| 中国船级社 | 证书编号/Certificate No. |
| CHINA CLASSIFICATION SOCIETY | GB23PTB00036_01 |
型式认可证书
CERTIFICATE OF TYPE APPROVAL
兹证明本证书所述制造厂具备按照下列标准的要求生产本证书所列产品的能力和条件。
This is to certify that the manufacturer stated in the certificate meets the requirements of the standards listed below and is available
with the ability and conditions to produce the products described in the certificate.
制造厂/Manufacturer
地址/Address
Box 540,S-37123 Karlskrona,Sweden
产品名称/Product
电缆贯穿装置
Cable Transits
附加标志/Notations
无/Nil.
认可标准/Approval Standard
1.1974年SOLAS公约及其修正案第II-2章第3条和第9条
Regulations 3 and 9, Chapter II-2 of 1974 SOLAS Convention, as Amended
2.IMO 2010年FTP规则附件1第3部分
IMO 2010 FTP Code Annex One Part Three
用于/Intended for
船舶/Ships
产品明细/Product Description
电缆贯穿装置/Cable Transits (M0001)
| 名称/Name | 属性(值)/Value | 单位/Unit |
| 规格/Specification | 详见附页/See additional page(s) | |
| 电缆占据率/Cable Spacing Factor | 详见附页/See additional page(s) | % |
| 密封填料/Sealing | 详见附页/See additional page(s) | |
| 密封堵料/Caulking | 详见附页/See additional page(s) | |
| 气密性/Airtight | 详见附页/See additional page(s) | mbar |
| 水密性/Watertight | 详见附页/See additional page(s) | bar |
| 证书有效期至/This Certificate is valid until | 2026年11月13日/ Nov. 13,2026 |
| 发证机构 中国船级社哥德堡办事处 | 签发日期 2023年10月06日 |
| Issued by CCS Gothenburg Office | Date Oct. 06,2023 |
本证书根据中国船级社规范和相关规定签发。所有证书页为一个整体,必须同时使用。纸质证书每页均须由本社盖章方为有效,电子证书含数字签名方
为有效,本证书复印件无效。任何单位和个人均不应摘录或节选本证书的部分内容。有关方对所持证书的真实性有疑问时,可以向我社检验机构咨询。
This Certificate is issued pursuant to the Rules of the Society and related regulation. All pages of the certificate are taken as a whole and are used simultaneously. No
paper certificate page is valid without bearing the stamp of the Society, no electronic certificates is valid without the digital signature, and no copied form of the
certificate is regarded as valid. Any part of the certificate is not to be extracted or abridged by any unit or individual in any form. Related parties who are doubted
about the authenticity of the certificate may inquire of the Society or its offices.
| Form No: T01. | 联系方式/Contact Us,见本社官方网站/See official web site of the Society(http://www.ccs.org.cn) | UTN:P023-29565977 |
| 第1页共3页/Page 1 of 3 | ||
| 证书编号/Certificate No. GB23PTB00036_01 |
舱壁电缆贯穿耐火等级/受火面/Fire Class
of Bulkhead Cable Transits /Exposed Face
甲板电缆贯穿耐火等级/受火面/Fire Class
of Deck Cable Transits /Exposed Face
批准的图纸/Approved Drawings
图纸批准号/ Drawings Approval No. : 详见附页/See additional page(s)
产品认可试验报告/ Approval Test Report
试验报告编号/ Test Report No. : 详见附页/See additional page(s)
试验报告日期/ Test Report Date :
试验单位/ Laboratory: 详见附页/See additional page(s)
试验单位地址/ Test Address: 详见附页/See additional page(s)
认可后的产品检验方式/ Method of Product Inspection after Approval
按规范只认可不进行产品检验的产品/The product approved only in term of the rules:
认可后的产品检验由制造厂按本社批准的产品检验计划进行检验,经检验合格后由制造厂签发合格证明,并连同该
产品的本社认可证书复印件一并交付用户,制造厂对产品符合公约、法规、本社规范和本社认可的标准规定负责。
After approval, product inspection should be carried out by the Manufacturer in accordance with the
product inspection scheme approved by the Society. Upon satisfactory inspection, and the Quality
Certificate issued by the Manufacturer should be provided to the purchaser together with the copy of
the approval certificate issued by the Society. The manufacturer should take responsibility for the
product being in compliance with the convention, statutory regulation, the Society rules and the
standard accepted by the Society.
认可保持条件/ Maintenance Requirements of Approval
1.型式认可后,如果产品及其重要零部件的设计、所用材料或制造方法有所改变,且影响到产品的主要特性、特
征;或产品的性能指标有所更改,且超过认可的范围,则有关图纸和文件应经检验机构审批。并在检验机构认为必
要时,经本社检验人员见证有关试验和进行检查,其结果应能证实仍符合认可条件。
After type approval, if there are changes to the design, materials used or manufacturing method of
the product and important components and such changes affect major characteristics and properties of
the product, or property indexes of the product are changed and exceed the scope of approval,
related drawings and documents are to be examined and approved by the concerned survey office. Where
deemed necessary by the survey office, the surveyor to the Society will go to witness relevant tests
and conduct inspection and the results should be able to demonstrate compliance with the approval
conditions.
