LAB498522CS-005-optimized
No. LAB498522CS/005
divisions
Type Roxtec RS Series
ROMBVAGEN 2, P.O. BOX 540
SE-37123 KARLSKRONA
Place of manufacture ROMBVAGEN 2,
37165 LYCKEBY
Issued in Genoa on June 5, 2023. This Certificate is valid until February 7, 2028
No. LAB498522CS/005
Enclosure - Page 1 of 6
Roxtec RS S eries
Devices, composed of halogen free material packing system, for the passage of pipes having diameter ranging from 6
up to 330 mm through A Class aluminium and steel bulkheads and decks. The aluminium bulkheads and decks are
insulated by means of two layers of mineral wool with aluminium foil (certified non-combustible according to the IMO
FTP Code), having, each, minimum thickness of 30 mm and minimum density of 130 kg/m3 on the exposed side
(decks) and on both sides (bulkhead). The steel bulkheads and decks are insulated with different configuration
described in the following tables. The division insulation covers also the transits and is applied all around the same for a
minimum width of 250 mm; the transits that may be fitted with additional insulation (certified non-combustible
according to the IMO FTP Code) as described in the following tables:
ALUMINIUM DIVISIONS
BULKHEADS - METALLIC PIPES
TYPE OF TRANSITS TYPE OF PIPES ADDITIONAL TRANSIT FIXING AND
INSULATION NOTES
From RS 23 up to RS 75 Metallic pipes – diameter Mineral wool cylinder, one The penetration is fixed to
from 8 up to 28 mm layer 50 mm thick having the bulkhead plate in the
density of 100 kg/m3 and middle; the additional
length of 250 mm insulation is fitted on the
unexposed side.
From RS 27 up to RS 100 Metallic pipes – diameter Mineral wool cylinder, one The penetration is fixed to
greater than 28 up to 57 mm layer 50 mm thick having the bulkhead plate in the
length of 300 mm insulation is fitted on the
unexposed side.
From RS 100 up to RS 150 Metallic pipes – diameter Mineral wool cylinder, one The penetration is fixed to
greater than 57 up to 108 layer 50 mm thick having the bulkhead plate in the
mm density of 100 kg/m3 and middle; the additional
length of 600 mm insulation is fitted on the
unexposed side.
No. LAB498522CS /005
Enclosure - Page 2 of 6
DECKS - METALLIC PIPES
INSULATION NOTES
From RS 23 up to RS 75 Metallic pipes – diameter Mineral wool cylinder, with The penetration may be
greater than 8 up to 28 mm steel net - one layer 50 mm fixed to the deck plate in the
thick having density of 100 middle, exposed or
kg/m3 and length of 300 unexposed side; the
mm additional insulation is fitted
on the exposed side.
From RS 75 up to RS 100 Metallic pipes – diameter Mineral wool cylinder, with The penetration may be
greater than 28 up to 57 mm steel net - one layer 50 mm fixed to the deck plate in the
kg/m3 and length of 400 unexposed side; the
From RS 100 up to RS 150 Metallic pipes – diameter Mineral wool cylinder, with The penetration may be
greater than 57 up to 108 steel net - one layer 50 mm fixed to the deck plate in the
mm thick having density of 100 middle, exposed or
3
kg/m and length of 600 unexposed side; the
DECKS - FIBERGLASS PIPES
INSULATION NOTES
From RS 68 up to RS 125 Fiberglass – diameter from Mineral wool cylinder, with The penetration may be
32 up to 90 mm steel net - one layer 50 mm fixed to the deck plate in the
kg/m3 and length of 200 unexposed side; the
Enclosure - Page 3 of 6
STEEL DIVISIONS
BULKHEADS - insulated by means of two layers of mineral wool (certified non-combustible according to the IMO FTP
Code) having minimum thickness of 50 and 30 mm and minimum density of 100 kg/m3 – METALLIC PIPES
INSULATION NOTES
RS 25 steel pipes – diameter 6 mm No additional insulation The penetration is fixed to
middle.
