LR22451596SF Cert Merged Version 1_signed-optimized
Certificate No: LR22451596SF
Issue Date: 07/03/2021
Expiry Date: 06/03/2026
Certificate Of Fire Approval
This is to certify that the product(s) detailed below will be accepted for compliance with the applicable Lloyd’s
Register Rules and Regulations for use on offshore units classed with Lloyd’s Register, and for use on offshore units
and onshore facilities when authorised by contracting governments to issue the relevant certificates, licences,
permits etc.
Address Box 540, S37123, Karlskrona, Sweden
| Type | Cable Penetration (Jet Fire Test) |
| Description | Multi Cable and Pipe (Rectangular) Transit – Type “Roxtec RM Module Multi- |
Diameter Penetration Seals” for Jet Fire applications
Trade Name “Roxtec RM Module Multi-Diameter Penetration Seals”
| Specified Standard | Health and Safety Executive, Offshore Technology Report – OTI 95 634 “Jet Fire |
Resistance Test of Passive Fire Protection Materials”
specimen tested. The manufacturer should notify Lloyd’s Register North America, Inc. of any modification or
changes to the equipment in order to obtain a valid Certificate.
The Design Appraisal Document and its supplementary Type Approval Terms and Conditions form part of this
Certificate.
Bruce McDonald
Technical Authority - Statutory to Lloyd’s
1330 Enclave Parkway, Houston, Texas, 77077, Register North America, Inc.
United States A member of the Lloyd’s Register group
Lloyd’s Register Group Limited, its affiliates and subsidiaries and their respective officers, employees or agents are, individually and collectively,
referred to in this clause as ‘Lloyd’s Register’. Lloyd’s Register assumes no responsibility and shall not be liable to any person for any loss, damage or
expense caused by reliance on the information or advice in this document or howsoever provided, unless that person has signed a contract with the
relevant Lloyd’s Register entity for the provision of this information or advice and in that case any responsibility or liability is exclusively on the terms
and conditions set out in that contract.
TA03 2.0
Page 2 of 4
| DESIGN APPRAISAL DOCUMENT | Reference: | UKITSO/FIRE/TA/BM/WP42704607/PRJ11100310102 |
ATTACHMENT TO CERTIFICATE OF TYPE APPROVAL No. LR22451596SF
The undernoted documents have been appraised for compliance with the relevant requirements of International Conventions, and
this Design Appraisal Document forms part of the Certificate.
This Certificate is a Renewal of Certificate Number SAS F160134
TEST REPORTS
SINTEF Energy, Norwegian Fire Research Laboratory, Trondheim, Norway Test Report No. 846031.02 dated 4 November 1997.
SINTEF Energy, Norwegian Fire Research Laboratory, Trondheim, Norway Test Report No NBL-107332 dated 3.May 2005.
RISE Fire Research AS Norway, Test Reports F17 120000-15:2 6.July.2017, 120000-56 dated 26.November 2019, 120000-59 V2
dated 8.June 2020, 120000-67-V2 dated 17.September 2020, F19 120000-48:2 dated 14.March 2019, F19 120000-48:1 dated
12.March 2019
SP Fire Research AS, Trondheim, Norway; Assessment Report No: SPFR Report F15 20119-1 Issue 1 dated 29 January 2015
1. When used in conjunction with suitably insulated divisions:
Single barrier transit, the rear face (unexposed to a fire) of the elastomeric blocks is uninsulated
Double barrier transit, the face unexposed to a fire is completely insulated
2. Application in each case to be approved by Lloyd’s Register at the design stage.
3. Single barrier transit is located in 10 mm thick steel recess which is of the same width and height as penetration seal but
the transit front face which is exposed to the fire is set back a minimum of 340 mm from the fire side.
4. Double barrier transit is to include a minimum air gap of 250mm between the inner barrier faces.
5. Frame types SOBTB, SFBTB, SFOBTB and SRBTB also accepted as well as frame types SK (single transit) and SBTB (double
transit), in sizes 1-8 and combinations of up to a maximum equivalent size of 580mm high x 130mm wide x 300mm deep.
6. May be used with cables similar to the sizes tested and steel pipes up to 30mm maximum outside diameter.
7. Production items are to be manufactured in accordance with a quality control system which shall be maintained to
ensure that items are of the same standard as the approved prototype.
8. The certificate holder is solely responsible for the products supplied under this Certificate and to ensure that their
products, whether manufactured by themselves or their licensee manufacturers, if agreed by Lloyd’s Register, are fully
compliant with the relevant statutory regulations and Lloyd’s Register Class rules as applicable and designed,
manufactured and installed to the same quality and specifications as the prototype tested, including components that
are designed and manufactured by third parties.
9. The test laboratory is solely responsible for all tests performed within the scope of this certificate and to ensure that the
testing is conducted in full compliance with the relevant test standard, approved operational procedures, statutory
regulations and Lloyd’s Register requirements as applicable and to meet client objectives as per contractual agreements
or expense caused by reliance on the information or advice in this document or howsoever provided, unless that person has signed a contract with
the relevant Lloyd’s Register entity for the provision of this information or advice and in that case any responsibility or liability is exclusively on the
terms and conditions set out in that contract.
Page 3 of 4
ATTACHMENTS TO CERTIFICATE
Certificate Fire rating Temp time Service
drawing duration
20min HHF JetFire (350 kW/m2) and 35 min
S1563775 -
ext.pool fire (250 kW/m2)
20min HHF JetFire (350 kW/m2) and 10 min
S1563775 - Steel pipe 6-30mm and Marine cables 10-
82mm
15min HHF JetFire (350 kW/m2) and 30 min
S1563775 JetFire (250 kW/m2) and 75min poolfire (150 -
kW/m2)
15min HHF JetFire (350 kW/m2) and 20 min Steel pipe 6-30mm and Marine cable 10-
S1563775 -
JetFire (250 kW/m2) 90mm
30min HHF JetFire (350 kW/m2) and 30 min
S1563776 60
JetFire (250 kW/m2)
Steel pipe 6-30 and Marine cable 10-82mm
S1563776 60min HHF JetFire (350 kW/m2)
Steel pipe 16mm and Marine cable 10-
20min HHF JetFire (350 kW/m2) and 40 min 49mm
S1563776 60
PoolFire (200 kW/m2)
Page 4 of 4
S37123 Karlskrona
Bruce McDonald
Technical Authority-Statutory
Lloyd’s Register Americas
This certificate and Design Appraisal Document relates to type approval, it certifies that the prototype(s) of the product(s) referred to herein
has/have been found to meet the applicable design criteria for the use specified herein, it does not mean or imply approval for any other
use, nor approval of any products designed or manufactured otherwise than in strict conformity with the said prototype(s)
