LAB498522CS-001-optimized
No. LAB498522CS/001
divisions
Type Roxtec SLEEV-IT FC MAR ALU on aluminium
bulkheads
ROMBVAGEN 2, P.O. BOX 540
SE-37123 KARLSKRONA
Place of manufacture ROMBVAGEN 2,
37165 LYCKEBY
Issued in Genoa on June 5, 2023. This Certificate is valid until May 9, 2028
No. LAB498522CS/001
Enclosure - Page 1 of 2
Roxtec S LEEV-IT FC MAR ALU on aluminium bulkheads
Device for the passage of plastic pipes (not reinforced and multilayer) through A Class aluminium bulkheads composed
of a stainless steel tubular casing fitted with aluminium flange tack welded to the bulkhead plate. The castings are
provided of a break in order to permit the insertion of pipe and intumescing material and have a toggle clip arrangement
located at the break in order to secure the casings around the pipes. The division insulation (certified non combustible
according to the IMO FTP CODE) covers also the transits and is applied all around the same for a minimum width of
250 mm; the transits may be fitted with additional insulation (certified non combustible according to the IMO FTP
CODE), laid upon the bulkhead insulation on the side not exposed to the fire. The values, indicated in the tables, relevant
to the mineral wool thickness and density, are to be considered as the minimum values.
Fire resistant A-60 Class plastic pipe penetrations through aluminium bulkheads as per following tables:
Bulkheads insulated on both sides by means of two layers of mineral wool, 30 mm thick each and having density of 130
kg/m3.
TYPE OF TRANSITS - PIPE DIAMETER ADDITIONAL TRANSIT FIXING
INSULATION AND NOTES
Transits from SLEEV-IT FC-MAR16M ALU up to SLEEV-IT FC-MAR110M No additional Seal fitted on the
ALU insulation exposed or unexposed
pipe diameter from 16 mm up to 110 mm side.
Transits greater than SLEEV-IT FC-MAR110M ALU up to SLEEV-IT FC- No additional Seal fitted on the
MAR225M ALU - pipe diameter greater than 110 mm up to 225mm insulation exposed side
Bulkheads insulated on both sides by means of two layers of mineral wool 40 mm thick each and density of 100 kg/m3.
TYPE OF TRANSITS - PIPE DIAMETER ADDITIONAL INSULATION TRANSIT FIXING
AND NOTES
Transits from SLEEV-IT FC-MAR160M Two layers of mineral wool 40 mm thick each Seal fitted on the
ALU up to SLEEV-IT FC-MAR200M ALU and having density of 100 kg/m3 and width of exposed or unexposed
pipe diameter from 160 mm up to 200 mm 100 mm around the pipe in case of seal fitted side. Transits fitted with
on the unexposed side Roxtec Fire Sealant
Transits greater than SLEEV-IT FC- Two layers of mineral wool 40 mm thick each Seal fitted on the
MAR200M ALU up to SLEEV-IT FC- and having density of 100 kg/m3 and width of unexposed side. Transits
MAR225M ALU - pipe diameter greater 100 mm around the pipe fitted with Roxtec Fire
than 200 mm up to 225mm Sealant
No. LAB498522CS /001
Enclosure - Page 2 of 2
Roxtec drawings included in DBI Report No. PGA10801A dated 29 August 2016 and in CTO Report No. RS-17/B-
555/E dated 15 January 2018.
Tests as per DBI Report No. PGA10801A dated 29 August 2016 and CTO Report No. RS-17/B-555/E dated 15 January
2018 issued according to IMO 2010 FTP Code - Annex 1 - Part 3.
Genoa 5/06/2023
