Certificate No: LR2386976SF
| Issue Date: | 01/03/2023 |
| Expiry Date: 29/02/2028 |
Certificate Of Fire Approval
This is to certify that the product detailed below will be accepted for compliance with the applicable Lloyd’s
Register Rules and Regulations and with the International Convention for the Safety of Life at Sea, (SOLAS), 1974, as
amended, for use on ships and offshore installations classed with Lloyd’s Register, and for use on ships and offshore
| Address | Box 540, S-37123 Karlskrona, Sweden |
| Type | CABLE AND PIPE PENETRATION (STANDARD FIRE TEST) |
| Description | Multi Cable and Pipe Penetration Types: “S, R, RS, and RS PPS/S” for use in |
fibre reinforced composite bulkheads and decks
| Trade Name | “S, R, RS and RS PPS/S ” |
| Specified Standard | IMO Res.MSC.307(88) (2010 FTP Code) Annex 1 Part 3 |
IMO Res.MSC.307(88) (2010 FTP Code) Annex 1 Part 11.
IMO/MSC/Circ. 1488
spe cime n te ste d. The manufacture r should notify Lloyd’s Re giste r EMEA of any modification or change s to the
The De sign Appraisal Docume nt and its supple me ntary Type Approval Te rms and Conditions form part of this
Certificate.
Keith Taylor
Team Lead Fire & Safety to Lloyd’s Register
| 71 Fenchurch Street, London, EC3M 4BS, United | EMEA |
| Kingdom | A member of the Lloyd’s Register group |
Lloyd’s Register Group Limited, its affiliates and subsidiaries and their respective officers, employees or agents are, individually and collectively,
referred to in this clause as ‘Lloyd’s Register’. Lloyd’s Register assumes no responsibility and shall not be liable to any person for any loss, damage or
expense caused by reliance on the information or advice in this document or howsoever provided, unless that person has signed a contract with the
relevant Lloyd’s Register entity for the provision of this information or advice and in that case any responsibility or liability is exclusively on the terms
and conditions set out in that contract.
TA02 2.0
| Page | 2 of 4 |
| Certificate No: | LR2386976SF |
| Expiry Date: | 29/02/2028 |
| DESIGN APPRAISAL DOCUMENT | Reference: | UKITSO/FIRE/TA/BM/WP45611213/PRJ11100353791 |
ATTACHMENT TO CERTIFICATE OF TYPE APPROVAL No. LR2386976SF
The undernoted documents have been appraised for compliance with the relevant requirements of International Conventions, and
this Design Appraisal Document forms part of the Certificate.
TEST REPORTS
Marine Advanced Research Centre, Gdansk, Poland Test reports RS-20_B_253_E dated 9 July 2020, RS-20_B_254_E dated 4 August 2020, RS-
20_B_341_E dated 22 October 2020, RS-20_B_417_E dated 19 January 2021 and RS-20_B_426_E dated 23 November 2020.
Witness reports N142177N dated 1 September 2020, N142846G dated 2 November 2021 and N141XE2C dated 19 February 2020
| 1. | For use in fibre reinforced composite divisions. |
| 2. | Sleeve/frame types SFHM, SRC, SL, SLFRS and SLFR composed of aluminium/steel or GRP with penetrations seal type S, R, RM, RS |
| and RS PPS/S. | |
| 3. | Tables below give key parameters for installation in A-60 fibre reinforced composite bulkheads and decks. |
Fiber Reinforced Composite Bulkheads A-60
Cable/Pipe
Drawing
| Sleeve/Frame type | Sleeve/Frame material | Penetration size | Cable/Pipe | Outer diameter (OD) |
| Reference | ||||
| [mm] |
| SL | GRP | R 50 - R 200 | Single/Multi- Cable | Up to 82 | S1559171 |
| SL | GRP | RS 25 - RS 125 | Single Cable | Up to 90 | S1559244 |
| SL | GRP | RS 25 - RS 150 | Steel/Titanium Pipe | 6-114 | S1559174 |
| SL | GRP | RS 25 - RS 150 | Copper Pipe | 6-108 | S1559174 |
| SL | GRP | RS PPS/S 50 - RS PPS/S 150 | Thermoplastic Pipe* | 16-110 | S1559249 |
| SL | GRP | RS PPS/S 50 - RS PPS/S 125 | PE/ALU/PE Pipe | 16-75 | S1559249 |
