MEDB00001MS-revision1-optimized
MEDB00001MS
Roxtec sealing system with multidiameter technology: R-series (steel)
Regulation (EU) 2021/1158,
This Certificate is valid until 2025-02-13.
Issued at Høvik on 2022-02-14
DNV local station: Digitally Signed By: Øyvind Hoff
Sweden CMC Location: DNV Høvik, Norway
on behalf of
Lars Erik Hallbeck Parelius Notified Body Sverre Olav Bergli
Form code: MED 201.NOR Revision: 2021-03 www.dnv.com Page 1 of 4
Job Id: 344.1-000153-101
Certificate No: MEDB00001MS
Revision No: 1
“Roxtec sealing system with multidiameter technology: R-series (steel)”
consisting of a steel sleeve, bolted, welded or attached through expansion (R X) to a steel section. Sleeve is fitted with a
Roxtec R frame (standard, Ex or EMC) in sizes 50-200. The R-frame is filled with Roxtec (standard, Ex or EMC) halogen
free RM modules.
Approved for use as a single or multicable penetration system in class A-0 and A-60 steel bulkheads and decks for
approved ship cables. Other applications are subject to case-by-case approval.
the penetration.
Table 1: Approved cable penetration in A-60 steel bulkhead
Max. cable Sleeve Sleeve
Sleeve Sleeve
Type Size Diameter
position insulation
[mm] [mm] [mm]
R 50 - 200 67
R SLA 50 - 100 50
RX 70 - 200 67
Table 2: Approved cable penetration in A-60 steel deck
Sleeve Sleeve
Type Size Diameter
position Insulation
[mm] [mm] [mm]
R 50 - 200 67
R SLA 50 - 100 50
RX 75 - 200 83
Table 3: Approved cable penetration in A-0 steel bulkhead
Sleeve Sleeve
Type Size Diameter
position Insulation
[mm] [mm] [mm]
R 50 - 200 67
R SLA 50 - 100 50
RX 70 - 200 10
Table 4: Approved cable penetration in A-0 steel deck
Sleeve Sleeve
Type Size Diameter
position Insulation
[mm] [mm] [mm]
R 50 - 200 39
R SLA 50 - 100 50
RX 75 - 200 83
All SL A sleeves shall be installed in accordance with Roxtec’s SL A Installation Instructions, including aperture
dimensions and tolerances, tightening torque, etc.
Please note Installation instruction for Roxtec RX attached through expansion: Aperture irregularities are
acceptable within min and max diameters. (Max Ø = Min Ø + 2mm).
Each product shall be supplied with its manual for installation and maintenance.
Test report No. P701755 dated 12 June 2007 from SP, Borås, Sweden.
Test report No. PGA10025 dated 22 December 2011 from DBI, Hvidovre, Denmark.
Form code: MED 201.NOR Revision: 2021-03 www.dnv.com Page 2 of 4
Revision No: 1
Test report No. 4P06068 dated 17 January 2015 from SP, Borås, Sweden.
Test report No. PGA10724A dated 5 February 2016 from DBI, Hvidovre, Denmark.
Test report No. PGA10800A dated 26 May 2016 from DBI, Hvidovre, Denmark.
Test report No. PGA10871A, Rev.2, dated 9 December 2016 from DBI, Hvidovre, Denmark.
Test report No. PGA10870A dated 13 December 2016 from DBI, Hvidovre, Denmark.
Test report No. 7P02167 dated 7 August 2017 from SP, Borås, Sweden.
Test report No. RS-18/B-484/E dated 10 December 2018 from CTO, Gdansk, Poland.
Test report No. RS-18/B-485/E dated 10 December 2018 from CTO, Gdansk, Poland.
Test report No. RS-18/B-255/E dated 20 August 2019 from CTO, Gdansk, Poland.
Test report No. 8P07092 dated 27 September 2019 from SP, Borås, Sweden.
Test report No. 8P07094 dated 16 January 2020 from SP, Borås, Sweden.
Drawing No. S1571128 Rev. A dated 13 October 2021 from maker.
Drawing No. S1571137 Rev. A dated 13 October 2021 from maker.
Drawing No. S1571139 Rev. A dated 13 October 2021 from maker.
Drawing No. S1571140 Rev. A dated 13 October 2021 from maker.
Drawing No. S1571823 Rev. A dated 13 October 2021 from maker.
Drawing No. S1572074 Rev. A dated 13 October 2021 from maker.
Installation instructions Roxtec SL A sleeve from Roxtec.
2010 FTP Code part 3.
MED Mark of Conformity and USCG approval number, if applicable (see page 1).
Form code: MED 201.NOR Revision: 2021-03 www.dnv.com Page 3 of 4
Revision No: 1
consisting of a steel sleeve, bolted welded or attached through expansion (R X) to a steel section. Sleeve is fitted with a
free RM modules.
Test report No. MLM 010238 dated 30 August 2001 from DNV Malmö.
Test report No. MLM 020408 dated 3 June 2001 from DNV Malmö.
Test report No. 40007647-1 dated 13 December 2011 from DNV Malmö.
Form code: MED 201.NOR Revision: 2021-03 www.dnv.com Page 4 of 4
