MEDB00001Y7-revision5-optimized
EC-TYPE EXAMINATION MEDB00001Y7
CERTIFICATE (MODULE B) 5
Roxtec sealing system with multidiameter technology: S-series (steel)
Regulation (EU) 2023/1667,
This Certificate is valid until 2027-06-13.
Issued at Høvik on 2024-01-31
Denmark CMC
Tessa Biever
Marcin Tobiasz Notified Body on behalf of
No.: 0575
Mydlak-Röder, Christine
Head of Notified Body
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 1 of 6
Job Id: 344.1-000153-122
Certificate No: MEDB00001Y7
Revision No: 5
“Roxtec sealing system with multidiameter technology: S-series (steel)”,
consisting of Roxtec S-series steel frames (S, S Ex, SF, SFHM, SO, SFO, SFOH, SR/T, SR/S, SRC r20, SRC r40, SRC
r60) in height 1-8 and width 60-120, and combinations thereof, welded or bolted to the steel sections.
The steel frame is filled with Roxtec halogen free RM modules*. Assembled with Roxtec Wedge (standard, Ex, ES or ES
Ex) and corresponding stay plates.
SK-series is an extra deep steel frame with single barrier (SK, SK Ex, SFK, SFOK, SFOHK, SRCK r20, SRCK r40,
SRCK r60).
The steel frame is fitted at one end with Roxtec halogen free RM modules*. Assembled with Roxtec Wedge (standard,
Ex, ES or ES Ex) and corresponding stay plates.
SBTB-series is an extra deep steel frame with two barriers (SBTB, SBTB Ex, SFBTB, SRBTB, SRCBTB r20, SRCBTB
r40, SRCBTB r60). The steel frame is fitted at both ends with Roxtec halogen free RM modules*. Assembled with
Roxtec Wedge (standard, Ex, ES or ES Ex) and corresponding stay plates.
  • RM modules comes in the following versions: RM, RM Ex, RM FOC, RM ES, RM ES B, RM PE, RM PE B, RM BG, RM BG B, RM ES
Ex, RM ES B Ex, RM PE Ex, RM ES B Ex , RM BG Ex, RM BG B Ex
For more details, see drawings listed under Type Examination documentation below.
Approved for use as empty, single or multiple cable penetration system in class A-0, A-15, A-30 and A-60 steel
bulkheads and decks for approved ship cables, inc. continuously welded aluminium clad cables (e.g., CLX type)
according to the tables below. Other applications are subject to case-by-case approval.
the penetration.
Table 1: Approved cable penetration in A-60 steel bulkhead.
Max. cable Sleeve Sleeve
Frame Cable Sleeve
Size diameter length
type type position
Fully insulated2).
S-series 1–8 Marine
(S1585258, 1)
Fully insulated2).
S-series 1 – 8+8x3 Marine1)
(S1585258, 2)
Fully insulated.
S-series 1 – 8+8x10 Marine1)
(S1585258, 3)
Fully insulated2).
(S1585258, 4-5)
Fully insulated.
S-series 1 – 8+8x3 CLX
(S1574575, 1)
Fully insulated on
SK-series 2 – 8+8x2 Marine1)
(S1585341, 3)
Fully insulated2).
SK-series 2 – 8+8x5 Marine
(S1585341, 4)
Partially insulated.
SBTB-series 2–8 Marine
(S1585343, 2)
  1. Fiber optic conduits of LSHF material can only be installed in FOC modules, Max size of conduit is 18 mm.
2) No insulation between cables.
Table 2: Approved cable penetration in A-0 steel bulkhead.
Frame Cable Sleeve
type Type position
None.
S-series 1 – 8+8x5 Marine1)
(S1585853, 4)
Fully insulated.
(S1585853, 5)
Fully insulated.
(S1574720, 1)
Fully insulated on both
SK-series 1 – 8+8x2 Marine1)
(S1585869, 3)
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 2 of 6
Revision No: 5
| SK-series | 1 – 8+8x5 | Marine1) | 90 | 100 – 400 | 10 | Stiffened side | None. |
(S1585869, 4)
None.
