GB23PTB00036_02_Cert-optimized
中国船级社 证书编号/Certificate No.
CHINA CLASSIFICATION SOCIETY GB23PTB00036_02
型式认可证书
CERTIFICATE OF TYPE APPROVAL
兹证明本证书所述制造厂具备按照下列标准的要求生产本证书所列产品的能力和条件。
This is to certify that the manufacturer stated in the certificate meets the requirements of the standards listed below and is available
with the ability and conditions to produce the products described in the certificate.
制造厂/Manufacturer
地址/Address
Box 540,S-37123 Karlskrona,Sweden
产品名称/Product
管路贯穿装置
Pipe Penetrations
附加标志/Notations
无/Nil.
认可标准/Approval Standard
1.1974年SOLAS公约及其修正案第II-2章第3条和第9条
Regulations 3 and 9, Chapter II-2 of 1974 SOLAS Convention, as Amended
2.IMO 2010年FTP规则附件1第3部分
IMO 2010 FTP Code Annex I Part 3
用于/Intended for
船舶/Ships
证书有效期至/This Certificate is valid until 2026年11月13日/ Nov. 13,2026
| 发证机构 中国船级社哥德堡办事处 | 签发日期 2023年10月06日 |
| Issued by CCS Gothenburg Office | Date Oct. 06,2023 |
本证书根据中国船级社规范和相关规定签发。所有证书页为一个整体,必须同时使用。纸质证书每页均须由本社盖章方为有效,电子证书含数字签名方
为有效,本证书复印件无效。任何单位和个人均不应摘录或节选本证书的部分内容。有关方对所持证书的真实性有疑问时,可以向我社检验机构咨询。
This Certificate is issued pursuant to the Rules of the Society and related regulation. All pages of the certificate are taken as a whole and are used simultaneously. No
paper certificate page is valid without bearing the stamp of the Society, no electronic certificates is valid without the digital signature, and no copied form of the
certificate is regarded as valid. Any part of the certificate is not to be extracted or abridged by any unit or individual in any form. Related parties who are doubted
about the authenticity of the certificate may inquire of the Society or its offices.
Form No: T01. 联系方式/Contact Us,见本社官方网站/See official web site of the Society(http://www.ccs.org.cn) UTN:P023-63028376
第1页共3页/Page 1 of 3
证书编号/Certificate No. GB23PTB00036_02
产品明细/Product Description
管路贯穿装置/Pipe Penetrations(M0001)
名称/Name 属性(值)/Value 单位/Unit
型号/Type 详见附页/See additional page(s)
规格/Specification 详见附页/See additional page(s)
应用型式/Application Type 详见附页/See additional page(s)
使用限制/Installation Limitations 详见附页/See additional page(s)
装置围板/套管包覆用隔热材料/Insulation
Material Bundled for Coaming Or Spigot 详见附页/See additional page(s)
of Pipe Penetrations
套管(薄片)材料/Sleeves(Sheets) 详见附页/See additional page(s)
密封胶/Sealant 详见附页/See additional page(s)
试验前试样液压试验压力(水密性)
/Pressure of Hydraulic Before Test 详见附页/See additional page(s) bar
Specimen(Watertight)
试验前试样空气试验压力(气密性)
/Pressure of Air Before Test 详见附页/See additional page(s) mbar
Specimen(Airtight)
甲板管路贯穿耐火等级/受火面/Fire Class
of Deck Pipe Penetrations /Exposed Face
舱壁管路贯穿耐火等级/受火面/Fire Class
of Bulkhead Pipe Penetrations /Exposed 详见附页/See additional page(s)
Face
批准的图纸/Approved Drawings
图纸批准号/ Drawings Approval No. : 详见附页/See additional page(s)
产品认可试验报告/ Approval Test Report
试验报告编号/ Test Report No. : 详见附页/See additional page(s)
试验报告日期/ Test Report Date :
试验单位/ Laboratory: 详见附页/See additional page(s)
试验单位地址/ Test Address:
认可后的产品检验方式/ Method of Product Inspection after Approval
按规范只认可不进行产品检验的产品/The product approved only in term of the rules:
认可后的产品检验由制造厂按本社批准的产品检验计划进行检验,经检验合格后由制造厂签发合格证明,并连同该
产品的本社认可证书复印件一并交付用户,制造厂对产品符合公约、法规、本社规范和本社认可的标准规定负责。
After approval, product inspection should be carried out by the Manufacturer in accordance with the
product inspection scheme approved by the Society. Upon satisfactory inspection, and the Quality
Certificate issued by the Manufacturer should be provided to the purchaser together with the copy of
the approval certificate issued by the Society. The manufacturer should take responsibility for the
product being in compliance with the convention, statutory regulation, the Society rules and the
standard accepted by the Society.
