COFC_80193903-optimized
Certificate of Compliance
Certificate: 1333944 Master Contract: 215242
| Project: | 80193903 | Date Issued: | 2024-05-02 |
| Issued to: | Roxtec International AB |
Rombvägen 2
Karlskrona, Blekinge County 371 65
Attention: Per Kask
The products listed below are eligible to bear the CSA Mark shown with adjacent
indicators ‘C’ and ‘US’ for Canada and US or with adjacent indicator ‘US’ for US
only or without either indicator for Canada only.
Issued by:
Ethan Poopalasingam
Ethan Poopalasingam
PRODUCTS
Class 4411 01 OUTLET BOXES AND FITTINGS - Boxes
Class 4411 81 OUTLET BOXES AND FITTINGS - Boxes - Certified to US Standards
Class 4414 04 FITTINGS - Grounding and Bonding Equipment
Class 4414 84 GROUNDING AND BONDING DEVICES - Certified to US Standards
CLASS 4411 01 ‑ OUTLET BOXES AND FITTINGS ‑ Boxes
CLASS 4411 81 - OUTLET BOXES AND FITTINGS - Boxes - Certified to US Standards
Fitting Kits, Compact Kit Solutions (frame, modules)
Model(s) Environmental Rating
| EzEntry 4 Mini | Types 12, 13 |
| QD-1397 Rev 2019-04-30 | © 2024 CSA Group. All rights reserved. | Page 1 |
| Certificate: 1333944 | Master Contract: 215242 |
| Project: 80193903 | Date Issued: 2024-05-02 |
Fitting Kits, Compact Kit Solutions (frame, modules, integral compression)
| ComSeal 12 LW, ComSeal 16 LW, ComSeal 6 LW | Type 3R |
| ComSeal 10, ComSeal 10 AISI 316, ComSeal 12, ComSeal 15, ComSeal 16, ComSeal 16 AISI 316, | Type 3, 12, 12K |
ComSeal 30, ComSeal 32, ComSeal 32 AISI 316
EzEntry 4, EzEntry 10, EzEntry 16, EzEntry 24, EzEntry 32, CF 8, CF 16, CF 24, CF 24 F1, CF 32 Types 1, 2, 3, 3R, 3S, 4, 4X, 5, 12,
13, IP66
C RS T 25, C RS T 31, C RS T 43, C RS T 50, RG M63 Types 1, 2, 3, 3R, 3S, 4, 4X, 5, 12,
13, IP66, IP67
Compact Kit Solutions (frame, modules, compression unit, stayplates)
| Models HD 16, HD 16 Ex, HD 24, HD 24 Ex, HD 32, HD 32 Ex, HDLC, HDLC Ex | Types 1, 2, 3, 3R, 3S, 4, 4X, 5, 12, 13, IP66. |
Standard (frame, modules, compression unit, stayplates)
G, GH, GHM, GO, GOH, S, SBTB, Types 1, 2, 3, 3R, 3S, 4 (except Wedge 60 galv, Wedge 120 galv compression units), 4X (except
SF, SFH, SFHM, SFH CFL 30 Wedge 60 galv, Wedge 120 galv compression units), 5, 12, 13, IP66, IP67.
Round System
| R, RX, RS, RS OMD, RSX | Types 1, 2, 3, 3R, 3S, 4, 4X, 5, 12, 13, IP66, IP67. |
CLASS 4414 04 - GROUNDING AND BONDING DEVICES
CLASS 4414 84 - GROUNDING AND BONDING DEVICES - Certified to US Standards
Grounding and Bonding Compact Kit Solutions
CF 8 BG, CF 32 BG, HD 16 BG, HD 16 BG Ex, HD 24 BG, HD 24 BG Ex, HD 32 BG, HD 32 BG Ex, Types 1, 2, 3, 3R, 3S, 4, 4X, 5,
HDLC BG, HDLC BG Ex, SFH CFL 30 12, 13, IP66.
