MEDB00002SG-revision2-optimized
EC-TYPE EXAMINATION MEDB00002SG
CERTIFICATE (MODULE B) 2
Roxtec sealing system with multidiameter technology: R-series (aluminium division)
Regulation (EU) 2022/1157,
This Certificate is valid until 2028-01-25.
Issued at Høvik on 2023-02-07
Øyvind Hoff
Marcin Tobiasz Notified Body on behalf of
No.: 0575
Sverre Olav Bergli
Head of Notified Body
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 1 of 3
Job Id: 344.1-000153-115
Certificate No: MEDB00002SG
Revision No: 2
“Roxtec sealing system with multidiameter technology: R-series (aluminum division)”
The R-Series sealing system consist of a rubber frame filled with Roxtec RM modules of different sizes depending on
diameter and configuration of the cables. It is available in standard, Ex and EMC versions depending on application.
The R-seal is installed into an aluminum sleeve that is welded, a steel sleeve that are attached by expansion (SLFR X)
or a steel sleeve attached with a nut (SLA) onto the aluminum division.
Approved for use as single or multiple cable penetration system in class A-0, A-15, A-30 and A-60 aluminium bulkheads
and decks. Other applications are subject to case-by-case approval.
Approved for use in class A-0, A-15 and A-30 when the penetration system is insulated as A-60 and in addition the
division is to be insulated with A-60 insulation at least 200 mm around the penetration.
Table 1: Approved cable penetration in A-60 aluminium bulkhead.
Max. cable Sleeve Sleeve
R-series Sleeve Sleeve
diameter length thickness
size type position
[mm] [mm] [mm]
50 - 200 SLR1) 30
50 - 100 SLA 50
70 - 200 SLFR X 50
  1. SLR-Series includes the following sleeve types: SLR, SLR EX or sleeves equal to Roxtec dimensions specified in drawing S1587721.
Table 2: Approved cable penetration in A-60 aluminium deck.
size type position
[mm] [mm] [mm]
Symmetric,
50 - 200 SLR1) 67
Top side
50 - 100 SLA 50
70 - 200 SLFR X 50
Please note Installation instruction for Roxtec R X attached through expansion: Aperture irregularities are acceptable
within min and max diameters (Max Ø = Min Ø + 2 mm).
Test report No. PGA11370A dated 20 February 2019 from DIFT, Denmark.
Test report No. PGA11371A dated 20 February 2019 from DIFT, Denmark.
Test report No. RS-18/B-179/E dated 25 June 2018 from CTO, Gdansk, Poland.
Test report No. RS-19/B-224/E dated 1 August 2019 from CTO, Gdansk, Poland.
Test report No. RS-20/B-082/E dated 21 April 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-408/E dated 17 December 2020 from CTO, Gdansk, Poland.
Drawing No. S1583385 Rev. B dated 20 September 2022 from Roxtec International AB.
Drawing No. S1583387 Rev. B dated 20 September 2022 from Roxtec International AB.
Drawing No. S1583389 Rev. B dated 20 September 2022 from Roxtec International AB.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 2 of 3
Revision No: 2
“Roxtec sealing system with multidiameter technology: R-series (aluminium division)”
Approved for penetration in aluminium bulkheads or decks limited to a pressure of 4.00 bar watertightness and 2.67 bar
For SLA sleeves the pressure is limited to 2.67 bar watertightness and 1.00 bar gastightness.
Test report No. N141EX8Z Rev.2 dated 10 August 2017 from DNV, Malmö, Sweden.
Test report No. MLM 020408 dated 3 June 2001 from DNV, Malmö, Sweden.
Test report No. MLM 030473-1 (R X) dated 27 January 2003 from DNV, Malmö, Sweden.
Test report No. MLM 010238 dated 30 August 2001 from DNV Malmö, Sweden.
Pressure tests with water and Helium according to Class Programme DNV-CP-0165.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 3 of 3