From RS 25 up to RS 50 Steel pipes – diameter Mineral wool cylinder, with The penetration is fixed to
greater than 6 up to 28 mm steel net - one layer 60 mm the bulkhead plate in the
thick having density of 100 middle; the additional
kg/m3 and length of 300 insulation is fitted on the
mm unexposed side.
From RS 50 up to RS 400 Metallic pipes – diameter Mineral wool cylinder, one The penetration is fixed to
greater than 28 up to 330 layer 100 mm thick having the bulkhead plate in the
length of 1200 mm insulation is fitted on the
unexposed side.
RS 50 Copper pipes – diameter 28 Mineral wool cylinder, one The penetration is fixed to
length of 500 mm insulation is fitted on the
unexposed side.
Code) having, each, minimum thickness of 50 mm and minimum density of 200 kg/m3 – METALLIC PIPES
INSULATION NOTES
RS 23 Steel pipes – diameter 10 Mineral wool cylinder - one The penetration is fixed to
unexposed side.
RS 23 Copper pipes – diameter 6 Mineral wool cylinder - one The penetration is fixed to
unexposed side.
Enclosure - Page 4 of 6
DECKS - insulated by means of two layers of ceramic wool (certified non-combustible according to the IMO FTP
Code) having, each, minimum thickness of 25 mm and minimum density of 96 kg/m3 – METALLIC PIPES
INSULATION NOTES
From RS 23 up to RS 50 Steel pipes – diameter from Ceramic wool cylinder - The penetration may be
8 up to 28 mm four layers 25 mm thick fixed to the deck plate in the
each having density of 96 middle, exposed or
From RS 50 up to RS 150 Steel pipes – diameter Ceramic wool cylinder - The penetration may be
greater than 28 up to 114.3 four layers 25 mm thick fixed to the deck plate in the
mm each having density of 96 middle, exposed or
kg/m3 and length of 600 unexposed side; the
on both sides.
Enclosure - Page 5 of 6
DECKS - insulated by means of two layers of mineral wool (certified non-combustible according to the IMO FTP
Code) having minimum thickness of 50 and 30 mm and minimum density of 125 kg/m3 – METALLIC PIPES
INSULATION NOTES
RS 23 Steel pipes – diameter 10 Mineral wool cylinder - two The penetration may be
mm layers 25 mm thick each fixed to the deck plate in the
having density of 100 kg/m3 middle, exposed or
and length of 300 mm unexposed side; the
From RS 23 up to RS 150 Steel pipes – diameter Mineral wool cylinder - two The penetration may be
greater than 10 up to 108 layers 25 mm thick each fixed to the deck plate in the
mm having density of 100 kg/m3 middle, exposed or
and length of 450 mm unexposed side; the
RS 23 copper pipes – diameter 6 Mineral wool cylinder - two The penetration may be
From RS 23 up to RS 150 Copper pipes – diameter Mineral wool cylinder - two The penetration may be
greater than 6 up to 108 mm layers 25 mm thick each fixed to the deck plate in the
and length of 600 mm unexposed side; the
Enclosure - Page 6 of 6
Fire resistant A-60 Class pipe penetrations through steel and load-bearing aluminium bulkheads and decks.
Roxtec drawings enclosed in DANAK Test Reports No. PG11955 and No. PG11898 dated 17 April 2009, RIME Test
reports No. 09-345 and No. 09-346 dated 11 December 2009 and SP Test Report No. 4P06068 dated 17 January 2015.
Tests as per DANAK Test Reports No. PG11955 and No. PG11898 dated 17 April 2009, RIME Test reports No. 09-
345 and No. 09-346 dated 11 December 2009 issued according to IMO Res. A.754 (18) and SP Test Report No.
4P06068 dated 17 January 2015 issued according to IMO 2010 FTP Code.
Genoa 5/06/2023