2.工厂的质量管理体系应保持有效运行,并且与认可时一致。如果质量管理体系发生改变,应经原体系认证机构审
核并报本社批准。
The quality management system of the factory shall be ensure effective operation, and shall be the
same as the situation of approval. If there are any changes to the quality management system,
auditing of the original certification organization for quality management system and the society’s
approval shall be obtained.
3.认可证书有效期内,如果出现可能导致本社取消认可的情况,工厂应及时采取有效的纠正措施。
Within the validity of the approval certificate, if cases occur that may cause the Society to
withdraw the approval, the manufacturer should take corrective actions in a prompt and effective
manner.
4.在认可证书有效期内,本社检验人员可在未经事先通知的情况下对工厂的产品制造过程进行审核,以验证产品的
生产是否符合业经本社批准的图纸和文件。工厂应予以配合。
Within the validity of the approval certificate, the surveyor to the Society may pay unannounced
audit to the manufacturing process of the product in order to confirm whether it is in compliance
with the drawings and documents approved by the Society. The factory should provide an active
cooperation and necessary for the surveyor.
5.如果属于获得型式认可B 模式证书,且无需颁发船用产品证书/等效证明文件的情况,证书获得者应接受本社每
年一次的定期审核,定期审核日为认可证书期满之日对应的每一周年日,检查工作应在周年日的前后三个月内进
行。
If belong to the situation of the product has type approval mode B certificate, and marine product
certificate/equivalent document is not necessary, those who have obtained the certificate should be
subject to periodical audit every year. The date of periodical audit shall be each anniversary date
which corresponds to the date of expiry of the relevant certificate and the periodical audit shall
be done within a time span of three months before and after the annual surveillance date.
第2页共3页/Page 2 of 3
备注/Remarks
1. 本社已审核了产品厂无石棉声明,但本社的审核不免除产品厂按照合同关系向订货方保证产品无石棉的责任。
The declaration of asbestos-free submitted by manufacturer has been reviewed by the Society.
However, liability of the manufacturer to guarantee the products are asbestos-free to purchaser
under contract will not be exempted.
2. 本证书由原型式认可证书(No. GB22PTB00041_01)变更并替代原证书。
This Certificate is modified from and supersedes the previous Type Approval Certificate No.
GB22PTB00041_01.
3. This cert was issued to Roxtec International AB.
Besides production site at Karlskrona, Sweden, Roxtec Sealing System (Shanghai) Co., Ltd (address:
Ground floor, Building A, No. 875 Qiuxin Road, Lingang Nicheng Industrial Area, Pudong District
Shanghai, P.R.China) is the assessed production site for the following components of the approved
products:
R-series: Sleeve
RS-series: Sleeve
S-series: Frame, Stayplates
G-series: Frame Stayplates
4. 本证书认可产品应根据制造厂安装手册和批准图纸安装。
The approved products shall be installed as per the manufacuter’s installation instructions and the
approved drawings.
中国船级社哥德堡办事处
注:本证书含有附页,共11页
Note: The certificate is attached with additional 11 page(s)
第3页共3页/Page 3 of 3
| 证书编号/Certificate No.:GB23PTB00036_01 | 附页/Additional Page |
产品明细
Product Description
电缆贯穿装置
产品名称/Product name
Cable transits
| 型号/Type | S Series | R Series | RS Series | G Series | GK FS SK |
规格
| See “Detailed Parameters” | See “Detailed Parameters” | See “Detailed Parameters” | See “Detailed Parameters” | See “Detailed Parameters” |
| Specification |
图纸批准号
| GB17A00007, NP18A01797 | GB17A00007, NP18A01797 | GB17A00007, NP18A01797 | NP23PPP00217 | HB20PPP20003 |
| Drawings approval No. | ||||
| 界面(甲板/舱壁)材质 | aluminum/steel | aluminum/steel | aluminum/steel | steel |
| Material of divisions(deck/bulkhead) | Bulkhead and Deck | Bulkhead and Deck | Bulkhead and Deck | Bulkhead and Deck |
| 贯穿装置与舱壁或甲板连接方式 | 焊接/welded | |||
| 焊接/welded | 焊接/welded | 焊接/welded | ||
| Connection method of penetration device | 螺栓链接/bolted | |||
| 螺栓链接/bolted | 螺栓链接/bolted | 螺栓链接/bolted | ||