认可保持条件/ Maintenance Requirements of Approval
1.型式认可后,如果产品及其重要零部件的设计、所用材料或制造方法有所改变,且影响到产品的主要特性、特
征;或产品的性能指标有所更改,且超过认可的范围,则有关图纸和文件应经检验机构审批。并在检验机构认为必
要时,经本社检验人员见证有关试验和进行检查,其结果应能证实仍符合认可条件。
After type approval, if there are changes to the design, materials used or manufacturing method of
the product and important components and such changes affect major characteristics and properties of
the product, or property indexes of the product are changed and exceed the scope of approval,
related drawings and documents are to be examined and approved by the concerned survey office. Where
deemed necessary by the survey office, the surveyor to the Society will go to witness relevant tests
and conduct inspection and the results should be able to demonstrate compliance with the approval
第2页共3页/Page 2 of 3
conditions.
2.工厂的质量管理体系应保持有效运行,并且与认可时一致。如果质量管理体系发生改变,应经原体系认证机构审
核并报本社批准。
The quality management system of the factory shall be ensure effective operation, and shall be the
same as the situation of approval. If there are any changes to the quality management system,
auditing of the original certification organization for quality management system and the society’s
approval shall be obtained.
3.认可证书有效期内,如果出现可能导致本社取消认可的情况,工厂应及时采取有效的纠正措施。
Within the validity of the approval certificate, if cases occur that may cause the Society to
withdraw the approval, the manufacturer should take corrective actions in a prompt and effective
manner.
4.在认可证书有效期内,本社检验人员可在未经事先通知的情况下对工厂的产品制造过程进行审核,以验证产品的
生产是否符合业经本社批准的图纸和文件。工厂应予以配合。
Within the validity of the approval certificate, the surveyor to the Society may pay unannounced
audit to the manufacturing process of the product in order to confirm whether it is in compliance
with the drawings and documents approved by the Society. The factory should provide an active
cooperation and necessary for the surveyor.
5.如果属于获得型式认可B 模式证书,且无需颁发船用产品证书/等效证明文件的情况,证书获得者应接受本社每
年一次的定期审核,定期审核日为认可证书期满之日对应的每一周年日,检查工作应在周年日的前后三个月内进
行。
If belong to the situation of the product has type approval mode B certificate, and marine product
certificate/equivalent document is not necessary, those who have obtained the certificate should be
subject to periodical audit every year. The date of periodical audit shall be each anniversary date
which corresponds to the date of expiry of the relevant certificate and the periodical audit shall
be done within a time span of three months before and after the annual surveillance date.
备注/Remarks
1.本社已审核了产品厂无石棉声明,但本社的审核不免除产品厂按照合同关系向订货方保证产品无石棉的责任。
The declaration of asbestos-free submitted by manufacturer has been reviewed by the Society.
However, liability of the manufacturer to guarantee the products are asbestos-free to purchaser
under contract will not be exempted.
2.本证书由原型式认可证书(No. GB22PTB00041_02)变更并替代原证书。
This Certificate is modified from and supersedes the previous Type Approval Certificate No.
GB22PTB00041_02.
3.This cert was issued to Roxtec International AB.
Besides production site at Karlskrona, Sweden, Roxtec Sealing System (Shanghai) Co., Ltd (address:
Ground floor, Building A, No. 875 Qiuxin Road, Lingang Nicheng Industrial Area, Pudong District
Shanghai, P.R.China) is the assessed production site for the following components of the approved
products:
R-series: Sleeve
RS-series: Sleeve
S-series: Frame, Stayplates
G-series: Frame Stayplates
4.本证书认可产品应根据制造厂安装手册和批准图纸安装。
The approved products shall be installed as per the manufacuter’s installation instructions and the
approved drawings.
中国船级社哥德堡办事处
注:本证书含有附页,共11页
Note: The certificate is attached with additional 11 page(s)
第3页共3页/Page 3 of 3
证书编号/Certificate No.:GB23PTB00036_02 附页/Additional Page
产品明细
Product Description
管路贯穿装置
产品名称/Product name
Pipe Penetrations
型号/Type S Series R Series RS Series G Series SPM Seals
规格
See “Detailed Parameters” See “Detailed Parameters” See “Detailed Parameters” See “Detailed Parameters” See “Detailed Parameters”
Specification
图纸批准号
GB17A00007, NP18A01797 GB17A00007, NP18A01797 GB17A00007, NP18A01797 NP23PPP00217 GB17A00006
Drawings approval No.
