MEDB00002SA-revision4-optimized
Certificate no.:
EC-TYPE EXAMINATION MEDB00002SA
CERTIFICATE (MODULE B) 4
that the Penetrations through “A” class divisions: electric cable transits
Roxtec sealing system with multidiameter technology: RS-series (steel)
issued to
Regulation (EU) 2023/1667,
This Certificate is valid until 2027-12-20.
Issued at Høvik on 2024-05-13
Denmark CMC
Tessa Biever
Marcin Tobiasz Notified Body on behalf of
No.: 0575
Mydlak-Röder, Christine
Head of Notified Body
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 1 of 5
Job ID: 344.1-000153-125
Certificate no.: MEDB00002SA
Revision No: 4
Roxtec sealing system with multidiameter technology: RS-series (steel division)
The RS cable penetration seal consist of two halves with removable layers making it adaptable to cables of different
diameters. It is available in different versions, RS, RS OMD, RS EMC or RS EX, depending on application.
The RS-seal is installed into a steel sleeve that is either welded, bolted, attached through expansion (SLFRS X),
attached with a nut (SLA) or by threads (SL 25/M24x1.5 and SL 31/M30x2) onto the steel division.
Approved for use as a single cable penetration system in class A-0 and A-60 steel bulkheads and decks for approved
ship cables. Other applications are subject to case-by-case approval.
around the penetration.
Table 1: Approved cable penetration in A-60 steel bulkhead
Max. cable Sleeve Sleeve
RS-series Sleeve Sleeve
diameter length thickness
size type position
[mm] [mm] [mm]
Fully insulated on one side
23 - 125 SLRS-series 1) 90
(S1588058, 1)
23 - 150 SLRS-series 1)
(S1588058, 2)
Fully insulated both sides
25 - 125 SL-series 2) 90
(S1588060, 1)
Fully insulted on one side
23 - 125 SLFRS X 86
(S1588957, 1)
25 - 75 SLA 32
(S1589092, 1 – 3)
Threaded Fully insulted on one side
31 13 68
sleeve (S1575852, 1)
  1. SLRS-series includes the following sleeve types: SLRS, SLRS Ex, SLFRS, SLFRS Ex, SLFRS BG, SLFO, SLFO/RI or sleeves equal to
Roxtec dimensions specified in drawing S1586454 Rev.A
2) SL-series are longer versions of sleeves in SLRS-series
Table 2: Approved cable penetration in A-60 steel deck
size type position
[mm] [mm] [mm]
Partially insulated on one side
23 - 150 SLRS-series 1) 96
(S1588058, 3)
Fully insulated on the underside
(S1588060, 2)
25 - 150 SLFRS X 90
(S1588957, 2)
25 - 75 SLA 32
(S1589092, 4-6)
25 - 31 13 63 - 68
sleeve S1575852; No. 2
Table 3: Approved cable penetration in A-0 steel bulkhead
size type position
[mm] [mm] [mm]
None
23 – 150 SLRS-series 1) 100
(S1588955, 1)
(S1588060, 1)
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 2 of 5
Revision No: 4
23 - 150 SLFRS X 86 65 4-7 Insulated side
(S1588955, 1)
None
25 - 75 SLA 32 47 - 86 4-5 Either
(S1588065, 1)
Threaded None
31 13 68 2.3 Either
sleeve (S1575011, 1)
  1. SLRS-series includes the following sleeve types: SLRS, SLRS Ex or sleeves equal to Roxtec dimensions specified in drawing S1586454
Rev.A
Table 4: Approved cable penetration in A-0 steel deck
size type position
[mm] [mm] [mm]
Symmetric, None
23 - 150 SLRS-series 1) 93
Top side (S1588955, 2)
(S1588119, 2)
25 - 125 SLFRS X 90
(S1589097, 2)
None
25 - 75 SLA 32
(S1588065, 2)
25 - 75 SLA 32
(S1588065, 3-4)
Threaded None
31 13 68
sleeve S1575011; No. 2
Rev.A
Please note Installation instruction for SLFRS X attached through expansion: Aperture irregularities are acceptable
within min and max diameters (Max Ø = Min Ø + 2 mm).
Test report No. PGA10652 dated 3 July 2015 from DBI, Hvidovre, Denmark.
Test report No. PGA10800A dated 26 May 2016 from DBI, Hvidovre, Denmark.
Test report No. PGA10870A dated 1 November 2016 from DBI, Hvidovre, Denmark.
Test report No. PGA10871A dated 31 October 2016 from DBI, Hvidovre, Denmark.
Test report No. 6P10024 dated 7 March 2017 from SP, Borås, Sweden.