| to bulkhead or deck | Attached by expansion (SLFR X & SLFRS X) or with a nut (SLA) | |||
| 0% to max 68% (Recommended | ||||
| 电缆占据率 | maximum cable density), the cable | |||
| 0% to max 44% | 0% to max 44% | 0% to max 60% | 0% to max 44% | |
| Cable spacing factor | bundle shall be arranged in the | |||
| center of the sleeve. | ||||
| Sealing strip and Straps | ||||
| Strip: Armacell | ||||
| Straps: Ahlsell | ||||
| 密封填料 | Fiberglass Cloth | |||
| Roxtec EPDM Rubber | Roxtec EPDM Rubber | Roxtec EPDM Rubber | Roxtec EPDM Rubber | Fiber glass: Klevers, manufactured |
| Sealing | ||||
| by Klevers GmbH&Co.KG | ||||
| Intumescent material: | ||||
| PROMASEAL-PL, manufactured by | ||||
| Promat GmbH | ||||
| Sealant |
密封堵料
| No Caulking | No Caulking | No Caulking | No caulking | Generic smoke-tight marine grade |
| Caulking | ||||
| sealant |
框架或套筒材料
| aluminum/steel | aluminum/steel | aluminum/steel | steel | steel |
| Material of frame or sleeve |
框架或套筒包覆用隔热材料
| Insulation material bundled for frame or | A-60 approved type | A-60 approved type | A-60 approved type | A-60 approved type | A-60 approved type |
| sleeve |
| 证书编号/Certificate No.:GB23PTB00036_01 | 1/11 |
舱壁贯穿耐火等级/受火面
| Fire class of bulkhead transits /Exposed | See “Detailed Parameters” | See “Detailed Parameters” | See “Detailed Parameters” | See “Detailed Parameters” | See “Detailed Parameters” |
| face |
甲板贯穿耐火等级/受火面
| Fire class of deck transits/Exposed face | ||||
| 试验前试样空气试验压力(气密性) | Bolted:1.67 bar | Bolted:1.67 bar | Bolted:1.67 bar | Bolted:1.67 bar |
| Pressure of air before test | Welded:2.67 bar | Welded:2.67 bar | Welded:2.67 bar | Welded:2.67 bar |
| specimen(Airtight) | Long sleeves: 1 bar | Long sleeves: 1.5 bar | ||
| 试验前试样液压试验压力(水密性) | Bolted:3.33 bar | Bolted:3.33 bar | Bolted:3.33 bar | Bolted:3.33 bar |
| Pressure of hydraulic before test | Welded:4 bar | Welded:4 bar | Welded:4 bar | Welded:4 bar |
| specimen(Watertight) | ||||
| Long sleeves: 2 bar | Long sleeves: 3 bar | |||
- Approved for cable transition in decks or bulkheads with “A” class divisions (including A-0, A-15, A-30, A-60). For A-15 and A-30 applications,
the penetration shall be insulated as for A-60 and the division is to be fitted with A60 insulation for a minimum distance of 200 mm around the
使用限制
penetration.
Installation limitation
- Not for use in tank boundaries.
- More details please refer to “Detailed parameters”
| 应用型式/Application Type | See “Detailed Parameters” | See “Detailed Parameters” | See “Detailed Parameters” | See “Detailed Parameters” | See “Detailed Parameters” |
| 证书编号/Certificate No.:GB23PTB00036_01 | 2/11 |
Detailed Parameters
1. S series
1.1 Product specifications
Roxtec sealing system with multidiameter
technology, S-series consists of Roxtec S-series frames with a
depth of 60 mm (S, S Ex, SF, SFHM, SO, SFO, SFOH, SR/T, SR/S, SRC r20, SRC r40, SRC r60) in height 1-8
and width 60-120, and combinations thereof, welded or bolted to the steel/aluminum sections. Also included in
the S-series is the subgroup of SK-series frames with a single barrier with a depth of more than 60 mm (SK, SK
Ex, SFK, SFOK, SFOHK, SRCK r20, SRCK r40, SRCK r60) and a subgroup SBTB-series frames with two
barriers (SBTB, SBTB Ex, SFBTB, SRBTB, SRCBTB r20, SRCBTB r40, SRCBTB r60).
The S-series (including subgroups) is filled with Roxtec halogen free RM modules (*1. & *2.). Assembled with
Roxtec Wedge, Roxtec ES Wedge, Roxtec Ex Wedge or Roxtec ES Ex Wedge and corresponding stayplates.
*1. Standard RM, RM Ex, RM PPS, RM FOC, RM ES, RM ES B, RM PE, RM PE B, RM BG, RM BG B, RM
ES Ex, RM ES B Ex, RM PE Ex, RM ES B Ex , RM BG Ex, RM BG B Ex
*2. RMX, RX BG, RX BG B.