管路材质
Material of pipe
界面(甲板/舱壁)材质 aluminum/steel aluminum/steel aluminum/steel steel
Material of divisions(deck/bulkhead) Bulkhead and Deck Bulkhead and Deck Bulkhead and Deck Bulkhead and Deck
焊接/welded 焊接/welded
贯穿装置与舱壁或甲板连接方式
焊接/welded 螺栓链接/bolted 螺栓链接/bolted 焊接/welded
Connection method of penetration device attached by expansion
螺栓链接/bolted Attached by expansion (SLFR attached by expansion 螺栓链接/bolted
to bulkhead or deck
X) or with a nut (SLA) (SLFRS X) or with a nut (SLA)
框架或套筒材料
aluminum/steel aluminum/steel aluminum/steel steel No sleeve/frame
Material of frame or sleeve
框架或套筒包覆用隔热材料
Insulation material bundled for frame A-60 approved type A-60 approved type A-60 approved type A-60 approved type A-60 approved type
or sleeve
舱壁贯穿耐火等级/受火面
Fire class of bulkhead transits /Exposed See “Detailed Parameters” See “Detailed Parameters” See “Detailed Parameters” See “Detailed Parameters” See “Detailed Parameters”
face
甲板贯穿耐火等级/受火面 See “Detailed Parameters” See “Detailed Parameters” See “Detailed Parameters” See “Detailed Parameters” See “Detailed Parameters”
Fire class of deck transits/Exposed face
试验前试样空气试验压力(气密性) Bolted:1.67 bar Bolted:1.67 bar Bolted:1.67 bar Bolted:1.67 bar 0.67 bar
Pressure of air before test Welded:2.67 bar Welded:2.67 bar Welded:2.67 bar Welded:2.67 bar
specimen(Airtight) Long sleeves: 1 bar
试验前试样液压试验压力(水密 Bolted:3.33 bar Bolted:3.33 bar Bolted:3.33 bar Bolted:3.33 bar 1.00 bar
性) Pressure of hydraulic before test Welded:4 bar Welded:4 bar Welded:4 bar Welded:4 bar
specimen(Watertight) Long sleeves: 2 bar
| 证书编号/Certificate No.:GB23PTB00036_02 | 1/11 |
| 证书编号/Certificate No.:GB23PTB00036_02 | 附页/Additional Page |
密封胶
No sealant No sealant No sealant No sealant No sealant
Sealant
应用型式 See “Detailed Parameters” See “Detailed Parameters” See “Detailed Parameters” See “Detailed Parameters”
Application Type
使用限制 1. Approved for pipe penetration in decks or bulkheads with “A” class divisions (including A-0, A-15, A-30, A-60). For A-15 and A-30
Installation limitation applications, the penetration shall be insulated as for A-60 and the division is to be fitted with A60 insulation for a minimum distance of 200 mm
around the penetration.
  1. Not for use in tank boundaries.
  2. More details please see “Detailed Parameters”.
证书编号/Certificate No.:GB23PTB00036_02 2/11
Detailed Parameters
1. S series
1.1 Product description
Roxtec sealing system with multidiameter :trade_mark: technology, S-series consists of Roxtec S-series frames with a
depth of 60 mm (S, S Ex, SF, SFHM, SO, SFO, SFOH, SR/T, SR/S, SRC r20, SRC r40, SRC r60) in height 1-8
and width 60-120, and combinations thereof, welded or bolted to the steel/aluminum sections. Also included in
the S-series is the subgroup of SK-series frames with a single barrier with a depth of more than 60 mm (SK, SK
Ex, SFK, SFOK, SFOHK, SRCK r20, SRCK r40, SRCK r60) and a subgroup SBTB-series frames with two
barriers (SBTB, SBTB Ex, SFBTB, SRBTB, SRCBTB r20, SRCBTB r40, SRCBTB r60).
The S-series (including subgroups) is filled with Roxtec halogen free RM modules (*1. & *2.). Assembled with
Roxtec Wedge, Roxtec ES Wedge, Roxtec Ex Wedge or Roxtec ES Ex Wedge and corresponding stayplates.
*1. Standard RM, RM Ex, RM PPS, RM FOC, RM ES, RM ES B, RM PE, RM PE B, RM BG, RM BG B, RM
ES Ex, RM ES B Ex, RM PE Ex, RM ES B Ex , RM BG Ex, RM BG B Ex
*2. RMX, RX BG, RX BG B.
1.2 Application limitation
S-Series
Application for (Steel, Cu, CuNi & Bundle) pipes in terms of deck and bulkhead
Type Division Size Pipe Pipe diameter Frame Frame Frame insulation
Material (OD) [mm] length [mm] position Drawing No.
S series. A60 Steel 1-8 and Steel 6-54 60 All positions
Bulkhead/Deck combination
thereof.