| SRC | GRP | 4x1 - 6x1 | Single/Multi- Cable | Up to 90 | S1559156 |
| SRC | GRP | 4x1 - 6x1 | Steel/Titanium Pipe | 6-30 | S1564191 |
| SLFR | Aluminium/Steel | R 50 - R 200 | Single/Multi- Cable | Up to 82 | S1559126 |
| SLFRS | Aluminium/Steel | RS 23 - RS 150 | Steel Pipe | 6-114 | S1559205 |
| SLFRS | Aluminium/Steel | RS 23 - RS 150 | Copper Pipe | 6-108 | S1559205 |
| SLFRS | Aluminium/Steel | RS PPS/S 31 - RS PPS/S 150 | Thermoplastic Pipe* | 16 | S1559252 |
| SLFRS | Aluminium/Steel | RS PPS/S 31 - RS PPS/S 125 | PE/ALU/PE Pipe | 16-75 | S1559252 |
| SLFRS | Aluminium/Steel | RS 50 - RS 450 | Fiberglass Composite Pipe | 30-360 | S1559245 |
| SFHM | Aluminium/Steel | 1x1 - 8x1 | Single/Multi- Cable | Up to 82 | S1559116 |
| *Thermoplastic pipe types: (PB, PP/PPR/PPML/PPFR, PE/HDPE & PVC/uPVC/cPVC) |
or expense caused by reliance on the information or advice in this document or howsoever provided, unless that person has signed a contract with
the relevant Lloyd’s Register entity for the provision of this information or advice and in that case any responsibility or liability is exclusively on the
terms and conditions set out in that contract.
| Page | 3 of 4 |
Fiber Reinforced Composite Decks A-60
Cable/Pipe
Drawing
| Sleeve/Frame type | Sleeve/Frame material | Penetration size | Cable/Pipe type | Outer diameter (OD) |
| Reference | ||||
| [mm] |
| SRC | GRP | 4x1 - 6x1 | Single/Multi- Cable | Up to 82 | S1559156 |
| SLFRS | Aluminium/Steel | RS PPS/S 31 - RS PPS/S 150 | Thermoplastic Pipe* | 16-110 | S1559252 |
| 4. | Sample penetrations underwent hydrostatic and pneumatic pressure testing as follows; |
Pneumatic Pressure
| Penetration | Hydrostatic Pressure |
| (Helium gas) | |
| SRC R20 GRP | 1.5 bar |
| R 50 | 1.5 bar |
| R 200 | 1.5 bar |
| RS 25 | 1.5 bar |
| RS 200 | 1.5 bar |
| RS PPS/S 50 | 1.5 bar |
| RS PPS/S 150 | 1.5 bar |
| 5. | Penetrations are suitable for use in fibre reinforced composite bulkheads and decks with a heat deflection temperature of 78°C or |
above.
| 6. | The construction and constituent materials of all the components of the system shall be as listed in the approval documentation and |
| are to be manufactured in accordance with recognised national or international standards, and in all cases shall be to the satisfaction |
of the attending Surveyor.
| 7. | Production items are to be manufactured in accordance with a quality control system which shall be maintained to ensure that items |
| are of the same standard as the approved prototype. | |
| 8. | The certificate holder is solely responsible for the products supplied under this Certificate and to ensure that their products, whether |
| manufactured by themselves or their licensee manufacturers, if agreed by Lloyd’s Register, are fully compliant with the relevant | |
| statutory regulations and Lloyd’s Register Class rules as applicable and designed, manufactured and installed to the same quality and | |
| specifications as the prototype tested, including components that are designed and manufactured by third parties. |
| Page | 4 of 4 |
S-37123 Karlskrona
Keith Taylor
Team Lead, Fire & Safety
Fire & Safety, Statutory Discipline Team
UK&I Technical Support Office, Marine & Offshore
Lloyd’s Register EMEA
This certificate and Design Appraisal Document relates to type approval, it certifies that the prototype(s) of the product(s)
referred to herein has/have been found to meet the applicable design criteria for the use specified herein, it does not mean or
imply approval for any other use, nor approval of any products designed or manufactured otherwise than in strict conformity
with the said prototype(s)