1.2 Application limitation
a) Watertight bulkheads or decks are to be tested as per CCS Rules for Classification of Sea-going Steel Ships.
b) When requested to be used in watertight bulkheads on passenger ships or special purpose ships, the
penetration system has to comply with the requirements give in SOLAS Ch.11-1 Reg. 13.2.3 (2014
Consolidated Edition or latest issue).
c) This approval of penetrations passing through watertight bulkhead is not to be construed as a substitute for
flag Administration’s approval for the purpose of SOLAS 1974 as amended.
S-series
Application for (Std & CLX) cables and fiber optic conduits in terms of deck and bulkhead.
| Type & Size | Type of | Division | Type of | Max. cable | Frame | Frame | Frame insulation |
| frame | cable | diameter | Length and | Drawing No. | |||
| [mm] | thickness | position | |||||
| [mm] | |||||||
| S series | Std | A60 Aluminum | Std | 90 | Length: 60 | All positions | S1581136 Rev A |
| 1-8 combination | Bulkhead/Deck | Thickness: 10 | |||||
| thereof. | SFOHK A60 Steel | Std & FOC Std: 82 | Length: | Unexposed | S1581774 Rev A | ||
| Bulkhead/Deck | FOC: 18 | 100-200 | |||||
| Thickness: 10 | |||||||
| SFOHK A0 Steel | Std & FOC Std: 82 | Length: | Unexposed | S1581775 Rev A | |||
| Std | A60 Steel | CLX | 98 | Length: 60 | All positions | S1581776 Rev A | |
| Bulkhead/Deck | Thickness: 10 | ||||||
| Std | A0 Steel | CLX | 98 | Length: 60 | All positions | S1581777 Rev A | |
| Std | A60 Steel | Std & FOC Std: 90 | Length: 60 | All positions | S1581778 Rev B | ||
| Bulkhead/Deck | FOC: 18 | Thickness: 10 | |||||
| Std | A0 Steel | Std & FOC Std: 88 | Length: 60 | All positions | S1581779 Rev A | ||
| SFOHK A60 Steel | CLX | 60 | Length: | Unexposed | S1581780 Rev B | ||
| Deck | 100-200 | ||||||
| Thickness: 10 |
| 证书编号/Certificate No.:GB23PTB00036_01 | 3/11 |
| SFOHK A0 Steel | CLX | 60 | Length: | Unexposed | S1581781 Rev B |
| Deck | 100-200 |
Thickness: 10
| SBTB | A60 Steel | Std & FOC Std: 82 | Length: | All positions | S1582132 Rev A |
| Bulkhead/Deck | FOC: 18 | 200-400 | |||
| SBTB | A0 Steel | Std & FOC Std: 82 | Length: | All positions | S1582134 Rev A |
| SK | A60 Steel | Std & FOC Std: 82 | Length: | Unexposed | S1582129 Rev A |
| SK | A0 Steel | Std & FOC Std: 82 | Length: | Unexposed | S1582133 Rev A |
| SK | A60 Steel | CLX | 60 | Length: | Unexposed |
| SK | A0 Steel | CLX | 60 | Length: | Unexposed |
| SBTB | A60 Steel | CLX | 60 | Length: | All positions |
| Bulkhead/Deck | 200-400 | ||||
| SBTB | A0 Steel | CLX | 60 | Length: 200- | All positions |
| Bulkhead/Deck | 400 | ||||
| Thickness: 10 |
| Note 1: Type of frame | Note 2: Type of cable |
| Std | Standard Frame |
| SFOHK | SK frame with openable bolted flange |
| SBTB | Back-to-back frame |
| SK | Standard frame with extended depth |
1.3 list of type test reports
| Division | Division | Fire |
| No. | Test report no. | material |
| 1 | RS-18/B-179/E | Aluminum |
| 2 | RS-18/B-180/E | Aluminum |
| 3 | RS-19/B-224/E | Aluminum |
| 4 | RS-21/B-446/E | Aluminum |
| 5 | PGA10652 | Steel |
| 6 | RS-17/B-176/E | Steel |
| 7 | PGA11301A | Steel |
| 8 | RS-18/B-293/E | Steel |
| 9 | PGA10024 | Steel |
| 10 | PGA10453 | Steel |
| 11 | 6P02516 | Steel |
| 12 | RS-20/B-409/E | Steel |
