MEDB00000NX-revision4-optimized
MEDB00000NX
4
Application of: Directive 2014/90/EU of 23 July 2014 on marine equipment (MED), issued as “Forskrift
om Skipsutstyr” by the Norwegian Maritime Authority. This Certificate is issued by DNV GL AS under the
authority of the Government of Norway.
Roxtec sealing system with multidiameter technology: RS PPS and RS PPS/S (AL)
Regulation (EU) 2020/1170,
item No. MED/3.26b. SOLAS 74 as amended, Regulation II-2/9, IMO MSC.1/Circ.1276, IMO
2010 FTP Code and IMO MSC.1/1488
This Certificate is valid until 2024-08-04.
Issued at Høvik on 2020-12-04
for DNV GL AS
DNV GL local station: Digitally Signed By: Hoff, Øyvind
| Sweden CMC | Location: DNV GL Høvik, Norway |
on behalf of
Roald Vårheim
Helge Bjørnarå Notified Body
A U.S. Coast Guard approval number will be assigned to the equipment when the production module has been completed and will appear on the
production module certificate (module D, E or F), as allowed by the “Agreement between the United States of America and the EEA EFTA states
on the mutual recognition of Certificates of Conformity for Marine Equipment” signed 17 October 2005, and amended by Decision No 1/2019
dated February 22nd, 2019.
The mark of conformity may only be affixed to the above type approved equipment and a Manufacturer’s Declaration of Conformity
issued when the production-surveillance module (D, E or F) of Annex B of the MED is fully complied with and controlled by a written
inspection agreement with a Notified Body. The product liability rests with the manufacturer or his representative in accordance with
Directive 2014/90/EU.
This certificate is valid for equipment, which is conform to the approved type. The manufacturer shall inform DNV GL AS of any
changes to the approved equipment. This certificate remains valid unless suspended, withdrawn, recalled or cancelled.
Should the specified regulations or standards be amended during the validity of this certificate, the product is to be re-approved
before being placed on board a vessel to which the amended regulations or standards apply.
LEGAL DISCLAIMER: Unless otherwise stated in the applicable contract with the holder of this document, or following from mandatory law, the
liability of DNV GL AS, its parent companies and subsidiaries as well as their officers, directors and employees (“DNV GL”) arising from or in
connection with the services rendered for the purpose of the issuance of this document or reliance thereon, whether in contract or in tort
(including negligence), shall be limited to direct losses and under any circumstance be limited to 300,000 USD.
Form code: MED 201.NOR Revision: 2020-01 www.dnvgl.com Page 1 of 4
© DNV GL 2014. DNV GL and the Horizon Graphic are trademarks of DNV GL AS.
Job Id: 344.1-000153-97
Certificate No: MEDB00000NX
Revision No: 4
“Roxtec sealing system with multidiameter technology: RS PPS and RS PPS/S (AL)”
RS PPS 31-450:
consisting of an aluminium sleeve, bolted or welded to an aluminium section. The sleeve is fitted at both
ends with Roxtec RS seals (standard or EMC versions) including intumescent material in between.
RS PPS/S 31-150:
consisting of an aluminium sleeve, bolted or welded (including SLX-type sleeve) to an aluminium section.
The sleeve is fitted in with Roxtec RS PPS/S seal (standard or EMC versions) with integrated intumescent
material.
Approved for use as single plastic pipe penetration system in class A-0, A-15, A-30 and A-60 aluminium
bulkhead and deck for approved thermoplastic pipes as follows:
Table 1: Approved pipe penetration in aluminium bulkhead
material position insulation
Thermo-
RS PPS 31 - 200 16 - 160
plastic*
Thermo-
RS PPS 225 - 450 160 - 355 400 4-7 Symmetric S1541191 Rev. A
plastic*
RS PPS 31 - 150 PE/ALU/PE 16 - 110 156 4-7 Symmetric
Thermo- See
RS PPS/S 31 - 150 16 - 110 35 - 65 4-7 S1017153
plastic* drawing
  • PP, PVC, PB, ABS, PE, PVDF
Table 2: Approved pipe penetration in aluminium deck
Pipe Sleeve Seal
Thermo- Top and
plastic* Symmetric
Thermo- Top and
plastic* Symmetric
Thermo- See
plastic* drawing
Deck or bulkhead to be insulated with approved insulation according to classification covering the edge
of the aluminium frame. See insulation drawing specified in the Type Approval Documentation. For fire
class A-0, A-15 and A-30, the sleeve and pipes are to be insulated as for class A-60.
The pipe penetrations are not approved for use in watertight bulkheads on passenger ships and special
purpose ships (SPS).
The penetration system shall not be used for penetrating boundaries of tanks.
The insulation material used has to be approved according to the Marine Equipment Directive and bear
the Mark of Conformity.
Each product shall be supplied with its manual for installation and maintenance.
Form code: MED 201.NOR Revision: 2020-01 www.dnvgl.com Page 2 of 4
Revision No: 4
Test Report No. 103070.33A dated 15 November 2004 from SINTEF, Trondheim, Norway.
Test Report No. P403634 dated 30 December 2004 from SP, Borås, Sweden.
Test Report No. PG11898 dated 17 April 2009 from DBI, Hvidovre, Denmark.
Test Report No. PG11955 dated 17 April 2009 from DBI, Hvidovre, Denmark.
Test Report No. PGA10801A dated 29 August 2016 from DBI, Hvidovre, Denmark.
Test Report No. PGA11370A dated 20 February 2019 from DBI, Hvidovre, Denmark.
Test Report No. PGA11371A dated 20 February 2019 from DBI, Hvidovre, Denmark.
Test Report No. RS-19/B-020/E dated 27 May 2019 from CTO, Gdansk, Poland.
Test Report No. RS-19/B-224/E dated 1 August 2019 from CTO, Gdansk, Poland.
Assessment No. 103201.89 dated 4 August 2004 from SINTEF, Trondheim, Norway.
Drawing No. S1017153 dated 30 April 2009 from maker.
Drawing No. S1541191 Rev. A dated 26 November 2019 from maker.
Tested according to IMO FTPC Part 3 and in compliance with IMO 2010 FTP Code Ch. 8 or IMO 2010 FTP
Code Part 3.
The product or packing is to be marked with name and address of manufacturer, type designation, fire-
technical rating, MED Mark of Conformity and USCG approval number if applicable (Page 1).
Form code: MED 201.NOR Revision: 2020-01 www.dnvgl.com Page 3 of 4
Revision No: 4
RS PPS 31-450:
RS PPS/S 31-150:
material.
RS PPS 31-450:
Approved for penetration in aluminium bulkheads or decks limited to a pressure of 4.00 bar
watertightness and 2.67 bar gastightness.
RS PPS/S 31-150:
watertightness and 2.00 bar gastightness.
For bolted versions with gasket and self-tapping screws the pressure is limited to 3.33 bar
watertightness and 1.67 bar gastightness.
Test report No. MLM 020106 dated 19 December 2001 from DNV Malmö.
Test report No. SKM-04-4088 dated 16 June 2004 from DNV Stockholm.
Test report No. MLM 070656 dated 18 April 2007 from DNV Malmö.
Test report No. N142299W dated 9 November 2020 from DNV GL Malmö.
Pressure tests with water and Helium according to DNV Type Approval Programme 8.471.19-1 and Class
Programme DNVGL-CP-0165 Chapter 4, October 2017.
Form code: MED 201.NOR Revision: 2020-01 www.dnvgl.com Page 4 of 4
