LAB259217CS-002-optimized
No. LAB259217CS/002
divisions
Type Roxtec RS Series
ROMBVAGEN 2, P.O. BOX 540
SE-37123 KARLSKRONA
Place of manufacture ROMBVAGEN 2, P.O. BOX 540
SE-37123 KARLSKRONA
Issued in Genoa on February 8, 2018. This Certificate is valid until February 7, 2023
No. LAB259217CS/002
Enclosure - Page 1 of 7
Roxtec RS S eries
Devices, composed of halogen free material packing system, for the passage of pipes having diameter ranging from 6
up to 330 mm and bundle pipes having total diameter ranging from 16 up to 50 mm through A Class aluminium and
steel bulkheads and decks. The division insulation covers also the transits that may be fitted with additional insulation.
The aluminium bulkheads and decks are insulated by means of two layers of mineral wool with aluminium foil, 30 mm
thick each and having density of 130 kg/m3 on the exposed side (decks) and on both sides (bulkhead). The steel
bulkheads and decks are insulated with different configuration described in the following tables:
ALUMINIUM DIVISIONS
BULKHEADS - METALLIC PIPES
TYPE OF TRANSITS TYPE OF PIPES ADDITIONAL TRANSIT FIXING AND
INSULATION NOTES
From RS 23 up to RS 75 Metallic pipes – diameter Mineral wool cylinder, one The penetration is fixed to
from 8 up to 28 mm layer 50 mm thick having the bulkhead plate in the
density of 100 kg/m3 and middle; the additional
length of 250 mm insulation is fitted on the
unexposed side.
From RS 27 up to RS 100 Metallic pipes – diameter Mineral wool cylinder, one The penetration is fixed to
greater than 28 up to 57 mm layer 50 mm thick having the bulkhead plate in the
length of 300 mm insulation is fitted on the
unexposed side.
From RS 100 up to RS 150 Metallic pipes – diameter Mineral wool cylinder, one The penetration is fixed to
greater than 57 up to 108 layer 50 mm thick having the bulkhead plate in the
mm density of 100 kg/m3 and middle; the additional
length of 600 mm insulation is fitted on the
unexposed side.
No. LAB259217CS /002
Enclosure - Page 2 of 7
BULKHEADS - BUNDLE PIPES
INSULATION NOTES
From RS 43 up to RS 100 Stainless steel – total Mineral wool cylinder, two The penetration is fixed to
diameter from 16 up to 50 layers 30 mm thick each the bulkhead plate in the
mm (compressed to 50 mm), middle; the additional
having density of 125 kg/m3 insulation is fitted on the
and length of 400 mm unexposed side.
RS 50 Copper and CuNi – total Mineral wool cylinder, one The penetration is fixed to
diameter from 18 up to 20 layer 50 mm thick having the bulkhead plate in the
unexposed side.
p STYLE=" page-break-after: always" >
BULKHEADS - FIBERGLASS PIPES
INSULATION NOTES
From RS 68 up to RS 125 Fiberglass – diameter from Mineral wool cylinder, two The penetration is fixed to
32 up to 89 mm layers 30 mm thick each the bulkhead plate in the
and length of 400 mm for unexposed side.
seal size RS 68 up to 500
mm for seal size from RS
68 up to RS 125
Enclosure - Page 3 of 7
DECKS - METALLIC PIPES
INSULATION NOTES
From RS 23 up to RS 75 Metallic pipes – diameter Mineral wool cylinder, with The penetration may be
greater than 8 up to 28 mm steel net - one layer 50 mm fixed to the deck plate in the
thick having density of 100 middle, exposed or
kg/m3 and length of 300 unexposed side; the
mm additional insulation is fitted
on the exposed side.
From RS 75 up to RS 100 Metallic pipes – diameter Mineral wool cylinder, with The penetration may be
greater than 28 up to 57 mm steel net - one layer 50 mm fixed to the deck plate in the
kg/m3 and length of 400 unexposed side; the
From RS 100 up to RS 150 Metallic pipes – diameter Mineral wool cylinder, with The penetration may be
greater than 57 up to 108 steel net - one layer 50 mm fixed to the deck plate in the
mm thick having density of 100 middle, exposed or
3
kg/m and length of 600 unexposed side; the
DECKS - FIBERGLASS PIPES
INSULATION NOTES
From RS 68 up to RS 125 Fiberglass – diameter from Mineral wool cylinder, with The penetration may be
32 up to 90 mm steel net - one layer 50 mm fixed to the deck plate in the
kg/m3 and length of 200 unexposed side; the
Enclosure - Page 4 of 7
STEEL DIVISIONS
BULKHEADS - insulated by means of two layers of mineral wool having thickness of 50 and 30 mm and density of 100
kg/m3 – METALLIC PIPES
INSULATION NOTES
RS 25 steel pipes – diameter 6 mm No additional insulation The penetration is fixed to
middle.