| 13 | 09-344E | Steel |
| Tokyo, Japan | ||
| 14 | 4P08662 | Steel |
| 15 | RS-19/B-355/E | Steel |
| 16 | 8P04039 | Steel |
| 17 | PGA10723A | Steel |
| 证书编号/Certificate No.:GB23PTB00036_01 | 4/11 |
| 18 | RS-17/B-177/E | Steel | Deck | A0 | 2017-05-26 | CTO, Gdansk, Poland |
| 19 | PGA11302A | Steel | Deck | A0 | 2019-01-16 | DBI, Hvidovre, Denmark |
| 20 | PGB10119A | Steel | Deck | A0 | 2021-11-15 | DBI, Hvidovre, Denmark |
| 21 | 6P02249 | Steel | Deck | A60 | 2016-08-17 | SP, Borås, Sweden. |
| 22 | RS-18/B-484/E | Steel | Deck | A60 | 2018-12-10 | CTO, Gdansk, Poland |
| 23 | 8P04040 | Steel | Deck | A60 | 2018-08-13 | SP, Borås, Sweden. |
| 24 | 6P07563 | Steel | Deck | A60 | 2016-12-20 | SP, Borås, Sweden. |
| 25 | 6P10022 | Steel | Deck | A60 | 2017-03-07 | SP, Borås, Sweden. |
| 26 | 4P07023 | Steel | Deck | A60 | 2015-02-04 | SP, Borås, Sweden. |
| 27 | RS-19/B-356/E | Steel | Deck | A60 | 2019-10-18 | CTO, Gdansk, Poland |
| 28 | PGA10025 | Steel | Deck | A60 | 2011-12-22 | DBI, Hvidovre, Denmark |
| 29 | PGA10871A | Steel | Deck | A60 | 2018-01-16 | DBI, Hvidovre, Denmark |
1.4 Watertightness/gastightness test reports
| No. | Test report no. | Testing organization | Test report date |
| 1. | MLM 020106 | DNV, Malmö, Sweden | 2001-12-19 |
| 2. | MLM 020133 | DNV, Malmö, Sweden | 2002-02-26 |
| 3. | MLM 020408 | DNV, Malmö, Sweden | 2002-06-03 |
| 4. | SKM-04-4088 | DNV, Stockholm, Sweden | 2004-06-16 |
| 5. | N141805F | DNV, Gothenburg, Sweden | 2018-02-27 |
| 证书编号/Certificate No.:GB23PTB00036_01 | 5/11 |
- R series
2.1 Product specifications
Roxtec sealing system with multidiameterTM technology: R-series (steel/aluminum division)
the R-Series sealing system consist of a rubber frame filled with Roxtec RM modules of different sizes
depending on diameter and configuration of the cables/pipes. It is available in standard, Ex and EMC versions
depending on application.
The R-seal is installed into an aluminum/steel sleeve that is welded/bolted, attached by expansion (SLFR X) or
with a nut (SLA) onto the aluminum/steel division.
2.2 Application limitation
R-series.
Application for cables in terms of deck and bulkhead.
| Type | Size | Division | Max. cable | Sleeve | Sleeve | Sleeve insulation |
| diameter | Length and | Drawing No. | ||||
| [mm] | thickness[mm] | position | ||||
| R series with | 50- 200 | A60 Aluminum | 67 | Length: 55 | All positions | S1581128 Rev A |
| SLR/SLFR | ||||||
| Bulkhead/Deck | Thickness: 6 | |||||
| R series with | 50- 100 | A60 Aluminum | 50 | Length: 119-126 | Exposed/ | S1581129 Rev A |
| SLA | Unexposed | |||||
| Bulkhead/Deck | Thickness: 4-6 | |||||
| R series with | 79- 200 | A60 Aluminum | 50 | Length: 55 | Exposed/ | S1582321 Rev A |
| SLFR X | Unexposed | |||||
| R series with | 70- 200 | A0 Steel | 83 | Length: 55 | Exposed/ | S1581100 Rev A |
| SLFR X | Thickness: 6 | Unexposed | ||||
| Bulkhead/Deck | ||||||
| R series with | 70- 200 | A60 Steel | 83 | Length: 55 | Exposed/ | S1581099 Rev A |
| R series with | 50- 100 | A0 Steel | 50 | Length: 119-126 | Exposed/ | S1581097 Rev A |
| R series with | 50- 100 | A60 Steel | 50 | Length: 119-126 | Exposed/ | S1581094 Rev A |
| R series with | 50- 200 | A0 Steel | 67 | Length: 55 | All positions | S1581087 Rev A |