S series A60 Steel Copper 6-54 60 All positions S1582883 Rev A
Bulkhead/Deck & CuNi
S series A60 Steel Bundle 8-50 60 All positions S1582886 Rev A
Bulkhead/Deck
S series A0 Steel Copper 6-54 60 All positions S1582893 Rev A
S series A0 Steel Bundle 8-50 60 All positions S1582896 Rev A
Bulkhead/Deck
S series A0 Steel Steel 6-54 60 All positions S1582899 Rev A
Bulkhead/Deck
S series A60 Aluminum Steel 6-54 60 All positions S1582903 Rev A
Bulkhead/Deck
S series A60 Aluminum Copper 6-54 60 All positions S1583246 Rev A
1.3 list of type test reports
Division Division Fire
No. Test report no. material
| 1 | PG11898 | Aluminum | Bulkhead | A60 | 2009-04-17 | DBI, Hvidovre, Denmark |
| 2 | PG11955 | Aluminum | Deck | A60 | 2009-04-17 | DBI, Hvidovre, Denmark |
| 3 | PGB10077A | Aluminum | Deck | A60 | 2020-12-10 | DBI, Hvidovre, Denmark |
| 4 | RS-18/B-485/E | Steel | Bulkhead | A60 | 2018-12-10 | CTO, Gdansk, Poland |
| 5 | RS-20/B-081/E | Steel | Bulkhead | A0 | 2020-03-31 | CTO, Gdansk, Poland |
| 6 | 6P02249 | Steel | Deck | A60 | 2016-08-17 | SP, Borås, Sweden. |
| 7 | RS-17/B-395/E | Steel | Deck | A60 | 2017-10-30 | CTO, Gdansk, Poland |
| 8 | RS- 18/B-484/E | Steel | Deck | A60 | 2018-12-10 | CTO, Gdansk, Poland |
| 证书编号/Certificate No.:GB23PTB00036_02 | 3/11 |
| 9 | RS-21_B-242E | Steel | Bulkhead | A60 | 2021-06-30 | CTO, Gdansk, Poland |
| 10 | PGB10174A | Steel | Deck | A60 | 2022-07-13 | DBI, Hvidovre, Denmark |
1.4 Watertightness/gastightness test reports
No. Test report no. Testing organization Test report date
1. MLM 020133 DNV, Malmö, Sweden
2. MLM 020400 DNV, Malmö, Sweden
3. MLM 050410 DNV, Malmö, Sweden
4. MLM 060561 DNV, Malmö, Sweden
  1. R Series
2.1 Product description
Roxtec sealing system with multidiameterTM technology: R-series (steel/aluminum division)
The R-Series sealing system consist of a rubber frame filled with Roxtec RM modules of different sizes
depending on diameter and configuration of the cables/pipes. It is available in standard, Ex and EMC versions
depending on application.
The R-seal is installed into an aluminum/steel sleeve that is welded/bolted, attached by expansion (SLFR X) or
with a nut (SLA) onto the aluminum/steel division.
2.2 Application limitation
R-series.
Application for (Steel, Cu, CuNi & Bundle) pipes in terms of deck and bulkhead.
Type Division Size Pipe Pipe diameter Sleeve Sleeve Sleeve insulation
R series with SLFR X A60 Steel 70-200 Steel 6-54 55 Exposed/
Bulkhead/Deck Unexposed
R series with SLR/SLFR A60 Steel 50-200 Steel 6-95 55 All S1582060 Rev A
Bulkhead/Deck positions
R series with SLR/SLFR A60 Steel 50-200 Copper 6-54 55 All S1582062 Rev A
Bulkhead/Deck & CuNi positions
R series with long A60 Steel Deck 50-200 Steel 6-54 55-400 All
sleeves positions
R series with SLR/SLFR A0 Steel Deck 50-200 Steel 6-95 55 All S1582061 Rev A
positions
R series with SLR/SLFR A0 Steel 50-200 Copper 6-54 55 All S1582063 Rev A
R series with SLR/SLFR A0 Steel 50-200 Steel 6-54 55 All S1582064 Rev A
Bulkhead positions
R series with SLFR X A0 Steel 70-200 Steel 6-54 55 Exposed/
R series with long A0 Steel Deck 50-200 Steel 6-54 55-400 All
sleeves positions
R series with SLR/SLFR A60 Aluminum 50-200 Steel 6-54 55 All S1581874 Rev A
R series with SLR/SLFR A60 Aluminum 50-200 Copper 6-54 55 All S1583673 Rev A
R series with SLR/SLFR A60 Steel 50-200 Bundle 8-50 55 All S1588399 Rev A
R series with SLR/SLFR A0 Steel 50-200 Bundle 8-50 55 All S1588403 Rev A
The R-series can be installed into sleeves equal to Roxtec dimensions specified in drawing S1587721.
