MEDB0000368-optimized
MEDB0000368
Roxtec sealing system: Roxtec SPM seal series (Aluminium divisions)
Regulation (EU) 2022/1157,
IMO MSC.1/1488
This Certificate is valid until 2027-12-19.
Issued at Høvik on 2022-12-20
DNV local station:
Digitally Signed By: Øyvind Hoff
Sweden CMC Location: DNV Høvik, Norway
on behalf of
Kristin Grønnæss Hovden Notified Body Sverre Olav Bergli
Form code: MED 201.NOR Revision: 2022-02 www.dnv.com Page 1 of 3
Job Id: 344.1-007416-2
Certificate No: MEDB0000368
Revision No: 1
“Roxtec sealing system: Roxtec SPM seal series (Aluminium divisions)”
consisting of Roxtec SPM rubber seals in size 39-279 attached to expansion to Aluminium sections.
Approved for use as a single pipe penetration system in class A-60 Aluminium bulkheads and decks as according to the
tables below. Other applications are subject to case-by-case approval.
For A-0, A-15 and A-30 applications, the penetration shall be insulated as for A-60 and the division is to be fitted with A-
60 insulation for a minimum distance of 200 mm around the penetration. For detail information about insulation please
see drawings specified in the Type Examination Documentation.
Table 1: Approved pipe penetration in A-60 aluminium bulkhead
Pipe Seal
material position
SPM 39 – 279 Steel
SPM 39 – 157 Copper
Table 2: Approved pipe penetration in A-60 aluminium deck
Pipe Seal
material position
SPM 39 – 279 Steel
SPM 39 – 157 Copper
All seals shall be installed in accordance with Roxtec’s SPM seal Installation Instructions, including aperture dimensions
and tolerances, tightening torque, etc.
Test report No. RS-17/B-209/E dated 2 June 2017 from CTO, Gdansk, Poland.
Test report No. RS-17/B-210/E dated 2 June 2017 from CTO, Gdansk, Poland.
Test report No. RS-18/B-179/E dated 25 June 2018 from CTO, Gdansk, Poland.
Test report No. RS-18/B-180/E dated 25 June 2018 from CTO, Gdansk, Poland.
Test report No. PGA11370A dated 20 February 2019 from DBI, Hvidovre, Denmark.
Test report No. PGA11371A dated 20 February 2019 from DBI, Hvidovre, Denmark.
Drawing No. S1581274 Rev. C dated 7 July 2022 from maker.
Drawing No. S1581303 Rev. C dated 7 July 2022 from maker.
Drawing No. S1581308 Rev. B dated 7 July 2022 from maker.
Drawing No. S1581082 Rev. C dated 7 July 2022 from maker.
Form code: MED 201.NOR Revision: 2022-02 www.dnv.com Page 2 of 3
Revision No: 1
Approved for penetration in aluminium bulkheads or decks for steel and copper pipes limited to a pressure of 1 bar
watertightness and 0.67 bar gastightness.
Survey Report no. N1419WS4 dated 22 June 2016 from DNV GL Malmö.
Survey Report no. N141805A dated 20 December 2016 from DNV GL Malmö.
Tested according to Class Programme DNVGL-CP-0165 Chapter 4, October 2017.
Form code: MED 201.NOR Revision: 2022-02 www.dnv.com Page 3 of 3
