No. LAB484722CS/001
This is to certify that the product identified below satisfies the requirements of the
standard quoted under “Reference standard”
| Description | Devices for the passage of electric cables through A or B |
| Class divisions | |
| Type | ROXTEC R-Series - SLR type |
| ROMBVAGEN 2, BOX 540 | |
| SE-37123 Karlskrona |
| Place of manufacture | ROMBVAGEN 2, |
| 37165 LYCKEBY |
| Reference standards | IMO Res. MSC.307(88)-(2010 FTP Code) - Part. 3 |
Issued in Genoa on June 13, 2023. This Certificate is valid until June 12, 2028
No. LAB484722CS/001
Enclosure - Page 1 of 1
ROXTEC R-S eries - S LR type
Devices for the passage of electric cables having maximum diameter of 90 mm through A Class decks and bulkheads.
The devices are composed of rubber designated Roxylon inserted in a circular steel frame (SLR), 6 mm thick, and fitted
inside with RM Modules. The transits are fixed to the deck or bulkhead plate in the middle and are insulated as follows:
Decks - two layers of mineral wool (certified non-combustible according to the IMO FTP Code) having, each,
minimum thickness of 45mm and minimum density of 90 kg/m3 fitted on the lower side.
Bulkheads - two layers of mineral wool (certified non-combustible according to the IMO FTP Code) having, each,
minimum thickness of 45mm and minimum density of 90 kg/m3 fitted on the non-fire hazard side
On decks and bulkheads the mineral wool covers the transits and is applied all around the transits for a minimum width
of 250 mm.
DECKS
| Transit type | Minimum fill | Maximum fill | Cables - Maximum diameter |
| % | % | (mm) | |
| R50 | 1.4 | 25 | 25 |
| From R50 up to R200 | 1.4 | 20.25 | 25 |
| R200 | 0.1 | 20.25 | 90 |
| The transit type R200 may be installed also without electric cables |
BULKHEADS
| % | % | (mm) | |
| R50 | 1.4 | 20.34 | 23 |
| From R50 up to R200 | 1.4 | 20.25 | 23 |
Fire resistant A-60 Class cable transits through A Class bulkheads; fire risk on the uninsulated side.
Fire resistant A-60 Class cable transits through A Class decks.
No. LAB484722CS /001
Enclosure - Page 2 of 2
Roxtec drawings enclosed in DBI Test Report No. PGB10167A dated 18 March 2022 and No. PGB10172A dated 17
June 2022, CTO Test Reports No. RS-22/B/-153/E dated 4 May 2022, No. RS-22/B/-336/E and No. RS-22/B-338/E
dated 28 October 2022.
Tests as per DBI Test Report No. PGB10167A dated 18 March 2022 and No. PGB10172A dated 17 June 2022, CTO
Test Reports No. RS-22/B/-153/E dated 4 May 2022, No. RS-22/B/-336/E and No. RS-22/B-338/E dated 28 October
2022 issued according to 2010 FTP Code.
Note: Transits R50 – R200 were subjected to hydrostatic test (water – 6 bar) for 60 minutes and gas-tightness test
(helium – 3 bar) for 30 minutes without any leakage – test as per DNV-GL Survey report No. 141EX8Z Rev. 2 dated
10 August 2017