证书编号/Certificate No.:GB23PTB00036_02 4/11
2.3 list of type test reports
| 1 | RS-20/B-408/E | Aluminum | Bulkhead | A60 | 2020-12-17 | CTO, Gdansk, Poland |
| 2 | RS-21/B-446/E | Aluminum | Bulkhead | A60 | 2021-10-07 | CTO, Gdansk, Poland |
| 3 | RS-20/B-410/E | Aluminum | Bulkhead | A60 | 2020-12-17 | CTO, Gdansk, Poland |
| 4 | PGB10016A | Aluminum | Deck | A60 | 2022-06-29 | DBI, Hvidovre, Denmark |
| 5 | PGB10077A | Aluminum | Deck | A60 | 2020-12-10 | DBI, Hvidovre, Denmark |
| 6 | PG11955 | Aluminum | Deck | A60 | 2009-04-17 | DBI, Hvidovre, Denmark |
| 7 | 4P08662 | Steel | Bulkhead | A60 | 2015-06-08 | SP, Borås, Sweden. |
| 8 | 8P04039 | Steel | Bulkhead | A60 | 2018-08-06 | SP, Borås, Sweden. |
| 9 | PGB10046A | Steel | Bulkhead | A60 | 2020-11-16 | DBI, Hvidovre, Denmark |
| 10 | PGB10176A | Steel | Bulkhead | A60 | 2022-11-04 | DBI, Hvidovre, Denmark |
| 11 | PGA11301A | Steel | Bulkhead | A0 | 2018-11-22 | DBI, Hvidovre, Denmark |
| 12 | PGA10724A | Steel | Bulkhead | A0 | 2016-05-05 | DBI, Hvidovre, Denmark |
| 13 | PGA10800A | Steel | Deck | A60 | 2016-05-26 | DBI, Hvidovre, Denmark |
| 14 | 8P04040 | Steel | Deck | A60 | 2018-08-13 | SP, Borås, Sweden. |
| 15 | RS_19_B_225_ | Steel | Deck | A60 | 2019-08-01 | CTO, Gdansk, Poland |
E
16 PGB10174A Steel Deck A60 2022-07-23 DBI, Hvidovre, Denmark
17 6P07563 Steel Deck A60 2016-12-20 SP, Borås, Sweden.
18 PGB10118A Steel Deck A60 2021-11-15 DBI, Hvidovre, Denmark
19 PGA10723A Steel Deck A0 2016-02-04 DBI, Hvidovre, Denmark
20 PGA11302A Steel Deck A0 2019-01-16 DBI, Hvidovre, Denmark
21 RS-22/B-336/E Steel Bulkhead A60 2022-10-28 CTO, Gdansk, Poland
22 RS-22/B-337/E Steel Deck A60 2022-10-28 CTO, Gdansk, Poland
2.4 Watertightness/gastightness test reports
1. MLM 030473-1 DNV, Malmö, Sweden
2. N1429Y4V DNV, Gothenburg, Sweden
3. N142G50V DNV, Gothenburg, Sweden
| 证书编号/Certificate No.:GB23PTB00036_02 | 5/11 |
  1. RS Series
3.1 Product description
Roxtec sealing system with multidiameterTM technology: RS-series (steel/aluminum division)
The RS cable/pipe penetration seal consist of two halves with removable layers making it adaptable to a single
cable/pipe of different diameters. It is available in different versions, RS, RS OMD, RS EMC or RS EX,
The RS-seal is installed into an steel/aluminum sleeve that is either welded, bolted, attached through expansion
(SLFRS X) or attached with a nut (SLA) onto the steel/aluminum division.
3.2 Application limitation
RS-series.
Application for (steel, Cu, CuNi, GRE & Bundle) pipes in terms of deck and bulkhead.
Type Division Pipe Pipe Sleeve Sleeve Sleeve insulation
Material diameter length Drawing No.
position
(OD) [mm] [mm]
RS series A60 Steel Steel 6-558 35-65 All positions S1582643 Rev A
SLRS/SLFRS in size 23-664. Bulkhead
RS series A60 Steel Deck Steel 6-558 35-65 All positions S1582664 Rev A
RS series A0 Steel Deck Steel 6-558 35-65 All positions S1582695 Rev A
RS series A0 Steel Steel 6-558 35-65 All positions S1582700 Rev A
RS series A60 Steel Steel 6-168 65 Exposed/ S1582703 Rev A
SLFRS X in size 25-200.
RS series A60 Steel Steel 6-30 77-124 Exposed/ S1582705 Rev A
SLA in size 25–75. Bulkhead/Deck Unexposed
RS series A0 Steel Steel 6-30 77-124 Exposed/ S1582714 Rev A
SLA in size 25–75.
RS series A0 Steel Steel 6-168 65 Exposed/ S1582764 Rev A
RS series A60 Steel Copper & 6-34 77-124 Exposed/ S1581910 Rev A
SLA in size 25–75. Bulkhead/Deck CuNi Unexposed
RS series A60 Steel Copper 6-225 35-65 All positions S1581884 Rev A
SLRS/SLFRS in size 23-300. Bulkhead/Deck
RS series A60 Steel Copper & 6-108 65 Exposed/ S1582686 Rev A
SLFRS X in size 25- 150. Bulkhead/Deck CuNi Unexposed
RS series A0 Steel Copper 6-225 35-65 All positions S1582701 Rev A
SLRS/ SLFRS in size 23-300. Deck
RS series A0 Steel Copper 6-225 35-65 All positions S1582702 Rev A
RS series A0 Steel Copper & 6-34 77-124 Exposed/ S1582716 Rev A
RS series A0 Steel Copper & 6-108 65 Exposed/ S1582750 Rev A
RS series A60 Steel CuNi 10-420 35-65 All positions S1582712 Rev A
SLRS/ SLFRS in size 25-500. Bulkhead
RS series A60 Steel Deck CuNi 10-420 35-65 All positions S1582713 Rev A
RS series A0 Steel CuNi 10-420 35-65 All positions S1582744 Rev A
SLRS/ SLFRS in size 25-500. Deck
RS series A0 Steel CuNi 10-420 35-65 All positions S1582745 Rev A
RS series A60 Steel GRE 25-1040 35-65 All positions S1582692 Rev A
SLRS/ SLFRS in size 50- 1125. Bulkhead
| 证书编号/Certificate No.:GB23PTB00036_02 | 6/11 |
| RS series | A60 Steel | GRE | 25-1040 | 35-65 | All positions | S1582694 Rev A |
| SLRS/ SLFRS in size 50- 1125. | Deck |
| RS series | A0 Steel | GRE | 25-1040 | 35-65 | All positions | S1582709 Rev A |
| SLRS/SLFRS in size 50- 1125. | Deck |
| RS series | A0 Steel | GRE | 25-1040 | 35-65 | All positions | S1582743 Rev A |
Bulkhead
RS series A60 Steel Bundle 8-50 35-65 All positions S1582690 Rev A
Bulkhead/Deck
SLRS/SLFRS in size 25- 100.