| SLR/SLFR | Thickness: 6 | |||||
| R series with | 50- 200 | A60 Steel | 90 | Length: 55 | All positions | S1581085 Rev A |
| R series with | 50-200 | A60 Steel Deck | 90 | Length: 55-400 | All positions | S1588323 Rev A |
| long sleeves | Thickness: 6 | |||||
| R series with | 50-200 | A0 Steel Deck | 90 | Length: 55-400 | All positions | S1588324 Rev A |
| The R-series can be installed into sleeves equal to Roxtec dimensions specified in drawing S1587721. |
2.3 list of type test reports
| No. Test report no. | material | orientation |
| 1 | RS-20/B-408/E | Aluminum |
| 2 | RS-20/B-082/E | Aluminum |
| 证书编号/Certificate No.:GB23PTB00036_01 | 6/11 |
| 3 | PGA11370A | Aluminum | Bulkhead | A60 | 2019-02-20 | DBI, Hvidovre, Denmark |
| 4 | PGA11371A | Aluminum | Deck | A60 | 2019-02-20 | DBI, Hvidovre, Denmark |
| 5 | RS-19/B-224/E | Aluminum | Deck | A60 | 2019-08-01 | CTO, Gdansk, Poland |
| 6 | RS-18/B-179/E | Aluminum | Deck | A60 | 2018-06-25 | CTO, Gdansk, Poland |
| 7 | PGB10167A | Steel | Bulkhead | A60 | 2022-03-18 | DBI, Hvidovre, Denmark |
| 8 | RS-18/B-485/E | Steel | Bulkhead | A60 | 2018-12-10 | CTO, Gdansk, Poland |
| 9 | RS-19/B-255/E | Steel | Bulkhead | A60 | 2019-08-20 | CTO, Gdansk, Poland |
| 10 | RS-21/B-518/E | Steel | Bulkhead | A60 | 2021-12-15 | CTO, Gdansk, Poland |
| 11 | RS-22/B-152/E | Steel | Bulkhead | A60 | 2022-05-04 | CTO, Gdansk, Poland |
| 12 | PGA10724A | Steel | Bulkhead | A0 | 2916-02-05 | DBI, Hvidovre, Denmark |
| 13 | 8P07094 | Steel | Bulkhead | A0 | 2020-01-16 | SP, Borås, Sweden. |
| 14 | RS-22/B-153/E | Steel | Deck | A60 | 2022-05-04 | CTO, Gdansk, Poland |
| 15 | PGB10172A | Steel | Deck | A60 | 2022-06-17 | DBI, Hvidovre, Denmark |
| 16 | PGA10800A | Steel | Deck | A60 | 2016-05-26 | DBI, Hvidovre, Denmark |
| 17 | PGA10871A | Steel | Deck | A60 | 2018-01-16 | DBI, Hvidovre, Denmark |
| 18 | 7P02167 | Steel | Deck | A60 | 2017-08-07 | SP, Borås, Sweden. |
| 19 | PGB10169A | Steel | Deck | A0 | 2022-03-18 | DBI, Hvidovre, Denmark |
| 20 | PGA10723A | Steel | Deck | A0 | 2016-02-04 | DBI, Hvidovre, Denmark |
| 21 | 8P07092 | Steel | Deck | A0 | 2020-01-16 | SP, Borås, Sweden. |
| 22 | RS-22/B-336/E | Steel | Bulkhead | A60 | 2022-10-28 | CTO, Gdansk, Poland |
| 23 | RS-22/B-337/E | Steel | Deck | A60 | 2022-10-28 | CTO, Gdansk, Poland |
2.4 Watertightness/gastightness test reports
| No. Test report no. | Testing organization | Test report date |
| 1. | MLM030473-1 | DNV, Malmö, Sweden |
| 2. | N1429Y4V | DNV, Gothenburg, Sweden |
| 3. | N142G50V | DNV, Gothenburg, Sweden |
| 证书编号/Certificate No.:GB23PTB00036_01 | 7/11 |
- RS series
3.1 Product specifications
Roxtec sealing system with multidiameterTM technology: RS-series (steel/aluminum division)
The RS cable/pipe penetration seal consist of two halves with removable layers making it adaptable to a single
cable/pipe of different diameters. It is available in different versions, RS, RS OMD, RS EMC or RS EX,
The RS-seal is installed into an steel/aluminum sleeve that is either welded, bolted, attached through expansion
(SLFRS X) or attached with a nut (SLA) onto the steel/aluminum division.
3.2 Application limitation
RS-series
Application for (Std & CLX) cables in terms of deck and bulkhead.
