| EC-TYPE EXAMINATION | MEDB00002SD |
| Revision No: | |
| CERTIFICATE (MODULE B) | 2 |
Roxtec sealing system with multidiameter technology: RS-series (aluminium division)
Regulation (EU) 2022/1157,
This Certificate is valid until 2028-01-02.
Issued at Høvik on 2023-01-05
| DNV local unit: | Digitally Signed By: Øyvind Hoff |
| Sweden CMC | Location: DNV Høvik, Norway |
| on behalf of |
| Marcin Tobiasz | Notified Body | Sverre Olav Bergli |
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 1 of 3 |
| Job Id: | 344.1-000153-113 | ||
| Certificate No: | MEDB00002SD | ||
| Revision No: | 2 |
“Roxtec sealing system with multidiameter technology: RS-series (aluminium division)”
The RS cable penetration seal consist of two halves with removable layers making it adaptable to a single cable of
different diameters. It is available in different versions, RS, RS OMD, RS EMC or RS EX, depending on application.
The RS-seal is installed into an aluminium sleeve that is either welded (SLRS) or attached with a steel nut (SLA) onto
the aluminium division.
Approved for use as single cable penetration system in class A-0, A-15, A-30 and A-60 aluminium bulkheads and decks.
Other applications are subject to case-by-case approval.
Approved for use in class A-0, A-15 and A-30 when the penetration system is insulated as A-60 and in addition the
division is to be insulated with A-60 insulation at least 200 mm around the penetration.
Table 1: Approved cable penetration in A-60 aluminium bulkhead.
| RS-series | Sleeve | Cable |
| diameter | length | thickness |
| size | type | type |
| [mm] | [mm] | [mm] |
| S1583484 Rev A, | ||
| 23 – 125 | SLRS1) | Marine |
| No. 1 | ||
| S1583525 Rev A, | ||
| 25 - 100 | SLA | Marine |
| No. 1 |
- SLRS-series includes the following sleeve types: SLRS, SLRS Ex or sleeves equal to Roxtec dimensions specified in drawing S1586454.
Table 2: Approved cable penetration in A-60 aluminium deck.
| RS-series | Cable | Sleeve |
| Size | diameter | length |
| size | type | position |
| (OD) [mm] | [mm] | [mm] |
| Symmetric, | S1583484 Rev A | |
| 25 – 125 | SLRS1) | Marine |
| Top side | No.2 | |
| S1583525 Rev A | ||
| No.2 |
Test report No. PGA11371A dated 20 February 2019 from DBI, Hvidovre, Denmark.
Test report No. PGB10031A dated 9 July 2020 from DBI, Hvidovre, Denmark.
Test report No. RS-17/B-210/E dated 2 June 2017 from CTO, Gdansk, Poland.
Test report No. RS-17/B-555/E dated 15 January 2018 from CTO, Gdansk, Poland.
Test report No. RS-19/B-020/E dated 27 May 2019 from CTO, Gdansk, Poland.
Test report No. RS-19/B-224/E dated 1 August 2019 from CTO, Gdansk, Poland.
Test report No. RS-20/B-410/E dated 17 December 2020 from CTO, Gdansk, Poland.
Test report No. RS-21/B-189/E dated 4 June 2021 from CTO, Gdansk, Poland.
Drawing No. S1583484 Rev. A dated 19 September 2022 from maker.
Drawing No. S1583525 Rev. A dated 20 September 2022 from maker.
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 2 of 3 |
| Revision No: | 2 |
Appendix
For SLA sleeves approved for penetration in aluminium bulkheads or decks limited to a pressure of 2.67 bar
watertightness and 1 bar gastightness.
For SLRS sleeves approved for penetration in aluminium bulkheads or decks limited to a pressure of 4 bar
watertightness and 2.67 bar gastightness.
For bolted versions with gasket and self tapping screws, the pressure is limited to 3.33 bar watertightness and 1.67 bar
For longer versions of SLRS sleeves the pressure is limited to 2 bar watertightness and 1 bar gastightness.
Test report No. N141EX8Z Rev.2 dated 10 August 2017 from DNV, Malmö, Sweden.
Test report No. MLM 010235 dated 21 August 2001
Test report No. MLM 010133 dated 26 February 2002
Test report No. MLM 020408 dated 3 June 2002
Test report No. MLM 030473-1 (RS X) dated 27 January 2003.
Pressure tests with water and helium according to DNV-CP-0165.
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 3 of 3 |
