CoFC_70181819_EN-optimized
Certificate of Compliance
Certificate: 2254189 Master Contract: 215242 (215242)
| Project: | 70181819 | Date Issued: | 2018-05-08 |
| Issued to: | Roxtec International AB |
Rombvägen 2
Karlskrona, 371 65
Attention: Jorgen Akesson
The products listed below are eligible to bear the CSA Mark shown
with adjacent indicators ‘C’ and ‘US’ for Canada and US or with adjacent
indicator ‘US’ for US only or without either indicator for Canada only.
Ravindra (Ravi) Kanthe
Issued by:
PRODUCTS
CLASS - C441805 - CABLE-Hardware - For Hazardous Locations
CLASS - C441885 - CABLE-Hardware-For Hazardous Locations-Certified to U.S. Standards
Canada: Ex e IIC Gb;
USA: Class I, Zone 1 AEx eb IIC Gb
PART A, CABLE TRANSIT DEVICE, ROUND EXPANSION FRAME, R…B Ex, (Sleeve bolted), RO…B Ex
(Sleeve bolted Openable frame), R…W Ex, (Sleeve welded), RO…W Ex (Sleeve welded Openable frame).
Rated -60°C to +80°C.
Modules RM Ex, RM PE Ex, RM PE B Ex, RM ES Ex and RM ES B Ex.
Type designation: IP66
PART B, CABLE TRANSIT DEVICE, ROUND SEAL, RS…B Ex (Self-contained Sleeve Bolted) and RS…W Ex
(Self-contained Sleeve Welded). Theses come in PE and ES versions and have (1) no bonding and
grounding. No separate grounding fastener/equipment, (2) Potential Equalization with Foil and (3)
Potential Equalization with Foil and Electro Magnetic Shielding with Conductive Rubber and come in
various diametric sizes.
DQD 507 Rev. 2016-02-18 Page 1
Project: 70181819
PART C, CABLE TRANSIT DEVICE, FRAME CF 8 Ex (Aluminum) and CF 32 Ex (Aluminum).
Rated -40°C to +80°C.
Modules CM Ex, CM PE Ex, CM ES Ex, CM BG Ex and CM BG B Ex.
PART C, CABLE TRANSIT DEVICE, FRAME CF 16 Ex (Mild Steel or Stainless Steel).
Modules CM Ex, CM PE Ex and CM ES Ex.
PART D, CABLE TRANSIT DEVICE, FRAME G…Ex, G BG Ex, G…W Ex, S…Ex, S…S0…Ex, SRC Ex,
S…WM Ex, SBTB Ex, SK Ex, SF…Ex, SF BG Ex, SFX…B Ex, SFX…B BG Ex and SF…W Ex (Steel,
Stainless Steel).
Modules RM Ex, RM PE Ex, RM PE B Ex, RM ES Ex, RM ES B Ex, RM BG Ex and RM BG B Ex
Type designation IP 66 is ONLY for FRAMES : G…Ex, G…W Ex, S…Ex, S…S0…Ex, SRC Ex, S…WM
Ex, SBTB Ex, SK Ex, SF…Ex, SFX…B Ex and SF…W Ex (Steel, Stainless Steel)
PART E, MODULES (Sealing Block)
Regular Ex Modules: (60mm deep):
RM Ex - Regular Module, no bonding and grounding or EMC Gnd.
RM PE Ex - Potential Equalization with Foil [Middle of block], 3 sectional layers
RM PE B Ex - Potential Equalization with Foil [Back of block], 2 sectional layers
RM ES Ex - Potential Equalization with Foil and Electro Magnetic Shielding with Conductive Rubber
[Middle of block], 2 sectional layers
RM ES B Ex - Potential Equalization with Foil and Electro Magnetic Shielding with Conductive Rubber
[End of block], 2 sectional layers
RM BG Ex - (formerly HC3) Bonding and Grounding with Braid [Middle of block], 3 sectional layers
RM BG B Ex - (Formerly HC2) Bonding and Grounding Braid [Back of block], 2 sectional layers
Compact Ex Modules: (30 mm or 40 mm deep)
CM Ex - Compact Module, no bonding and grounding or EMC Gnd., 30mm deep
CM PE Ex - Potential Equalization with Foil [Back of block], 2 sectional layers, 40mm deep
CM ES Ex - Potential Equalization with Foil and Electro Magnetic Shielding with Conductive Rubber
[Back of block], 3 sectional layers, 40mm deep
CM BG Ex - (formerly HC3) Bonding and Grounding with Braid [Middle of block], 3 sectional layers,
40mm deep
CM BG B Ex - (Formerly HC2) Bonding and Grounding Braid [Back of block], 2 sectional layers, 40mm
deep
DQD 507 Rev. 2016-02-18 Page 2
Project: 70181819
Canada: Ex tb IIIC Db
USA: Class II, Zone 21 AEx tb IIIC Db
CABLE TRANSIT DEVICE, FRAME G…Ex, G…W Ex, S…Ex, S…S0…Ex, SRC Ex,
S…WM Ex, SBTB Ex, SK Ex, SF…Ex, SFX…B Ex and SF…W Ex (Steel, Stainless Steel).
Modules RM Ex, RM PE Ex, RM PE B Ex, RM ES Ex, RM ES B Ex.
Note:
1) System environmental rating: 1, 2, 3, 3S, 3R, 4, 4X, 5, 12, 13 and IP66.
2) “…” can denote any alpha numeric character denoting configuration of gland assembly.