SBTB-series 2–8 Marine 1) 82 200 – 400 10 Symmetric
(S1585877, 2)
Table 3: Approved cable penetration in A-60 steel deck.
Frame Cable Sleeve
type Type position
S-series 1 – 8+8x2 Marine
(S1585258, 6 – 7)
Top side, Partially insulated.
Symmetric (S1585258, 8)
Fully insulated.
S-series 1 – 8+8x2 CLX
(S1574575, 2)
SK-series 2–8 Marine1)
(S1585341, 1)
SK-series 2 – 8+8x5 Marine1)
(S1585341, 2)
SK-series 2–8 CLX
(S1578673, 1)
(S1585343, 1)
Fully insulated with
Top side, insulation inside
SBTB-series 2–8 CLX
Symmetric frame2).
(S1578800, 1)
Table 4: Approved cable penetration in A-0 steel deck.
Frame Cable Sleeve
type type position
Top side, None.
S-series 1–8 Marine1)
Symmetric (S1585853, 1)
None.
(S1585853, 2)
Symmetric (S1585853, 3)
Fully insulated.
(S1574720, 2)
None.
SK-series 1–8 Marine1)
(S1585869, 1)
Fully insulated.
SK-series 1 – 8+8x5 Marine1)
(S1585869, 2)
Fully insulated.
SK-series 2–8 CLX
(S1578674, 1)
SBTB-series 2–8 Marine1)
(S1585877, 1)
SBTB-series 2–8 CLX
Symmetric frame2).
(S1578712, 1)
Only fire technical properties have been evaluated. Ex and EMC etc. have to be separately documented.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 3 of 6
Revision No: 5
Test report No. 09-344(E) dated 11 December 2009 from RIME, Tokyo, Japan.
Test report No. PX05454 dated 15 December 2010 from SP, Borås, Sweden.
Test report No. PGA10024 dated 21 December 2011 from DBI, Hvidovre, Denmark.
Test report No. PGA10025 dated 22 December 2011 from DBI, Hvidovre, Denmark.
Test report No. PGA10452 dated 28 May 2014 from DBI, Hvidovre, Denmark.
Test report No. PGA10453 dated 28 May 2014 from DBI, Hvidovre, Denmark.
Test report No. 4P07023 dated 4 February 2015 from SP, Borås, Sweden.
Test report No. 4P08662 dated 8 June 2015 from SP, Borås, Sweden.
Test report No. PGA10652 dated 3 July 2015 from DBI, Hvidovre, Denmark.
Test report No. PGA 10871A Rev.1 dated 31 October 2016 from DBI, Hvidovre, Denmark.
Test report No. 6P02516 dated 29 August 2016 from SP, Borås, Sweden.
Test report No. PGA10871A Rev.2 dated 31 October 2016 from DBI, Hvidovre, Denmark.
Test report No. 6P07563 dated 20 December 2016 from SP, Borås, Sweden.
Test report No. 6P10022 dated 7 March 2017 from SP, Borås, Sweden.
Test report No. RS-17/B-176/E dated 25 May 2017 from CTO, Gdansk, Poland.
Test report No. RS-17/B-177/E dated 26 May 2017 from CTO, Gdansk, Poland.
Test report No. 8P04039 dated 6 August 2018 from RISE, Borås, Sweden.
Test report No. 8P04040 dated 13 August 2018 from RISE, Borås, Sweden.
Test report No. RS-18/B-293/E dated 13 September 2018 from CTO, Gdansk, Poland.
Test report No. PGA11301A dated 22 November 2018 from DBI, Hvidovre, Denmark.
Test report No. RS-18/B-484/E dated 10 December 2018 from CTO, Gdansk, Poland.
Test report No. PGA11302A dated 19 January 2019 from DBI, Hvidovre, Denmark.
Test report No. RS-19/B-355/E dated 16 October 2019 from CTO, Gdansk, Poland.
