LR2051699SF-02-optimized
Certificate No: LR2051699SF-02
Issue Date: 09/02/2020
Expiry Date: 08/02/2025
Certificate Of Fire Approval
This is to certify that the product detailed below will be accepted for compliance with the applicable Lloyd’s Register
Rules and Regulations and with the International Convention for the Safety of Life at Sea, (SOLAS), 1974, as
amended, for use on ships and offshore installations classed with Lloyd’s Register, and for use on ships and offshore
Address Rombvägen 2, Box 540, S-371 23 Karlskrona, Sweden
| Type | Pipe Penetration (Standard Fire Test combined with Water Tightness Test) |
| Description | Fire Resisting Plastic Pipe Penetration Seals – Type: “RS PPS/S” (Back-to-Back |
Arrangement) series fitted to ensure the watertight integrity of a bulkhead
where heat-sensitive materials are used.
Trade Name RS PPS/S F+WT
| Specified Standard | SOLAS Chapter II-1 Regulation 13 – Openings in watertight bulkheads below |
the bulkhead deck in passenger ships including amendment IMO MSC 98/23/
Add.1, Annex 12, Regulation 13.2.3.
specimen tested. The manufacturer should notify Lloyd’s Register Canada Limited of any modification or changes to
the equipment in order to obtain a valid Certificate.
The Design Appraisal Document and its supplementary Type Approval Terms and Conditions form part of this
Certificate.
Bruce McDonald
Fire and Safety Lead Specialist to
Lloyd’s Register North America, Inc. Lloyd’s Register Americas Inc.
1330 Enclave Parkway, Suite 200, Houston, TX 77077, USA. A member of the Lloyd’s Register group
Lloyd’s Register Group Limited, its affiliates and subsidiaries and their respective officers, employees or agents are, individually and collectively, referred
to in this clause as ‘Lloyd’s Register’. Lloyd’s Register assumes no responsibility and shall not be liable to any person for any loss, damage or expense
caused by reliance on the information or advice in this document or howsoever provided, unless that person has signed a contract with the relevant
Lloyd’s Register entity for the provision of this information or advice and in that case any responsibility or liability is exclusively on the terms and
conditions set out in that contract.
TA02 1.0.0
Page 2 of 3
Reference: UKITSO/FIRE/TA/BM/WP39320227
ATTACHMENT TO CERTIFICATE OF FIRE APPROVAL No. LR2051699SF-02
The undernoted documents have been appraised for compliance with the relevant requirements of International
Conventions, and this Design Appraisal Document forms part of the Certificate.
APPROVAL DOCUMENTATION
01. Roxtec RS PPS/S F+WT Roxtec product sheet
02. Roxtec RS PPS/S standard Roxtec product sheet
03. RS PPS/S product information drawing S1011273
04. Insulation drawing S1558595 Rev. A
TEST REPORTS
  1. N141NBR5 Dated 2018-11-05 Including Roxtec test report DOC-002562 dated 2018-10-31
  2. N141RA6Z Dated 2019-01-24 Including Roxtec test report DOC-002621 dated 2019-01-23
  3. N141S7E5 Dated 2019-03-10 Including Roxtec test report DOC-002676 dated 2019-03-05
  4. N141SGZW Dated 2019-03-10 Including Roxtec test report DOC-002700 dated 2019-03-06
  5. N141SMF7 Dated 2019-03-15 Including Roxtec test report DOC-002718 dated 2019-03-13
  6. N141SMF8 Dated 2019-03-15 Including Roxtec test report DOC-002719 dated 2019-03-13
  7. N141SRGA Dated 2019-03-15 Including Roxtec test report DOC-002736 dated 2019-03-15
  8. N141UBRY Dated 2019-08-07 Including Roxtec test report DOC-002962 dated 2019-08-07
  9. N141W15W Dated 2019-09-30 Including Roxtec test report DOC-003037 dated 2019-09-09
  10. N141Y94A Dated 2020-02-20 Including Roxtec test report DOC-003037 dated 2020-02-18
  11. N141Y94C Dated 2020-02-24 Including Roxtec test report DOC-003037 dated 2020-02-18
  1. Production items are to be manufactured in accordance with a quality control system which shall be maintained to
    ensure that items are of the same standard as the approved prototype.
  2. The certificate holder is solely responsible for the products supplied under this Certificate and to ensure that their
    products, whether manufactured by themselves or their licensee manufacturers, if agreed by Lloyd’s Register, are fully
    compliant with the relevant statutory regulations and Lloyd’s Register Class rules as applicable and designed,
    manufactured and installed to the same quality and specifications as the prototype tested, including components that are
designed and manufactured by third parties.
  1. When used in conjunction with watertight steel bulkheads with approved insulation arrangements in accordance with
    drawing S1558595 Rev. A. For applications in watertight bulkheads on passenger and SPS vessels in accordance with SOLAS
    Ch. II-1 Reg. 13.2.3 (2014 edition) including amendment IMO MSC 98/23/Add.1, Annex 12, Regulation 13.2.3 and IMO
    MSC/Circ. 736 Paragraph 2.1. If the flag Administration has specific requirements, this will prevail.
  2. Roxtec RS PPS/S F+WT heat sensitive pipe penetration system consists of two round rubber seals fitted around the pipe
    on both sides of an extended steel sleeve generating a “back-to-back arrangement”. The two seals incorporates
    intumescent strips at the centre, which expands extensively when exposed to high temperature. The sleeve or frame shall
    have a centred position in the bulkhead, and be welded to it.
Page 3 of 3
  1. The penetration seal system is subjected to hydrostatic pressure test at 2 bar for 60 minutes without any leakage, after
    having undergone a standard A-class fire test. Tightness test pressure is applied to the same side of the division which is
    exposed to the fire test. The results achieved are as described in the table below:
Pipe tested nominal Length of
Material diameter Pipe System Size Range
ABS 16mm-110mm RS PPS/S 43-150 (BTB)
PB 16mm-110mm RS PPS/S 43-150 (BTB)
PE/HDPE 16mm-110mm RS PPS/S 43-150 (BTB)
PP/PPR/PPML/PPFR 16mm-110mm RS PPS/S 43-150 (BTB)
PVC (inc uPVC & cPVC) 16mm-110mm RS PPS/S 43-150 (BTB) 600mm
PVDF 16mm-110mm RS PPS/S 43-150 (BTB)
PE/AL/PE 16mm-63mm RS PPS/S 43-100 (BTB)
PLACES OF PRODUCTION
Bruce McDonald
Lloyds Register Americas
This Certificate and Design Appraisal Document relates to type approval, it certifies that the prototype(s) of the product(s)
referred to herein has/have been found to meet the applicable design criteria for the use specified herein, it does not mean
or imply approval for any other use, nor approval of any products designed or manufactured otherwise than in strict
conformity with the said prototype(s).
