CERTIFICATE OF FIRE APPROVAL
This is to certify that
The product detailed below will be accepted for compliance with the applicable Lloyd’s Register Rules and
Regulations and with the International Convention for the Safety of Life at Sea, (SOLAS), 1974, as amended, for
use on ships and offshore installations classed with Lloyd’s Register, and for use on ships and offshore
| Address | Box 540 |
S-371 23 Karlskrona
| Type | PIPE PENETRATION (STANDARD FIRE TEST) |
| Description | Fire Resisting Pipe Penetration Seals – Type: “RS and RS OMD” for applications in |
Aluminium Bulkheads and Decks
| Specified Standard | IMO Res. MSC.61 (67)- (FTP Code) Annex 1 Part 3 |
| IMO MSC/Circ.1120 | |
| IMO Res. MSC.307 (88)-(2010 FTP Code) Section 8 |
| Date of issue | 15 December 2015 | Expiry date 14 December 2020 |
| Certificate No. | SAS F160063 | Signed |
Fire & Safety, MTES
Lloyd’s Register EMEA
LR427.2013.12
| Sheet No | 1 of 3 | Name | B. Geary |
| Surveyor to Lloyd’s Register EMEA | |||
| A Member of the Lloyd’s Register Group |
Note:
This certificate is not valid for equipment, the design or manufacture of which has been varied or modified
from the specimen tested. The manufacturer should notify Lloyd’s Register of any modification or changes to
the equipment in order to obtain a valid Certificate.
Page
2 of 3
| 71 Fenchurch Street, London, EC3M 4BS | Document number |
| Telephone 020 7423 2416 Fax 020 7423 2053 | SAS F160063 |
| Email med@lr.org | Issue number |
| 1 |
DESIGN APPRAISAL DOCUMENT
| Date | Quote this reference on all future communications |
| 12 February 2016 | MTES/SFS/TA/BG/WP24838242 |
ATTACHMENT TO CERTIFICATE OF TYPE APPROVAL No. SAS F160063
APPROVAL DOCUMENTATION
SINTEF Norwegian Fire Research Laboratory, Fire Test Report Nos. 103070.03B and 103070.03A both dated
15 March 2001, No: 103070.33A dated 15 November 2004; SP Fire Test Laboratory, Boras, Sweden, Fire Test
Report No. P403634, dated 30 December 2004.
Roxtec drawings no: S1002247 Rev. A dated 11 March 2011, S1002249 Rev. B dated 11 March 2011 and
S1007913 dated 24 May 2005.
| 1. | When used in conjunction A-60 aluminium bulkheads and decks with approved insulation |
| arrangements. Aluminium bulkheads and decks in all cases must be insulated with an approved | |
| system to prevent the core temperature exceeding 2000c and all penetrations fitted to such divisions | |
| must also be insulated with either the same system or an approved A-60 system | |
| 2. | Insulation arrangements for penetrations in aluminium divisions are to be in accordance with Roxtec |
| drawings no: S1002247 Rev. A dated 11 March 2011, S1002249 Rev B dated 11 March 20011 and |
| 3. | Consists of: Roxtec Seal frame types: RS/RS OMD in sizes 23 to 150, fitted around pipes and |
| enclosed in types: SLRS/SLXRS sleeves made of steel or aluminium that are bolted or welded to the | |
| aluminium division respectively. For deck applications, aluminium sleeves are to be fitted to the | |
| topside (non-fire exposed side) of the deck in all cases | |
| 4. | Permissible copper pipe outside diameter range: 10mm to 118mm |
| 5. | Permissible steel pipe outside diameter range: 10mm to 114mm |
| 6. | Production items are to be manufactured in accordance with a quality control system which shall be |
| maintained to ensure that items are of the same standard as the approved prototype |
NOTES
A Type RS-23/OMD and Type RS-150/OMD pipe penetrations were subjected to a hydrostatic test (6
bar) and gas-tightness test (4 bar) for 30 minutes without any leakage, as witnessed by an IACS Surveyor
and as indicated in DNV Certificate No. MLM 020106 dated 19 December 2001.
Page
3 of 3
| 1 |
371 23 Karlskrona
Fire & Safety, MTES
LR427.2013.12
Ben Geary
Technical Manager
Statutory Fire & Safety