RS series A0 Steel Bundle 8-50 35-65 All positions S1582747 Rev A
Bulkhead/Deck
RS series A60 Aluminum Steel 6-558 35-65 All positions S1582791 Rev A
Bulkhead
RS series SLA in size 25–75. A60 Aluminum Steel 6-30 77-124 Exposed/ S1582792 Rev A
Deck
RS series A60 Aluminum Copper 6-108 35-65 All positions S1582805 Rev A
Bulkhead
SLRS/SLFRS in size 23- 150.
RS series SLA in size 25–75. A60 Aluminum Copper & 6-34 77-124 Exposed/ S1582807 Rev A
RS series A60 Aluminum Copper & 6-108 65 Exposed/
Deck
RS series A60 Aluminum CuNi 10-420 35-65 All positions S1582817 Rev A
Deck
SLRS/SLFRS in size 23-500.
RS series A60 Aluminum CuNi 8-420 35-65 All positions S1582821 Rev A
Bulkhead
RS series A60 Aluminum GRE 35-1040 35-65 All positions S1582852 Rev A
Bulkhead
SLRS/SLFRS in size 68- 1125.
RS series A60 Aluminum GRE 35-520 35-65 All positions S1582853 Rev A
SLRS/ SLFRS in size 68-600. Deck
The RS-seal can be installed into sleeves equal to Roxtec dimensions specified in drawing S1586454.
3.3 list of type test reports
No. Test report no. material orientation
1 RS- 17/B-555/E Aluminum
2 RS- 19/B-020/E Aluminum
3 RS-20/B-408/E Aluminum
4 RS-20/B-082/E Aluminum
5 PG11898 Aluminum
6 RS-21_B- 189E Aluminum
7 PGB10031A Aluminum
8 RS-20/B-410/E Aluminum
9 RS-21/B-446/E Aluminum
10 PGB10015A Aluminum
11 RS- 18/B- 179/E Aluminum
12 PGB10016A Aluminum
13 PGB10077A Aluminum
14 RS- 19/B-224/E Aluminum
15 PG11955 Aluminum
16 PGB10076A Aluminum
| 证书编号/Certificate No.:GB23PTB00036_02 | 7/11 |
| 17 | PX05454 | Steel | Bulkhead | A60 | 2011-09-08 | SP, Borås, Sweden |
| 18 | 4P06068 | Steel | Bulkhead | A60 | 2015-01-17 | SP, Borås, Sweden |
| 19 | 4P08662 | Steel | Bulkhead | A60 | 2015-06-08 | SP, Borås, Sweden |
| 20 | RS- 18/B- 181/E | Steel | Bulkhead | A60 | 2018-05-07 | CTO, Gdansk, Poland |
| 21 | RS- 19/B-355/E | Steel | Bulkhead | A60 | 2019-10-16 | CTO, Gdansk, Poland |
| 22 | RS-20/B-017/E | Steel | Bulkhead | A60 | 2020-01-23 | CTO, Gdansk, Poland |
| 23 | RS-20/B- 191/E | Steel | Bulkhead | A60 | 2020-06-05 | CTO, Gdansk, Poland |
| 24 | RS-21_B-241E | Steel | Bulkhead | A60 | 2021-06-30 | CTO, Gdansk, Poland |
| 25 | RS-21/B-519/E | Steel | Bulkhead | A60 | 2021-12-15 | CTO, Gdansk, Poland |
| 26 | RS- 18/B-485/E | Steel | Bulkhead | A60 | 2018-12-10 | CTO, Gdansk, Poland |
| 27 | PGB10112A | Steel | Bulkhead | A60 | 2021-09-20 | DBI, Hvidovre, Denmark |
| 28 | RS- 19/B-035/E | Steel | Bulkhead | A60 | 2019-02-25 | CTO, Gdansk, Poland |
| 29 | PGA10650 | Steel | Bulkhead | A60 | 2015-05-18 | DBI, Hvidovre, Denmark |
| 30 | 6P04351 | Steel | Bulkhead | A60 | 2016-06-28 | SP, Borås, Sweden |
| 31 | RS-21/B-445/E | Steel | Bulkhead | A60 | 2021-10-07 | CTO, Gdansk, Poland |
| 32 | PGB10020A | Steel | Bulkhead | A60 | 2020-05-05 | DBI, Hvidovre, Denmark |
| 33 | RS-21/B-517/E | Steel | Bulkhead | A0 | 2021-12-15 | CTO, Gdansk, Poland |
| 34 | RS- 18/B-292/E | Steel | Bulkhead | A0 | 2018-08-13 | CTO, Gdansk, Poland |
| 35 | PGA11610A | Steel | Bulkhead | A0 | 2020-01-10 | DBI, Hvidovre, Denmark |
| 36 | RS-20/B-081/E | Steel | Bulkhead | A0 | 2020-03-31 | CTO, Gdansk, Poland |
