which can be triggered locally by drones or missiles, meaning you don’t need a nuke to achieve this effect on a specific target.
The Weak Link: Cables as Antennas
You can build a Faraday cage around your facility, but it means nothing if your penetrations aren’t shielded. Metallic cables and pipes act as literal antennas. They absorb the external EMP energy and pipe it straight through the walls
into the “protected” area.
To actually stop this, Roxtec notes that every single pipe and cable must have a 360-degree, low-impedance connection directly to the shield barrier at the entry point.
Discussion
Roxtec’s own lead engineer admitted they are trying to make their systems “easier to use,” which exposes the real issue: installation complexity.
- If a 360-degree ground is required at every single transit point, human error during installation almost guarantees a breach. One bad cable wrap compromises the whole building.
- How many data centers claiming to be “EMP resistant” are actually just running heavy E2 lightning protection, completely ignoring the E1 phase that will fry their servers anyway?
- Is it even feasible to retrofit standard infrastructure to survive this, or are we basically accepting that a localized NNEMP drone strike would be completely devastating?
