Design the Pipes Plastic conduits
Hello, Happy New Year.
I would like to ask if we can design the Pipes and Plastic conduits using an Excel file.
When I input the information using the uploaded excel file, only cable is available.
Maybe it’s something I’m not sure about but also the multiple transfer template name is an electrical cable export to Roxtec, so I think only cable can use Excel.
For pipes, I think it can be more difficult because we have to consider both Pipe ID and OD as per cases.
Could you please check it?
Thanks
Hi Junghye,
No you are right, the multi import & export only support cables right now.
We are going to make some improvements to this in the future, meanwhile conduits and pipes has to be handled in the regular cable, pipe & conduits in the application.
Thank you for the feedback.