| 37 | PGA11301A | Steel | Bulkhead | A0 | 2018-11-22 | DBI, Hvidovre, Denmark |
| 38 | RS- 18/B-023/E | Steel | Deck | A60 | 2018-01-29 | CTO, Gdansk, Poland |
| 39 | PGA10871A | Steel | Deck | A60 | 2018-01-16 | DBI, Hvidovre, Denmark |
| 40 | 6P02249 | Steel | Deck | A60 | 2016-08-17 | SP, Borås, Sweden |
| 41 | 4P07023 | Steel | Deck | A60 | 2015-02-04 | SP, Borås, Sweden |
| 42 | 09-346E | Steel | Deck | A60 | 2009-12-11 | Research institute of Marine Engineering, |
Tokyo, Japan
43 7P02167 Steel Deck A60 2017-08-07 SP, Borås, Sweden
44 PGB10047A Steel Deck A60 2020-11-30 DBI, Hvidovre, Denmark
45 PGB10118A Steel Deck A60 2021-11-15 DBI, Hvidovre, Denmark
46 PGA10800A Steel Deck A60 2016-05-26 DBI, Hvidovre, Denmark
47 RS- 18/B-484/E Steel Deck A60 2018-12-10 CTO, Gdansk, Poland
48 PGA10649 Steel Deck A60 2015-05-18 DBI, Hvidovre, Denmark
49 RS- 19/B-356/E Steel Deck A60 2019-10-18 CTO, Gdansk, Poland
50 PGA11611A Steel Deck A60 2020-01-11 DBI, Hvidovre, Denmark
51 5P03457 Steel Deck A60 2015-11-12 SP, Borås, Sweden
52 PGB10032A Steel Deck A60 2020-07-01 DBI, Hvidovre, Denmark
53 PGB10111A Steel Deck A60 2021-09-20 DBI, Hvidovre, Denmark
REV1
54 RS- 18/B-292/E Steel Deck A0 2018-09-13 CTO, Gdansk, Poland
55 PGB10119A Steel Deck A0 2021-11-15 DBI, Hvidovre, Denmark
56 PGA11302A Steel Deck A0 2019-01-16 DBI, Hvidovre, Denmark
58 PGB10110A Steel Deck A60 2021-04-27 DBI, Hvidovre, Denmark
3.4 Watertightness/gastightness test reports
1. MLM 010247 DNV, Malmö, Sweden
2. MLM 030473-1 DNV, Malmö, Sweden
3. MLM 060561 DNV, Malmö, Sweden
4. N1421782 DNV, Gothenburg, Sweden
5. N14254FG DNV, Gothenburg, Sweden
| 证书编号/Certificate No.:GB23PTB00036_02 | 8/11 |
  1. G Series
4.1 Product description
“Roxtec sealing system with multidiameterTM technology: G-series (steel)” consisting of Roxtec G-series steel
frames (G, GO and GHM) in sizes 1-8 and combinations thereof, bolted or welded to a steel section. The G
frame is filled with Roxtec (standard or Ex, EMC of type PE, ES and BG, BGB) halogen free RM modules.
Assembled with Roxtec wedge kit or Roxtec EMC wedge kit.
4.2 Application limitation
G-series
Application for steel pipes in terms of deck and bulkhead.
Type Division Size Pipe Pipe Frame Frame Frame insulation
position
(OD) [mm] [mm]
G series A60 Steel 1-8 and combination Steel 6-54 60 All S1582458 Rev A
Bulkhead/Deck thereof. positions
G series. A0 Steel 1-8 and combination Steel 6-54 60 All S1582478 Rev A
4.3 list of type test reports
| 1 | PGB10030A | Steel | Bulkhead | A60 | 2020-07-16 | DBI, Hvidovre, Denmark |
| 2 | RS- 17/B-395/E | Steel | Deck | A60 | 2017-10-30 | CTO, Gdansk, Poland |
| 3 | RS- 18/B-023/E | Steel | Deck | A60 | 2018-01-29 | CTO, Gdansk, Poland |
4.4 Watertightness/gastightness test reports
2. MLM 020401 DNV, Malmö, Sweden
3. MLM 030491 DNV, Malmö, Sweden
4. MLM 050410 DNV, Malmö, Sweden
| 证书编号/Certificate No.:GB23PTB00036_02 | 9/11 |
  1. SPM seals
5.1 Product description
“ Roxtec sealing system, Roxtec SPM series consisting of halogen free rubber seal in size 39-279 attached
through expansion to aluminum/steel division.