From RS 25 up to RS 50 Steel pipes – diameter Mineral wool cylinder, with The penetration is fixed to
greater than 6 up to 28 mm steel net - one layer 60 mm the bulkhead plate in the
thick having density of 100 middle; the additional
kg/m3 and length of 300 insulation is fitted on the
mm unexposed side.
From RS 50 up to RS 400 Metallic pipes – diameter Mineral wool cylinder, one The penetration is fixed to
greater than 28 up to 330 layer 100 mm thick having the bulkhead plate in the
length of 1200 mm insulation is fitted on the
unexposed side.
RS 50 Copper pipes – diameter 28 Mineral wool cylinder, one The penetration is fixed to
length of 500 mm insulation is fitted on the
unexposed side.
BULKHEADS - insulated by means of two layers of mineral wool having, each, thickness of 50 mm and density of 200
INSULATION NOTES
RS 23 Steel pipes – diameter 10 Mineral wool cylinder - one The penetration is fixed to
unexposed side.
RS 23 Copper pipes – diameter 6 Mineral wool cylinder - one The penetration is fixed to
unexposed side.
Enclosure - Page 5 of 7
DECKS - insulated by means of two layers of ceramic wool having, each, thickness of 25 mm and density of 96 kg/m3
– METALLIC PIPES
INSULATION NOTES
From RS 23 up to RS 50 Steel pipes – diameter from Ceramic wool cylinder - The penetration may be
8 up to 28 mm four layers 25 mm thick fixed to the deck plate in the
each having density of 96 middle, exposed or
From RS 50 up to RS 150 Steel pipes – diameter Ceramic wool cylinder - The penetration may be
greater than 28 up to 114.3 four layers 25 mm thick fixed to the deck plate in the
mm each having density of 96 middle, exposed or
kg/m3 and length of 600 unexposed side; the
on both sides.
DECKS - insulated by means of two layers of mineral wool having thickness of 50 mm (density of 100 kg/m3) and 30
mm density of 125 kg/m3) – METALLIC PIPES
INSULATION NOTES
RS 23 Copper pipe – diameter 6 Mineral wool cylinder - one The penetration may be
mm layers 30 mm thick having fixed to the deck plate in the
density of 125 kg/m3 and middle, exposed or
length of 400 mm unexposed side; the
Enclosure - Page 6 of 7
DECKS - insulated by means of two layers of mineral wool having thickness of 50 and 30 mm and density of 125
INSULATION NOTES
RS 23 Steel pipes – diameter 10 Mineral wool cylinder - two The penetration may be
mm layers 25 mm thick each fixed to the deck plate in the
having density of 100 kg/m3 middle, exposed or
and length of 300 mm unexposed side; the
From RS 23 up to RS 150 Steel pipes – diameter Mineral wool cylinder - two The penetration may be
greater than 10 up to 108 layers 25 mm thick each fixed to the deck plate in the
mm having density of 100 kg/m3 middle, exposed or
and length of 450 mm unexposed side; the
RS 23 copper pipes – diameter 6 Mineral wool cylinder - two The penetration may be
From RS 23 up to RS 150 Copper pipes – diameter Mineral wool cylinder - two The penetration may be
greater than 6 up to 108 mm layers 25 mm thick each fixed to the deck plate in the
and length of 600 mm unexposed side; the
Fire resistant A-60 Class pipe penetrations through steel and load-bearing aluminium bulkheads and decks.
Enclosure - Page 7 of 7
Roxtec drawings enclosed in SP Test Report No. P603001 dated 23 January 2007, DANAK Test Reports No. PG11955
and No. PG11898 dated 17 April 2009, RIME Test reports No. 09-345 and No. 09-346 dated 11 December 2009, SP
Test Report No. P701755 dated 12 June 2007, SP Test Report No. P601740, SP Test Reprt No. P501943 dated 17
May 2005, SP Test Report No. P605253 dated 9 February 2007 and SP Test Report No. 4P06068 dated 17 January
2015.
Tests as per SP Test Report No. P603001 dated 23 January 2007, DANAK Test Reports No. PG11955 and No.
PG11898 dated 17 April 2009, RIME Test reports No. 09-345 and No. 09-346 dated 11 December 2009, SP Test
Report No. P701755 dated 12 June 2007, SP Test Report No. P601740, SP Test Reprt No. P501943 dated 17 May
2005,SP Test Report No. P605253 dated 9 February 2007 issued according to IMO Res. A.754 (18) and SP Test
Report No. 4P06068 dated 17 January 2015 issued acccording to IMO 2010 FTP Code .
Genoa 2/02/2018