Test report No. RS-17//B-395/E dated 30 October 2017 from CTO, Gdansk, Poland.
Test report No. RS-18/B-022/E dated 29 January 2018 from CTO, Gdansk, Poland.
Test report No. 8P07092 dated 27 September 2019 from SP, Borås, Sweden.
Test report No. PGA11610A dated 1 January 2020 from DBI, Hvidovre, Denmark.
Test report No. PGA11611A dated 11 January 2020 from DBI, Hvidovre, Denmark.
Test report No. 8P07094 dated 16 January 2020 from SP, Borås, Sweden.
Test report No. RS-20/B-017/E dated 23 January 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-081/E dated 31 March 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-083/E dated 20 April 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-191/E dated 5 June 2020 from CTO, Gdansk, Poland.
Test report No. PGB10110A dated 27 April 2021 from DBI, Hvidovre, Denmark.
Test report No. PGB10118A dated 15 November 2021 from DBI, Hvidovre, Denmark.
Test report No. RS-21/B-517/E dated 15 December 2021 from CTO, Gdansk, Poland.
Test report No. RS-21/B-518/E dated 15 December 2021 from CTO, Gdansk, Poland.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 3 of 5
Revision No: 4
Test report No. PGB10169A dated 18 March 2022 from DBI, Hvidovre, Denmark.
Test report No. RS-22/B-153/E dated 8 April 2022 from CTO, Gdansk, Poland.
Test report No. 7P02024 dated 8 June 2022 from SP, Borås, Sweden.
Test report No. PGB10172A dated 17 June 2022 from DBI, Hvidovre, Denmark.
Test report No. RS-17/B-396/E dated 31 October 2017 from CTO, Gdansk, Poland.
Test report No. RS-22/B-338/E dated 28 October 2022 from CTO, Gdansk, Poland.
Test report No. RS-22/B-336/E dated 28 October 2022 from CTO, Gdansk, Poland.
Test report No. 8P07094 dated 23 September 2023 from RISE, Borås, Sweden.
Test report No. PGB10178A dated 4 November 2022 from DBI, Hvidovre, Denmark.
Test report No. PGB10176A dated 4 November 2022 from DBI, Hvidovre, Denmark.
Test report No. RS-23/B-031/E dated 7 March 2023 from CTO, Gdansk, Poland.
Test report No. PGB10177A dated 4 November 2022 from DBI, Hvidovre, Denmark.
Test report No. 6P02249 dated 17 May 2016 from SP, Borås, Sweden.
Test report No. RS-23/B-225/E dated 30 August 2023 from CTO, Gdansk, Poland.
Test report No. RS-23/B-339/E dated 3 November 2023 from CTO, Gdansk, Poland.
Drawing No. S1574995 Rev. B dated 8 August 2022 from maker.
Drawing No. S1575011 Rev. A dated 29 December 2021 from maker.
Drawing No. S1575852 Rev. A dated 31 January 2022 from maker.
Drawing No. S1586454 Rev. A dated 30 November 2022 from maker.
Drawing No. S1588957 Rev. A dated 17 November 2023 from maker.
Drawing No. S1588058 Rev. A dated 23 November 2023 from maker.
Drawing No. S1588955 Rev. A dated 17 March 2023 from maker.
Drawing No. S1589092 Rev. A dated 17 November 2023 from maker.
Drawing No. S1588065 Rev. A dated 17 November 2023 from maker.
Drawing No. S1588060 Rev. A dated 17 November 2023 from maker.
Drawing No. S1589097 Rev. A dated 17 November 2023 from maker.
Drawing No. S1588119 Rev. A dated 17 November 2023 from maker.
Tested according to IMO 2010 FTP Code Part 3.
MED Mark of Conformity and USCG approval number.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 4 of 5
Revision No: 4
The RS-seal is installed into a steel sleeve that is either welded, bolted, attached through expansion (SLFRS X) or
attached with a nut (SLA) onto the steel division.
For SLA sleeves the pressure is limited to 2.67 bar watertightness and 1.00 bar gastightness.
For longer versions of sleeves in SLRS-series the pressure is limited to 2.00 bar watertightness and 1.00 bar
Test report No. MLM 010235 dated 21 August 2001 from DNV Malmö.
Test report No. MLM 010133 dated 26 February 2002 from DNV Malmö.
Test report No. N141EX8Z Rev. 2 dated 10 August 2017 from DNV Malmö.
Test report No. DOC-004793 Rev. A dated 20 June 2022 from maker.
Pressure tests with water and helium according to DNV Type Approval Programme DNV-CP-0165.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 5 of 5
