Doc_75521_1-optimized
CERTIFICATE OF FIRE APPROVAL
This is to certify that
The product(s) detailed below will be accepted for compliance with the applicable Lloyd’s Register Rules and
Regulations for use on offshore installations classed with Lloyd’s Register, and for use on offshore installations
when authorised by contracting governments to issue the relevant certificates, licences, permits etc.
| Address | Box 540 |
S-371 23 Karlskrona
Type CABLE PENETRATION (HYDROCARBON FIRE TEST)
| Equipment Description | Fire Resisting Single/Multi Cable Penetration (Circular) for H-0 (400°C) Structural |
Bulkheads– Type: “RS-23 to RS-125” (36mm to 138mm sleeve diameter) R-70 to R-200
(79mm to 220mm sleeve diameter)
Specified Standard IMO Resolution A.754(18)
NPD Hydrocarbon Time/Temperature Curve
Date of issue 7 March 2016 Expiry date 6 March 2021
| Certificate No. | SAS F160136 | Signed |
Fire & Safety, MTES
Lloyd’s Register EMEA
LR427.2013.12
Sheet No 1 of 3 Name S. Abraham
Surveyor to Lloyd’s Register EMEA
A Member of the Lloyd’s Register Group
Note:
This certificate is not valid for equipment, the design or manufacture of which has been varied or modified from
the specimen tested. The manufacturer should notify Lloyd’s Register of any modification or changes to the
Page
2 of 3
71 Fenchurch Street, London, EC3M 4BS Document number
Telephone 020 7423 2416 Fax 020 7423 2053 SAS F160136
Email med@lr.org Issue number
2
DESIGN APPRAISAL DOCUMENT
Date Quote this reference on all future communications
8 July 2016 SOUTSO/SFS/TA/SA/WP25742200
ATTACHMENT TO CERTIFICATE OF TYPE APPROVAL No. SAS F160136
APPROVAL DOCUMENTATION
SINTEF Energy, Norwegian Fire Research Laboratory, Norway, Fire Test Report No. 22N007.12C, dated 16
September 1999.
1. When used in conjunction with H-0(400c) Class insulated structural steel bulkheads with a maximum
steel core temperature requirement of 400°C after 120 minutes duration
2. Consists of: Roxtec circular steel frames filled with Roxtec RM Modules around the cables and welded
to the non-fire exposed side of the bulkhead. The fire exposed side of the bulkhead shall be insulated
with an approved system and insulation extended to fully cover the face of the transit frame on the fire
exposed side
3. For applications in H-0 Class steel bulkheads (with no specified temperature criteria), penetrations are
to be fitted with the same or equivalent insulation arrangements as those used in the fire tests
(including any insulation fitted on the penetration itself in the tests) for a minimum distance of 450mm
around the penetration, on all fire risk sides in bulkheads and insulation should be extended to cover
the full side(s) and the end face(s) of the steel frame, with an overlap of at least 20mm from the steel
edges. The above mentioned insulation arrangements should be additional to any thermal or acoustic
insulation, but may include any fire rated insulation already fitted on the bulkhead and/or on the
penetration itself, such that the total fire rating is equivalent to the arrangements tested
4. Tested frame sizes: “RS-23 to RS-125” (36mm to 138mm sleeve diameter) “R-70 to R-200” (79mm to
5. Production items are to be manufactured in accordance with a quality control system which shall be
maintained to ensure that items are of the same standard as the approved prototype
NOTE
A type R-50 and R-70 cable penetrations were subjected to a hydrostatic pressure test on 4 June 1992 of 8 bar
for 30 minutes without any leakage, as detailed in DNV Certificate No. E-4281, dated 27 August 1996.
Page
3 of 3
2
S-37123 Karlskrona
Fire & Safety, MTES
LR427.2013.12
Saji Abraham
Senior Specialist
Statutory Fire and Safety
