No. LAB259217CS/001
| Description | Devices for the passage of pipes through A or B Class |
| divisions | |
| Type | Roxtec S Series |
| ROMBVAGEN 2, P.O. BOX 540 | |
| SE-37123 KARLSKRONA |
| Place of manufacture | ROMBVAGEN 2, P.O. BOX 540 |
| Reference standards | IMO Res. MSC.307(88)-(2010 FTP Code) |
Issued in Genoa on February 8, 2018. This Certificate is valid until February 7, 2023
No. LAB259217CS/001
Enclosure - Page 1 of 3
Roxtec S S eries
Devices, composed of halogen free material packing system, for the passage of metallic pipes having diameter ranging
from 8 up to 54 mm and bundle pipes having total diameter of 22 mm through A Class aluminium bulkheads and decks.
The aluminium bulkheads and decks are insulated by means of two layers of mineral wool with aluminium foil, 30 mm
thick each and having density of 130 kg/m3 on the exposed side (decks) and on both sides (bulkhead). The division
insulation covers also the transits that may be fitted with additional insulation as described in the following tables:
BULKHEADS - METALLIC PIPES
| TYPE OF TRANSITS | TYPE OF PIPES | ADDITIONAL | TRANSIT FIXING AND |
| INSULATION | NOTES | ||
| S 1x1 | Copper pipe diameter of 10 | Mineral wool cylinder, one | The penetration is fixed to |
| mm | layer 50 mm thick having | the bulkhead plate in the | |
| density of 100 kg/m3 and | middle; the additional | ||
| length of 300 mm | insulation is fitted on the | ||
| unexposed side. | |||
| S 1x1 | Steel pipe diameter of 10 | Mineral wool cylinder, one | The penetration is fixed to |
| and 12 mm | layer 50 mm thick having | the bulkhead plate in the | |
| length of 200 mm | insulation is fitted on the | ||
| S 2x1 | Copper pipe diameter of 10 | Mineral wool cylinder, two The penetration is fixed to | |
| and 28 mm | layers 30 mm thick each | the bulkhead plate in the | |
| (compressed to 50 mm), | middle; the additional | ||
| having density of 125 kg/m 3 insulation is fitted on the | |||
| and length of 500 mm | unexposed side. | ||
| S 8x2 | Copper pipe diameter from 8 Mineral wool cylinder, one | The penetration is fixed to | |
| up to 57 mm | layer 50 mm thick having | the bulkhead plate in the | |
| Steel pipe diameter from 8 density of 100 kg/m3 and | middle; the additional | ||
| up to 54 mm | length of 200 mm (steel | insulation is fitted on the | |
| pipe) and 300 mm (copper | unexposed side. | ||
| pipe) |
No. LAB259217CS /001
Enclosure - Page 2 of 3
BULKHEADS - BUNDLE PIPES
| S 2x1 | Stainless steel – total | Mineral wool cylinder, two The penetration is fixed to | |
| diameter of 22 mm | layers 30 mm thick each | the bulkhead plate in the | |
| CuNi – total diameter of 22 (compressed to 50 mm), | middle; the additional | ||
| mm | having density of 125 kg/m3 insulation is fitted on the | ||
| and length of 400 mm | unexposed side. | ||
| S 8x2 | Stainless steel – total | Mineral wool cylinder, two The penetration is fixed to | |
| diameter of each bundle pipe layers 30 mm thick each | the bulkhead plate in the | ||
| 32 mm | (compressed to 50 mm), | middle; the additional | |
| having density of 125 kg/m3 insulation is fitted on the | |||
DECKS - METALLIC PIPES
| S 1x1 | Steel pipe diameter of 10 | Mineral wool cylinder, one The penetration is fixed to | |
| mm | layer 50 mm thick having the deck plate in the middle, | ||
| density of 100 kg/m3 and exposed or unexposed side; | |||
| length of 400 mm | the additional insulation is | ||
| fitted on the exp. side. | |||
| S 8x2 | Steel pipe diameter from 8 | Mineral wool cylinder, one The penetration is fixed to | |
| up to 54 mm | layer 50 mm thick having the deck plate in the middle, | ||
| S 1x1 | Copper pipe diameter of | Mineral wool cylinder, two The penetration is fixed to | |
| 10mm | layers 50 mm thick each, the deck plate in the middle, | ||
| having density of 100 | exposed or unexposed side; | ||
| kg/m3 and length of 500 | the additional insulation is | ||
| mm | fitted on the exp. side. | ||
| S 8x2 | Copper pipe diameter from | Mineral wool cylinder, one The penetration is fixed to | |
| 10 up to 57 mm | layer 50 mm thick having the deck plate in the middle, | ||
| length of 500 mm | the additional insulation is | ||
Enclosure - Page 3 of 3
Fire resistant A-60 Class pipe penetrations through load-bearing aluminium bulkheads and decks.
Roxtec drawings enclosed in SP Test Report No. P603001 dated 23 January 2007, SINTEF Test Report No.
103070.33B dated 17 November 2004, DANAK Test Reports No. PG11898 and No. PG11955 dated 17 April 2009 and
CTO Test Report No. RS-17/B-210/E dated 2 June 2016 .
Tests as per SP Test Report No. P603001 dated 23 January 2007, SINTEF Test Report No. 103070.33B dated 17
November 2004, DANAK Test Reports No. PG11898 and No. PG11955 dated 17 April 2009 issued according to IMO
Res. A.754 (18) and CTO Test Report No. RS-17/B-210/E dated 2 June 2016 issued according to IMO 2010 FTP
Code.
