No. LAB167420CS/001
| Description | Devices for the passage of pipes through A or B Class |
| divisions | |
| Type | Roxtec Sleeve it Marine Fire Collar |
| ROMBVAGEN 2, BOX 540 | |
| SE-37123 Karlskrona |
| Place of manufacture | ROMBVAGEN 2, BOX 540 |
| Reference standards | IMO Res. MSC.307(88)-(2010 FTP Code) |
Issued in Genoa on August 12, 2020. This Certificate is valid until August 11, 2025
No. LAB167420CS/001
Enclosure - Page 1 of 3
Roxtec S leeve it Marine Fire Collar
Devices for the passage of pipes and ducts through A Class decks as described in the following tables; the devices
consist of a stainless steel tubular casing, having length of 60 mm, fixed to the deck plate tack welding or bolting the
collar tabs or the continuous flange. The casings are provided of a break in order to permit the insertion of pipe and
intumescing material and have a toggle clip arrangement located at the break used to secure the casings around the
pipes.
Plastic pipes - A-60 Class
| DIAM ETER (mm) | INSTALLATION ON | INTUM ESCING M ATERIAL | NO. OF LAYERS OF INT. |
| EXPOSED SIDE / | TYPE AND THICKNESS | M ATERIAL | |
| UNEXPOSED SIDE | |||
| from 16 up to 50 | Exposed or unexposed | TRP 345 – 1.8 mm | from 2 up to 3 |
| from 51 up to 225 | Exposed or unexposed | INTUM EX L - 2.5 mm | from 3 up to 8 |
| from 226 up to 320 (*) | Exposed | INTUM EX L - 2.5 mm | 10 |
| (*) the casing length is 122 mm |
Plastic pipes - A-0 Class
| from 16 up to 50 | Exposed | TRP 345 – 1.8 mm | from 2 up to 3 |
PE-ALU-PE pipes - A-60 Class
| 63 | Exposed or unexposed | INTUM EX L - 2.5 mm | 3 |
PE-ALU-PE pipes - A-0 Class
| 32 | Exposed | INTUM EX L - 2.5 mm | 3 |
No. LAB167420CS /001
Enclosure - Page 2 of 3
Pre-insulated thermoplastic pipes - A-60 Class
| 75 | Exposed | INTUM EX L - 2.5 mm | 4 |
| Additional insulation - non | |||
| combustible mineral wool | |||
| cylinder, 2 layers, thickness | |||
| 45+45 mm, density of 90 kg/m3 | |||
| and width of 100 mm around the | |||
| pipe | |||
| Sealing by means of Sika Fire Seal | |||
| M arine N on the unexposed side | |||
| 315 | Exposed | INTUM EX L - 2.5 mm | 10 |
| pipe | |||
Notes:
• two pipes, 160 mm diameter PB and 16 mm diameter uPVC fitted with Sleev-it pipe seals and Sleev-it intumescent sealant, were subjected
to a hydrostatic test and an air pressure test respectively at 1 bar and 0.02 bar and no leakage was reported after 30 minutes, as detailed in the
DNV Test Report No. LDN-08-045 dated 31 January 2008.
• two fire collar incorporating intumescent seal and elastomer pipe sealing ring (Sleev-it drawing No. SI/09/031 Rev. A dated 25 August 2009)
having diameter of 16 mm and 110 mm, were subjected to a hydrostatic test and an air pressure test respectively at 3.5 bar and 1 bar and no
leakage was reported after 30 minutes, as detailed in the Lloyd’s Register Certificate No. SOU 0901586/1 dated 8 January 2010.
Fire resistant plastic pipes, PE-ALU-PE pipes and pre-insulated thermoplastic pipes penetration through A Class decks.
Drawings as included in Test Reports issued by:
• Warringtonfire - No. 184391/A, No. 175486/A, No. 170080/B, No. 190890/A Issue 2, No. 309638A, No. 329449
• SP - No. 6P02249, No. 6P08395, No. 5P00771, No. 5P08395
• Gerbam - No. 878/07/A/NP/R 102
• DBI - No. PGA11388A, No. PGA11611A, No. PGA110871A rev 2
Enclosure - Page 3 of 3
Tests as per test reports issued according to IMO FTP Code:
• SP No. 6P02249 dated 17 August 2016
• Warringtonfire No. 184391/A dated 17 December 2009;
• SP No. 6P08395 dated 17 March 2016
• SP No. 5P00771 dated 25 November 2015
• Warringtonfire No. 175486/A dated 31 October 2008;
• Warringtonfire No. 170080/B dated 30 April 2008;
• Gerbam No. 878/07/A/NP/R 102 dated 28 March 2007
• Warringtonfire No. 190890/A Issue 2 dated 26 May 2010;
• DBI No. PGA11388A dated 14 August 2019
• SP No. 5P08395 dated 17 March 2016
• Warringtonfire No. 309638A dated 20 September 2011;
• Warringtonfire No. 329449 dated 13 August 2013
• DBI No. PGA11611A dated 11 January 2020
• DBI No. PGA110871A rev 2 dated 16 January 2018
This certificate annuls and replaces the certificate No. LAB174915CS/001 dated 15/9/2015 due to renewal.
Genoa August 12, 2020
No. LAB167420CS/002
| divisions | |
No. LAB167420CS/002
Devices for the passage of pipes and ducts through A Class bulkheads as described in the following tables; the devices
consist of a stainless steel tubular casing, having length of 60 mm, fixed to the steel bulkhead plate tack welding or
bolting the collar tabs or the continuous flange. The casings are provided of a break in order to permit the insertion of
pipe and intumescing material and have a toggle clip arrangement located at the break used to secure the casings around
the pipes.
| 16 | Exposed or unexposed | TRP 345 – 1.8 mm | 2 |
| sealed by means of ROXTEC | |||
| Fire Sealant | |||
| from 17 up to 48 | Exposed | TRP 345 – 1.8 mm | 3 |
| 16 | Exposed | TRP 345 – 1.8 mm | 2 |
| cylinder, thickness 100 mm, | |||
| density of 100 kg/m3 and height | |||
| of 250 mm |
| from 32 up to 63 | Exposed or unexposed | INTUM EX L - 2.5 mm | 3 |
No. LAB167420CS /002
| and total height of 300 mm from | |||
| the bulkhead plate | |||
Notes:
bulkheads.
• Warringtonfire - No. 164476 B, No. 314670, No. 303585 A, No. 183387 A, No. 316943, No. 309855 A, No. 337717,
No. 307171 A
• CTO S.A. - No. RS-19/B-423/E, No. RS-19/B-424/E
• RISE - No. 7P02024
• DBI - No. PGA10870A
Tests as per Test Reports issued according to IMO FTP Code:
• Warringtonfire No. 164476 B dated 23 July 2007
• Warringtonfire No. 314670 dated 25 June 2012
• Warringtonfire No. 303585 A dated 7 April 2011
• Warringtonfire No. 183387 A dated 23 October 2009
• Warringtonfire No. 316943 dated 26 April 2012
• Warringtonfire No. 309855 A dated 23 December 2011
• CTO S.A. No. RS-19/B-423/E dated 19 November 2019
• RISE No. 7P02024 dated 8 June 2017
• DBI No. PGA10870A dated 13 December 2016
• Warringtonfire No. 337717 dated 13 May 2014
• Warringtonfire No. 307171 A Issue 2 dated 17 June 2011
• CTO S.A. No. RS-19/B-424/E dated 27 November 2019
This certificate annuls and replaces the certificate No. LAB174915CS/002 dated 15/9/2015 due to renewal.