| QD-1397 Rev 2019-04-30 | © 2024 CSA Group. All rights reserved. | Page 2 |
Grounding and Bonding Frames
| B, B BG, G, G BG, GH, GH BG, GHM, GHM BG, GO | Types 1, 2, 3, 3R, 3S, 4 (except Wedge 60 galv, Wedge 120 galv compression |
| BG, GOH BG, RS BG, S, SBTB, SF, SF BG, SFH BG, | units), 4X (except Wedge 60 galv, Wedge 120 galv compression units), 5, 12, |
| SFHM BG | 13, IP66 |
APPLICABLE REQUIREMENTS
CSA C22.2 NO. 18.3: 12 +Upd.1+Upd.2 (Second Edition) (R2022) - Conduit, tubing, and cable fittings
CSA C22.2 NO. 41: 22 (Seventh Edition) - Grounding And Bonding Equipment
CSA C22.2 No. 94.2: 20 (Third Edition) - Enclosures for electrical equipment, environmental considerations
CAN/CSA C22.2 NO. 60529: 16 (Second Edition) - Degrees of protection provided by enclosures (IP Code)
UL 50E (Third Edition) - UL Standard for Safety Enclosures for Electrical Equipment, Environmental Considerations
UL 467 (Eleventh Edition) - Grounding and Bonding Equipment
ANSI/UL 514B (Sixth Edition) - UL Standard for Safety Conduit, Tubing, and Cable Fittings
ANSI/IEC 60529-2020 Edition 2.0 - Degrees of protection provided by enclosures (IP Code)
QD-1397 Rev 2019-04-30 © 2024 CSA Group. All rights reserved. Page 3
Project: 80193903 Date Issued: 2024-05-02
Notes:
Products certified under Class(es) C441484 have been certified under CSA’s ISO/IEC 17065 accreditation
with the American National Standards Institute (ANSI). www.ansi.org
Products certified under Class(es) C441101, C441404 have been certified under CSA’s ISO/IEC 17065
accreditation with the Standards Council of Canada (SCC). www.scc.ca
QD-1397 Rev 2019-04-30 © 2024 CSA Group. All rights reserved. Page 4
Supplement to Certificate of Compliance
The products listed, including the latest revision described below,
are eligible to be marked in accordance with the referenced Certificate.
Product Certification History
Project Date Description
80193903 2024-05-02 Current standards verification.
| 80173710 | 2024-01-11 | Models C RS T 25, C RS T 31, C RS T 43, C RS T 50, RG M63, G, GH, GHM, GO, |
GOH, R, RX, RS, RS OMD, RSX, S, SBTB, SF, SFH, SFHM, SFH CFL 30, B, B BG, G
BG, GH BG, GHM BG, GOH BG, RS BG, SF BG, SFH BG, SFHM BG add an IP67
rating.
80117197 2022-08-18 Add Grounding and Bonding Frames Model RS BG.
| 80089648 | 2021-07-09 | Grounding Fitting Kits Components Models CX BG, RX BG B alternate half core |
construction.
80074154 2021-03-05 Add modules Models RMX, RX BG B.
| 80058670 | 2020-11-06 | Add Fitting Kit compact kit solutions frames Models SFHM, SFHM BG. |
| 80026271 | 2020-03-11 | Add Fitting Kit compact kit solutions frames Models HDLC, HDLC Ex, HDLC BG, HDLC |
BG Ex.
80007470 2019-08-30 Add Fitting Kit compact kit solutions frames HD 16, DH 16 Ex, HD 16 BG, DH 16 BG Ex.
| 70130521 | 2017-04-05 | Models ComSeal 6 LW, ComSeal 12 LW, ComSeal 16 LW revised Type 3R Environmental |
rating.
70097222 2016-09-15 Add Frames Models GH, HD 24, HD 24 Ex, HD 32 Ex.
| 70092600 | 2016-09-01 | Add IP66 Environmental ratings. |
| 70089157 | 2016-07-15 | Add Frames Modes S, SBTB, SF. |
| © 2024 CSA Group. All rights reserved. | Page 5 |
| 70029412 | 2015-06-05 | Alternate grounding construction. |
| 70018541 | 2015-03-27 | Add modules BG C, BRM 80, HD 20w40, HD 30w40, HD 40 10-32, RM 80 BG, RM 80 |
BG; Grounding Fitting Kits B BG, G BG, GHM BG, GOH BG, HD 32 BG; cabinet seal HD
32.
2759260 2014-09-30 Add standard kit Model SBTB.
| 2600316 | 2013-10-17 | Model CF 32 one alternate gasket material; Model RG M63 one alternate frame material; |
add Models CF 24, CF 24 F1, C RS T25, C RS T 31, C RS T 43, C RS T 50, EzEntry 4
mini.
2421568 2011-05-02 Model CF-16 new frame enamel material.
| 2419565 | 2011-04-27 | Designation change to Models BG, BG B, BG C and comply with bonding classes 4414 |
04/84.
2403197 2011-04-19 Witness testing of Modules Series BG, BG B, BG C.
| 2390237 | 2011-01-19 | Add bonding module Model HC3. |
| 2350470 | 2010-10-03 | Add bonding modules Models HC1, HC2 for Bonding kits Models S, SF, G, GHM, GO, |
CF-8, CF-16, CF-32.
2282260 2010-04-21 Add cable sealing kits EZ Entry 4, 10, 16, 24, 32.
| 2223319 | 2009-12-10 | Add standard kits Models S, SF, G, GHM, GO; Round kits Models R, RS, RS OMD, RX, |
RSX.
© 2024 CSA Group. All rights reserved. Page 6
