In Transit designer, how can I active downloading "Certificate'?
There is a menu for downloading of ‘certificates’, however, it’s unactivate.
To download certificate, is there anything I need to do?
When you select the solution, you need to check the “Attach a certificate for this solution” and select a rating. When this is done, you will have the option to download the certificate.
Hi Robin,
Thanks for letting me know. I found it and checked it works well!
Thank you