Conditions of Acceptability:
  1. The above listed cable transit devices have been certified as components and must be installed in
    accordance with the applicable local electrical code and final acceptance is subject to inspection by the
local authority having jurisdiction
  1. Cable Transit Devices to be approved as apparatuses concerning the following special conditions for safe
use:
DQD 507 Rev. 2016-02-18 Page 3
Project: 70181819
| - | For maintaining the explosion protection, the Assembly Instruction that accompanies the products, |
shall be considered.
- Only cable for fixed installation is permitted for the Cable Transit Device.
- The Cable Transit Device is ready for use not earlier than 24 h after being tightened according to the
Assembly Instruction.
  1. For Cable Transit Devices certified as a component of types S…Ex, S…S0…Ex, S…WM Ex, SBTB Ex,
    SK Ex and SF…W Ex) the following schedule of limitations apply:
  • For maintaining the explosion protection, the Assembly Instruction, which accompanies the
component, shall be considered.
  • Only cable for fixed installation is permitted for the cable transit device.
  • The Cable Transit Device is ready for use not earlier than 24 h after being tightened according to the
  • Compliance with applicable requirements not covered by the sub-clauses stated below shall be
    verified. This include mechanical test (if applicable) and test of degree of protection IP and/or Type,
    which shall be carried out on the frame of the Cable Transit Device (excluding modules and
    compression unit) after it has been welded (S…Ex, S…S0…Ex, S…WM Ex, SBTB Ex, SK Ex and
    SF…W Ex) on the enclosure of the apparatus subject to test and certification.
APPLICABLE REQUIREMENTS
CSA Standard C22.2 No 0-10 General Requirements - Canadian Electrical Code, Part II
CSA Standard C22.2 No 0.4-04 Bonding of Electrical Equipment
CSA Std. C22.2 No. 18.3-12 Conduit, Tubing and Cable Fittings.
CSA Std. C22.2 No. 94.1-07 Enclosures for Electrical Equipment, Non-Environmental
Considerations.
CAN-CSA C22.2 No. 60079-0: 15 Electrical Apparatus for Explosive Gas Atmospheres - Part 0 - General
requirements.
CAN-CSA C22.2 No. 60079-7: 12 Electrical Apparatus for Explosive Gas Atmospheres - Part 7 - Increased
Safety “e”.
CAN-CSA C22.2 No. 60079-31: 12 Explosive Atmospheres - Part 31: Equipment Dust Ignition Protection
by Enclosure “t”
UL Standard 514B (Sixth Edition) Conduit, Tubing and Cable Fittings.
UL Standard 50 (Twelfth Edition) Enclosures for Electrical Equipment, Non-Environmental
Considerations.
UL 60079-0 - 6th Ed. Electrical Apparatus for Explosive Gas Atmospheres - Part 0 - General
Requirements.
UL 60079-7 - 4th Ed. Electrical Apparatus for Explosive Gas Atmospheres - Part 7 - Increased
Safety “e”.
ANSI/UL 60079-31 (Ed. 1): 2013 Explosive Atmospheres - Part 31: Equipment Dust Ignition Protection by
Enclosure “t”
MARKINGS
Please refer MARKINGS section of Descriptive Report and Test Results for details.
DQD 507 Rev. 2016-02-18 Page 4
Supplement to Certificate of Compliance
The products listed, including the latest revision described below,
are eligible to be marked in accordance with the referenced Certificate.
Product Certification History
Project Date Description
| 70181819 | 2018-05-08 | Update report 2254189 to add Class II Zone 21 AEx tb IIIC Db and IP66 |
based on IECEx report NO/NEM/ExTR 12.0016/04 test data and results.
70051651 2016-02-25 Update to Report 2254189 to add two new components Roxtec Wedge 120
ES Ex and 60 ES Ex with 4 new drawings, 2 files on gasket and 5 installation
manual based on report ExTR:NO/NEM/ExTR12.0016/02 and numerous
other drawing revisions and editorial changes.
70049285 2015-12-09 Update to Report 2254189 to include 8 new models for CSA North America
rated for Class 1 Zone 1 AEx e IIC based on complete test data from IECEx
and ATEX reports ; assumes no testing is required. Additional funds will be
required if any testing is deemed necessary.
2628358 2013-06-05 Update report 2514543 to add the “Ex” descriptor to the various model
numbers for marketing purposes.
2514543 2012-10-16 Update report 2254189 to include alternative construction of RS…B,
RS…W, CF 16, new version of Cable Gland Type G…W, extensive report
formatting to add clarity and a change to the Class numbers which better suit
the product listing.
2385302 2011-01-17 Update of Report 2254189 to include HC-1 and HC-2 modules
2314839 2010-08-17 Update report 2254189 to include the omission of drawing S1008535, Rev C.
2254189 2009-12-23 HazLoc certification for Cable Glands RS… B, SF…, G…, CF…, and R…B
(apparatuses); RS…W, SF…W, R…W, S… and S…SO… (components) for
Class I, Zone 1; Ex e IIC; IP66/IP67 based on submitted IECEx report and
CSA ordinary location certification. The descriptive documents have been
changed to reflect these changes to stds C22.2 No. 0-M91; CSA C22.2 No.
18.3-04; CSA C22.2 No. 94.1-07; CSA E60079-0: 07; CSA E60079-7: 02;
UL 514B, 5th Ed.; UL 50, 12th Ed.; UL 60079-0, 4th Ed.; UL 60079-7, 2nd
Ed.