Test report No. RS-19/B-356/E dated 18 October 2019 from CTO, Gdansk, Poland.
Test report No. RS-20/B-409/E dated 21 December 2020 from CTO, Gdansk, Poland.
Test report No. PGB10119A dated 15 November 2021 from DBI, Hvidovre, Denmark.
Test report No. PGB10172A dated 17 June 2022 from DBI, Hvidovre, Denmark.
Test report No. PGB10116A dated 2 August 2021 from DBI, Hvidovre, Denmark.
Test report No. PGB10117A dated 2 August 2021 from DBI, Hvidovre, Denmark.
Test report No. PGB10177A dated 4 November 2022 from DBI, Hvidovre, Denmark.
Test report No. RS-22/B-337/E dated 28 October 2022 from CTO, Gdansk, Poland.
Test report No. RS-22/B-425/E dated 2 January 2023 from CTO, Gdansk, Poland.
Test report No. RS-22/B-427/E dated 2 January 2023 from CTO, Gdansk, Poland.
Test report No. RS-23/B-104/E dated 25 April 2023 from CTO, Gdansk, Poland.
Test report No. RS-22/B-394/E dated 28 November 2022 from CTO, Gdansk, Poland.
Test report No. RS-23/B-105/E dated 23 May 2023 from CTO, Gdansk, Poland.
Test report No. PGB10218A dated 8 May 2023 from DBI, Hvidovre, Denmark.
Test report No. PGB10219A dated 10 May 2023 from DBI, Hvidovre, Denmark.
Test report No. PGB10651 dated 3 July 2015 from DBI, Hvidovre, Denmark.
Test report No. RS-23/B-223/E dated 30 August 2023 from CTO, Gdansk, Poland.
Test report No. RS-23/B-031/E dated 7 March 2023 from CTO, Gdansk, Poland.
Drawing No. S1574575 Rev. B dated 19 April 2022 from manufacturer.
Drawing No. S1574720 Rev. B dated 19 April 2022 from manufacturer.
Drawing No. S1578673 Rev. A dated 12 April 2024 from manufacturer.
Drawing No. S1578674 Rev. B dated 11 January 2024 from manufacturer.
Drawing No. S1578712 Rev. B dated 11 January 2024 from manufacturer.
Drawing No. S1578800 Rev. B dated 11 January 2024 from manufacturer.
Drawing No. S1585341 Rev. B dated 29 November 2023 from manufacturer.
Drawing No. S1585343 Rev. B dated 27 November 2023 from manufacturer.
Drawing No. S1585258 Rev. C dated 29 November 2023 from manufacturer.
Drawing No. S1585853 Rev. C dated 29 November 2023 from manufacturer.
Drawing No. S1585869 Rev. B dated 29 November 2023 from manufacturer.
Drawing No. S1585877 Rev. B dated 27 November 2023 from manufacturer.
Tested according to IMO FTPC Part 3 and in compliance with IMO 2010 FTP Code Ch. 8 and according to IMO 2010
FTP Code part 3.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 4 of 6
Revision No: 5
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 5 of 6
Revision No: 5
Appendix
SRCK r60).
    RM BG B, RM ES Ex, RM ES B Ex, RM PE Ex, RM ES B Ex , RM BG Ex, RM BG B Ex
For penetrations incorporation SFOHK frames, the pressure is limited to 2.67 bar watertightness.
Test report No. MLM 020106 dated 19 December 2001 from DNV, Malmö, Sweden.
Test report No. MLM 020133 dated 26 February 2002 from DNV, Malmö, Sweden.
Test report No. MLM 020408 dated 3 June 2002 from DNV, Malmö, Sweden.
Test report No. SKM-04-4088 dated 16 June 2004 from DNV, Stockholm, Sweden.
Test report No. N141CR4U Rev.1 dated 23 March 2017 from DNV, Malmö, Sweden.
Test report No. N141805F dated 27 February 2018 from DNV, Gothenburg, Sweden.
Pressure tests with water and helium according to DNV-CP-0165.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 6 of 6
