LAB498522CS-006-optimized
No. LAB498522CS/006
divisions
Type Roxtec SPM Seal
ROMBVAGEN 2, P.O. BOX 540
SE-37123 KARLSKRONA
Place of manufacture ROMBVAGEN 2,
37165 LYCKEBY
Issued in Genoa on June 5, 2023. This Certificate is valid until February 7, 2028
No. LAB498522CS/006
Enclosure - Page 1 of 2
Roxtec S PM S eal
Circular pipe penetrations named SPM, composed of highly elastic EPDM rubber and fittings of stainless steel and
having diameter ranging from 39 mm (type SPM 39) up to 279 mm (type SPM 279). The transits may be installed on
the exposed or the unexposed side. The divisions are insulated by means of two layers of mineral wool (certified non-
combustible according to the IMO FTP Code) having, each, minimum thickness of 30 mm thick and minimum density
of 130 kg/m3; the bulkheads are fitted with the insulation on both sides whereas the decks on the lower side. The
division insulation covers also the transits and is applied all around the same for a minimum width of 250 mm; the
transits may be fitted with additional insulation, laid upon the division insulation, consisting of mineral wool cylinders
equipped with steel wire (certified non-combustible according to the IMO FTP Code), having minimum thickness of 50
mm and minimum density of 100 kg/m3.
Fire resistant A-60 Class metallic pipe penetrations through aluminium bulkheads as per following tables:
COPPER
TYPE OF TRANSITS - PIPE DIAMETER ADDITIONAL INSULATION
Transit SPM 39 - pipe diameter 8 mm One layer having length of 400 mm fitted on the
unexposed side
Transits from SPM 39 up to SPM 157 - pipe diameter Two layers having length of 600 mm fitted on the
greater than 8 mm up to 110 mm unexposed side
STEEL
Transit SPM 39 - pipe diameter 8 mm One layer having length of 300 mm fitted on the
unexposed side
Transits from SPM 39 up to SPM 279 - pipe diameter Two layers having length of 500 mm fitted on both sides
greater than 8 mm up to 222 mm
No. LAB498522CS /006
Enclosure - Page 2 of 2
Fire resistant A-60 Class metallic pipe penetrations through aluminium decks as per following tables:
COPPER
Transit SPM 39 - pipe diameter 8 mm One layer having length of 400 mm fitted on the exposed
side
Transits from SPM 39 up to SPM 157 - pipe diameter Two layers having length of 600 mm fitted on the exposed
greater than 8 mm up to 110 mm side
STEEL
Transit SPM 39 - pipe diameter 8 mm No additional insulation
Transits from SPM 39 up to SPM 279 - pipe diameter Two layers having length of 600 mm fitted on the exposed
greater than 8 mm up to 222 mm side
Roxtec drawings included in CTO Reports No. RS-17/B-209/E and No. RS-17/B-210/E dated 2 June 2017.
Tests as per CTO Reports No. RS-17/B-209/E and No. RS-17/B-210/E issued on 2 June 2017 according to IMO 2010
FTP Code - Annex 1 - Part 3.
Genoa June 5, 2023