5.2 Application limitation
SPM-seal series.
Application for (Steel, Cu & CuNi) pipes in terms of deck and bulkhead.
position
(OD) [mm] [mm]
SPM in size 39-279. A60 Steel Deck Steel 8-222 44-58 Exposed/ S1583093 Rev A
Unexposed
SPM in size 39-279. A0 Steel Deck Steel 8-222 44-58 Exposed/ S1582531 Rev A
Unexposed
SPM in size 39-279. A60 Steel Steel 8-222 44-58 Exposed/ S1582516 Rev A
Bulkhead Unexposed
SPM in size 39-279. A0 Steel Steel 8-222 44-58 Exposed/ S1582546 Rev A
Bulkhead Unexposed
SPM Blind in size 39-92. A60 Steel NA NA 44-50 Exposed/ S1582554 Rev A
SPM Blind in size 39-92. A0 Steel NA NA 44-50 Exposed/ S1582555 Rev A
SPM in size 39-279. A60 Steel Deck Copper & 8-222 44-58 Exposed/ S1582594 Rev A
CuNi Unexposed
SPM in size 39-279. A60 Steel Copper & 8-222 44-58 Exposed/ S1582596 Rev A
Bulkhead CuNi Unexposed
SPM in size 39-279. A0 Steel Deck Copper & 8-222 44-58 Exposed/ S1582598 Rev A
CuNi Unexposed
SPM in size 39-279. A0 Steel Copper & 8-222 44-58 Exposed/ S1582599 Rev A
SPM in size 39-279. A60 Aluminum Steel 8-222 44-58 Exposed/ S1582604 Rev A
Deck Unexposed
SPM in size 39- 157. A60 Aluminum Copper & 8-110 44-51 Exposed/ S1582611 Rev A
Deck CuNi Unexposed
SPM in size 39-279. A60 Aluminum Steel 8-222 44-58 Exposed/ S1582606 Rev A
Bulkhead Unexposed
SPM in size 39- 157. A60 Aluminum Copper & 8-110 44-51 Exposed/ S1582619 Rev A
5.3 list of type test reports
1 RS- 17/B-210/E Aluminum
2 RS- 18/B- 179/E Aluminum
3 PGA11371A Aluminum
4 RS- 17/B-209/E Aluminum
5 RS- 18/B- 180/E Aluminum
6 PGA11370A Aluminum
7 RS- 18/B- 181/E Steel
8 PGA10870A Steel
9 PGB10046A Steel
10 6P05990 Steel
| 证书编号/Certificate No.:GB23PTB00036_02 | 10/11 |
| 11 | 5P03451 | Steel | Bulkhead | A60 | 2015-11-03 | SP, Borås, Sweden |
| 12 | PGB10046A | Steel | Bulkhead | A60 | 2020-11-16 | DBI, Hvidovre, Denmark |
| 13 | 5P08346 | Steel | Bulkhead | A60 | 2015-12-21 | SP, Borås, Sweden |
| 14 | 5P03457 | Steel | Deck | A60 | 2015-11-12 | SP, Borås, Sweden |
| 15 | 5P08343 | Steel | Deck | A60 | 2015-12-21 | SP, Borås, Sweden |
| 16 | 5P08395 | Steel | Deck | A60 | 2016-03-17 | SP, Borås, Sweden |
| 17 | 6P05989 | Steel | Deck | A60 | 2016-10-24 | SP, Borås, Sweden |
| 18 | RS- 17/B- 177/E | Steel | Deck | A0 | 2017-05-26 | CTO, Gdansk, Poland |
| 19 | PGA11302A | Steel | Deck | A0 | 2019-01-16 | DBI, Hvidovre, Denmark |
| 20 | PGA11388A | Steel | Deck | A0 | 2019-08-14 | DBI, Hvidovre, Denmark |
| 21 | RS- 18/B-022/E | Steel | Bulkhead | A60 | 2018-01-29 | CTO, Gdansk, Poland |
| 22 | RS- 18/B- 181/E | Steel | Bulkhead | A60 | 2018-05-07 | CTO, Gdansk, Poland |
| 23 | RS- 18/B-023/E | Steel | Deck | A60 | 2018-01-29 | CTO, Gdansk, Poland |
| 24 | PGA10870A | Steel | Bulkhead | A60 | 2016-12-13 | DBI, Hvidovre, Denmark |
5.4 Watertightness/gastightness test reports
1. N1417RRN DNV, Malmö, Sweden
2. N1419WS4 DNV, Malmö, Sweden
3. N141805C DNV, Malmö, Sweden
| 证书编号/Certificate No.:GB23PTB00036_02 | 11/11 |