| diameter Length and thickness | Drawing No. | |||||
| [mm] | [mm] | position | ||||
| RS series with | 25- 100 | A60 Aluminum | 50 | Length: 77-126 | Exposed/ | S1581154 Rev A |
| SLA | Thickness: 4-6 | Unexposed | ||||
| RS series with | 23- 125 | A60 Aluminum | 88 | Length: 35-65 | All positions | S1581150 Rev A |
| SLRS/SLFRS | Thickness: 4-6 | |||||
| RS series with | 25- 125 | A60 Steel | 90 | Length: 65 | Exposed/ | S1581291 Rev A |
| SLFRS X | Unexposed | |||||
| RS series with | 23- 644 | A60 Steel | 100 | Length: 35-65 | All positions | S1581292 Rev A |
| Including CLX cable |
Bulkhead/Deck
| RS series with | 23- 644 | A0 Steel | 86 | Length: 35-65 | All positions | S1581293 Rev A |
| SLRS/ SLFRS | Bulkhead/Deck | Thickness: 4-6 | ||||
| Including CLX cable | ||||||
| RS series with | 25-75 | A60 Steel | 32 | Length: 77-124 | Exposed/ | S1581294 Rev A |
| SLA | Bulkhead/Deck | Thickness: 4-6 | Unexposed | |||
| RS series with | 25-75 | A0 Steel | 32 | Length: 77-124 | Exposed/ | S1581295 Rev A |
| RS series with | 23- 664 | A60 Steel | 90 | Length 35-400 | All positions | S1581298 Rev A |
| long sleeves | Deck | Thickness: 6 | ||||
| RS series with | 23- 664 | A0 Steel | 90 | Length 35-400 | All positions | S1582128 Rev A |
| RS series with | 25- 125 | A0 Steel | 90 | Length: 65 | Exposed/ | S1582125 Rev A |
| SLFRS X | Bulkhead/Deck | Thickness: 6 | Unexposed | |||
| The RS-seal can be installed into sleeves equal to Roxtec dimensions specified in drawing S1586454. |
3.3 list of type test reports
| Test report date Testing organization | ||
| 1 | RS-17/B-210/E | Aluminum |
| 2 | RS-17/B-555/E | Aluminum |
| 3 | PGA11371A | Aluminum |
| 证书编号/Certificate No.:GB23PTB00036_01 | 8/11 |
| 4 | RS-19/B-224/E | Aluminum | Deck | A60 | 2019-08-01 | CTO, Gdansk, Poland |
| 5 | PGB10031A | Aluminum | Bulkhead | A60 | 2020-07-09 | DBI, Hvidovre, Denmark |
| 6 | RS-20/B-410/E | Aluminum | Bulkhead | A60 | 2020-12-17 | CTO, Gdansk, Poland |
| 7 | RS-21_B-189E | Aluminum | Bulkhead | A60 | 2021-06-04 | CTO, Gdansk, Poland |
| 8 | PGA10800A | Steel | Deck | A60 | 2016-05-26 | DBI, Hvidovre, Denmark |
| 9 | RS-22/B-153/E | Steel | Deck | A60 | 2022-05-04 | CTO, Gdansk, Poland |
| 10 | PGA10871A | Steel | Deck | A60 | 2018-01-16 | DBI, Hvidovre, Denmark |
| 11 | PGB10118A | Steel | Deck | A60 | 2021-11-15 | DBI, Hvidovre, Denmark |
| 12 | RS-17/B-395/E | Steel | Deck | A60 | 2017-10-30 | CTO, Gdansk, Poland |
| 13 | 6P02249 | Steel | Deck | A60 | 2016-08-17 | SP, Borås, Sweden. |
| 14 | PGB10172A | Steel | Deck | A60 | 2022-06-17 | DBI, Hvidovre, Denmark |
| 15 | PGA11611A | Steel | Deck | A60 | 2020-01-11 | DBI, Hvidovre, Denmark |
| 16 | 8P07092 | Steel | Deck | A0 | 2020-01-16 | SP, Borås, Sweden. |
| 17 | PGB10169A | Steel | Deck | A0 | 2022-03-18 | DBI, Hvidovre, Denmark |
| 18 | PGA10723A | Steel | Deck | A0 | 2016-02-04 | DBI, Hvidovre, Denmark |
| 19 | PGA11610A | Steel | Deck | A0 | 2020-01-10 | DBI, Hvidovre, Denmark |
| 20 | PGA10870A | Steel | Bulkhead | A60 | 2016-12-13 | DBI, Hvidovre, Denmark |
| 21 | 6P10024 | Steel | Bulkhead | A60 | 2017-03-07 | SP, Borås, Sweden. |
| 22 | RS-20/B-017/E | Steel | Bulkhead | A60 | 2020-01-23 | CTO, Gdansk, Poland |
| 23 | RS-20/B-191/E | Steel | Bulkhead | A60 | 2020-06-05 | CTO, Gdansk, Poland |
| 24 | 7P02024 | Steel | Bulkhead | A60 | 2017-06-08 | SP, Borås, Sweden. |
| 25 | RS-18/B-022/E | Steel | Bulkhead | A60 | 2018-01-29 | CTO, Gdansk, Poland |
| 26 | RS-21/B-517/E | Steel | Bulkhead | A60 | 2021-12-15 | CTO, Gdansk, Poland |
| 27 | RS-20/B-083/E | Steel | Bulkhead | A60 | 2020-04-20 | CTO, Gdansk, Poland |
| 28 | 8P07094 | Steel | Bulkhead | A0 | 2020-01-16 | SP, Borås, Sweden. |
| 29 | PGA10652 | Steel | Bulkhead | A0 | 2015-07-03 | DBI, Hvidovre, Denmark |
| 30 | RS-21/B-518/E | Steel | Bulkhead | A0 | 2021-12-15 | CTO, Gdansk, Poland |
| 31 | RS-20/B-081/E | Steel | Bulkhead | A0 | 2020-03-31 | CTO, Gdansk, Poland |
3.4 Watertightness/gastightness test reports
| 1. | MLM 020133 | DNV, Malmö, Sweden |
| 2. | MLM030473-1 | DNV, Malmö, Sweden |
| 3. | N141EX8Z Rev. 2 | DNV, Malmö, Sweden |
| 4. | N142G50V | DNV, Gothenburg, Sweden |
| 证书编号/Certificate No.:GB23PTB00036_01 | 9/11 |
- G series
4.1 Product specifications
“Roxtec sealing system with multidiameterTM technology: G-series (steel)” consisting of Roxtec G-series steel
frames (G, GO and GHM) in sizes 1-8 and combinations thereof, bolted or welded to a steel section. The G
frame is filled with Roxtec (standard or Ex, EMC of type PE, ES and BG, BGB) halogen free RM modules.
