Can only select GK Firestop frame
When i try to add solution there is only GK firestop. We want to use the S frame
Hello Daan,
This happens if you have cable dimensions that wont fit into any of our modules.
The lowest supported diameter is 3mm / 3/32".
We have some 1,5mm cable, after removal it work. thanks
