LAB035218CS-005-006-optimized
No. LAB035218CS/005
divisions
Type Roxtec SPM Seal on aluminium bulkhead
ROMBVAGEN 2, P.O. BOX 540
SE-37123 KARLSKRONA
Place of manufacture ROMBVAGEN 2, P.O. BOX 540
SE-37123 KARLSKRONA
Issued in Genoa on February 8, 2018. This Certificate is valid until February 7, 2023
No. LAB035218CS/005
Enclosure - Page 1 of 2
Roxtec S PM S eal on aluminium bulkhead
Circular pipe penetrations named SPM, composed of highly elastic EPDM rubber and fittings of stainless steel and
having diameter ranging from 39 mm (type SPM 39) up to 279 mm (type SPM 279). The bulkheads are insulated on
both sides by means of two layers of mineral wool 30 mm thick each and having density of 130 kg/m3. The division
insulation covers also the transits that are fitted with additional insulation, laid upon the bulkhead insulation, consisting
of mineral wool cylinders, equipped with steel wire, having thickness of 50 mm and density of 100 kg/m3.
Fire resistant A-60 Class metallic pipe penetrations through aluminium bulkheads as per following tables:
COPPER
TYPE OF TRANSITS - PIPE ADDITIONAL INSULATION TRANSIT FIXING AND NOTES
DIAMETER
Transit SPM 39 - pipe diameter 8 mm One layer having length of 400 mm Seal fitted on the exposed or
fitted on the unexposed side unexposed side.
Transits from SPM 39 up to SPM 157 Two layers having length of 600 mm Seal fitted on the exposed or
- pipe diameter greater than 8 mm up fitted on the unexposed side unexposed side
to 110 mm
STEEL
DIAMETER
Transit SPM 39 - pipe diameter 8 mm One layer having length of 300 mm Seal fitted on the exposed or
Transits from SPM 39 up to SPM 279 Two layers having length of 500 mm Seal fitted on the exposed or
- pipe diameter greater than 8 mm up fitted on both sides unexposed side
to 222 mm
No. LAB035218CS /005
Enclosure - Page 2 of 2
Roxtec drawings included in CTO Report No. RS-17/B-209/E dated 2 June 2017.
Tests as per CTO Report No. RS-17/B-209/E issued on 2 June 2017 according to IMO 2010 FTP Code - Annex 1 -
Part 3.
Genoa 2/02/2018
No. LAB035218CS/006
divisions
Type Roxtec SPM Seal on aluminium deck
SE-37123 KARLSKRONA
SE-37123 KARLSKRONA
No. LAB035218CS/006
Roxtec S PM S eal on aluminium deck
having diameter ranging from 39 mm (type SPM 39) up to 279 mm (type SPM 279). The decks are insulated on the
exposed side by means of two layers of mineral wool 30 mm thick each and having density of 130 kg/m3. The division
insulation covers also the transits that may be fitted with additional insulation, on the exposed side, consisting of
(mineral wool discs having the same thickness of the bulkhead insulation and /or) mineral wool cylinders, equipped with
Fire resistant A-60 Class metallic pipe penetrations through steel decks as per following tables:
COPPER
DIAMETER
unexposed side.
- pipe diameter greater than 8 mm up unexposed side
to 110 mm
STEEL
DIAMETER
Transit SPM 39 - pipe diameter 8 mm No additional insulation Seal fitted on the exposed or
unexposed side.
Transits from SPM 39 up to SPM 279 Two layers having length of 600 mm Seal fitted on the exposed or
to 222 mm
No. LAB035218CS /006
Roxtec drawings included in CTO Report No. RS-17/B-210/E dated 2 June 2017.
Tests as per CTO Report No. RS-17/B-210/E issued on 2 June 2017 according to IMO 2010 FTP Code - Annex 1 -
Part 3.
Genoa 2/02/2018
