LAB484722CS-002-optimized
No. LAB484722CS/002
This is to certify that the product identified below satisfies the requirements of the
standard quoted under “Reference standard”
Description Devices for the passage of electric cables through A or B
Class divisions
Type ROXTEC R-Series - SLA type
ROMBVAGEN 2, BOX 540
SE-37123 Karlskrona
Place of manufacture ROMBVAGEN 2,
37165 LYCKEBY
Reference standards IMO Res. MSC.307(88)-(2010 FTP Code) - Part. 3
Issued in Genoa on June 13, 2023. This Certificate is valid until June 12, 2028
No. LAB484722CS/002
Enclosure - Page 1 of 2
ROXTEC R-S eries - S LA type
Devices for the passage of electric cables having maximum diameter of 50 mm through A Class bulkheads and decks.
The devices are composed of rubber designated Roxylon inserted in a circular steel frame (SLA) and fitted inside with
RM Modules. The transits are insulated as follows:
Decks - one layer of mineral wool (certified non-combustible according to the IMO FTP Code) having minimum
thickness of 50 mm and minimum density of 120 kg/m3 and one layer of mineral wool (certified non-combustible
according to the IMO FTP Code) having minimum thickness of 30 mm and minimum density of 125 kg/m3 fitted on
the lower side.
Bulkheads - two layers of mineral wool (certified non-combustible according to the IMO FTP Code) having, each,
minimum thickness of 45 mm and minimum density of 90 kg/m3 fitted on the non-fire hazard side.
On decks and bulkheads the mineral wool covers the transits and is applied all around the transits for a minimum width
of 250 mm.
The transits may be fitted with additional insulation as described in the following table:
BULKHEAD
Transit type Fill Cables - TRANSIT FIXING AND NOTES
% Maximum
diameter
(mm)
R50 16 10 The penetration may be fixed on the exposed and unexposed side; when
fixed on the unexposed side, additional insulation composed of two layers
of the same mineral wool, having length of 110 mm, is to be fitted around
the cables
R100 22.10 47 The penetration may be fixed on the exposed and unexposed side; when
the cables
DECK
% Maximum
diameter
(mm)
R50 12 10 The penetration is fixed on the unexposed side; no additional insulation
fixed on the exposed side, additional insulation composed of the deck
insulation, having width of 100 mm, is to be fitted around the cables
R100 25 50 The penetration may be fixed on the exposed and unexposed side; when
No. LAB484722CS /002
Enclosure - Page 2 of 2
Fire resistant A-60 Class cable transits through A Class bulkheads; fire risk on the uninsulated side.
Fire resistant A-60 Class cable transits through A Class decks.
Roxtec drawings enclosed in CTO Test Reports No. RS-21/B/-518/E dated 15 December 2021, No. RS-22/B-152/E
dated 4 May 2022 and DBI Test Reports No. PGA10871Arev2 dated 16 January 2018 and No. PGA10800A dated 26
May 2016.
Tests as per CTO Test Reports No. RS-21/B/-518/E dated 15 December 2021, No. RS-22/B-152/E dated 4 May 2022
and DBI Test Reports No. PGA10871Arev2 dated 16 January 2018 and No. PGA10800A dated 26 May 2016 issued
according to 2010 FTP Code.
Note: Transits SLA 25 – 75 – 100 were subjected to hydrostatic test (water – 4 bar) for 60 minutes and gas-tightness
test (helium – 1.5 bar) for 30 minutes without any leakage – test as per DNV-GL Survey report No. 141EX8Z Rev. 2
dated 10 August 2017
Genoa June 13, 2023