Assembled with Roxtec wedge kit or Roxtec EMC wedge kit.
4.2 Application limitation
G-series.
| Type & Size | Division | Max. cable | Frame | Frame | Frame insulation |
| [mm] | |||||
| G series in size 1-8 and | A60 Steel | 88 | Length: 60 | All positions | S1582076 Rev A |
| combination thereof. | Bulkhead/Deck | Thickness: 6 | |||
| G series in size 1-8 and | A0 Steel | 88 | Length: 60 | All positions | S1582341 Rev A |
4.3 list of type test reports
| 1 | 6P10022 | Steel | Bulkhead | A60 | 2017-03-07 | SP, Borås, Sweden. |
| 2 | RS-17/B-395/E | Steel | Bulkhead | A60 | 2017-10-30 | CTO, Gdansk, Poland |
| 3 | RS-17/B-396/E | Steel | Deck | A60 | 2017-10-31 | CTO, Gdansk, Poland |
| 4 | RS-18/B-181/E | Steel | Deck | A60 | 2018-05-07 | CTO, Gdansk, Poland |
4.4 Watertightness/gastightness test reports
| 3. | MLM 020401 | DNV, Malmö, Sweden |
| 证书编号/Certificate No.:GB23PTB00036_01 | 10/11 |
- GK FS SK sealing kit
5.1 Product specifications
“GK FS SK sealing kit” consisting of a fiberglass cloth with built in heat activated intumescent material to be
wrapped around cable bundles and fitted into circular or oval steel pipe sleeves. Folded back on each side with
ends sealed off to create a cold smoke tight seal and secured by metal cable ties.
“GK FS SK sealing kit” is intended to be used for bundled cables or as a blank fire stop solution. The
installation shall be made in symmetrically welded or bolted pipe sleeves.
5.2 Application limitation
a) The systems must not be installed in bulkheads and decks if water or gas tightness is required.
b) The weight of the cables must be supported on both sides of the GK Fire stop Sealing Kit.
c) The sleeve size, Ø or Ø x L (mm):
Round: 89-273mm; Oval: 200x150, 200x170, 250x170 and 2x(250x170) mm
| Type | Division | Max. cable | Sleeve | Sleeve | Sleeve insulation |
| [mm] | thickness [mm] | position | |||
| GK FS SK in round and oval | A60 Steel | 100 | Length: 105-205 | Symmetric | S1581191 Rev A |
| sizes. | Deck | Thickness: ≥3 | |||
| GK FS SK in round and oval | A0 Steel | 100 | Length: 105-205 | Symmetric | S1581271 Rev A |
| GK FS SK in round and oval | A0 Steel | 100 | Length: 105-205 | Symmetric | S1581276 Rev A |
| sizes. | Bulkhead | Thickness: ≥3 | |||
| GK FS SK in round and oval | A60 Steel | 100 | Length: 105-205 | Symmetric | S1581277 Rev A |
| GK FS SK in round and oval | A60 Aluminum 50 | Length: 105-205 | Symmetric | S1581194 Rev A | |
| GK FS SK in round and oval | A60 Aluminum 50 | Length: 105-205 | Symmetric | S1581829 Rev A | |
5.3 list of type test reports
| 1 | PGB10016A | Aluminum |
| 3 | RS_19_B_225_E | Steel |
| 4 | RS-19/B-256/E | Steel |
| 5 | PGB10118A | Steel |
| 6 | PGB10172A | Steel |
| 7 | PGB10112A | Steel |
| 8 | RS-19/B-355/E | Steel |
| 10 | 8P07092 | Steel |
| 11 | PGA11610A | Steel |
| 12 | PGB10119A | Steel |
| 14 | PGA11387A | Steel |
| 15 | RS-19/B-423/E | Steel |
| 16 | RS-20/B-081/E | Steel |
| 17 | RS-21_B-240E | Steel |
| 证书编号/Certificate No.:GB23PTB00036_01 | 11/11 |
