| EC-TYPE EXAMINATION | MEDB0000130 |
| Revision No: | |
| CERTIFICATE (MODULE B) | 1 |
Roxtec sealing system with multidiameter technology: S-series (Al)
Regulation (EU) 2021/1158,
This Certificate is valid until 2027-03-10.
Issued at Høvik on 2022-03-11
DNV local station:
| Lars Erik Hallbeck Parelius | Sverre Olav Bergli |
| Notified Body | |
| Form code: MED 201.NOR | Revision: 2021-03 | www.dnv.com | Page 1 of 3 |
| Job Id: | 344.1-005051-3 | ||
| Certificate No: | MEDB0000130 | ||
| Revision No: | 1 |
“Roxtec sealing system with multidiameter technology: S-series (Al)”
consisting of Roxtec S-series aluminium frames (S, SO, SF, SFO, SR, SK, SRC r20, SRC r40 and SBTB) in sizes 2 - 8
and combinations thereof, welded to an aluminium section. The S frame is filled with Roxtec (standard or EMC) halogen
free RM modules. Assembled with Roxtec wedge kit (standard or EMC).
Approved for use as a single or multiple cable penetration system in class A-60 aluminium decks and bulkheads. Other
applications are subject to case-by-case approval.
around the penetration.
Table 1: Approved cable penetration in A-60 aluminium bulkhead
| Sleeve | Sleeve | |
| Type | Size | diameter |
| position | insulation | |
| [mm] | [mm] | [mm] |
| S | 2-8 | 88 |
Table 2: Approved cable penetration in A-60 aluminium deck
| Sleeve | Sleeve | |
| S | 2-8 | 83 |
Test report No. P603001 dated 23 January 2007 from SP, Borås, Sweden.
Test report No. RS-18/B-179/E dated 25 June 2018 from CTO, Gdansk, Poland.
Test report No. RS-18/B-180/E dated 25 June 2018 from CTO, Gdansk, Poland.
Test report No. RS-19/B-224/E dated 1 August 2019 from CTO, Gdansk, Poland.
Drawing No. S1571925 Rev. B dated 21 February 2022 from manufacturer.
Tested in accordance with IMO FTPC Part 3 and in compliance with IMO 2010 FTP Code Ch. 8, and in accordance with
IMO 2010 FTP Code part 3.
MED Mark of Conformity and/or USCG approval number if applicable (see page 1).
| Form code: MED 201.NOR | Revision: 2021-03 | www.dnv.com | Page 2 of 3 |
| Revision No: | 1 |
Approved for penetration in aluminium bulkheads or decks limited to a pressure of 4.00 bar watertightness and 2.67 bar
Test report No. MLM 020106 dated 19 December 2001 from DNV Malmö.
| Form code: MED 201.NOR | Revision: 2021-03 | www.dnv.com | Page 3 of 3 |
