MEDB000036A-revision3-optimized
MEDB000036A
3
Roxtec Sealing System with Multidiameter Technology: RS PPS and RS PPS/S series (steel)
Regulation (EU) 2021/1158,
IMO MSC.1/1488
This Certificate is valid until 2026-01-18.
Issued at Høvik on 2022-01-04
DNV local station: Digitally Signed By: Øyvind Hoff
Sweden CMC Location: DNV Høvik, Norway
on behalf of
Kristin Grønnæss Notified Body Sverre Olav Bergli
Form code: MED 201.NOR Revision: 2021-03 www.dnv.com Page 1 of 6
Job Id: 344.1-000153-102
Certificate No: MEDB000036A
Revision No: 3
“Roxtec sealing system with multidiameter technology: RS PPS and RS PPS/S series (steel)”
RS PPS 31-450
consisting of a steel sleeve, bolted or welded to a steel section. The sleeve is fitted at both ends with Roxtec RS seals
(standard or EMC versions) including intumescent material in between.
RS PPS/S 31-150
consisting of bolted or welded steel sleeve, or SLX-type sleeve attached through expansion, on to the steel sections.
The sleeve is only fitted with one single RS PPS/S seal with integrated intumescent material. Minimum thickness for
steel sleeve is 1.5 mm.
Approved for use as single and multiple pipe penetration system in class A-0, A-15, A-30 and A-60 steel bulkheads and
decks for approved plastic pipes as follows:
material position insulation
S1553577 Rev. A
RS PPS 31 - 175 Thermoplastic*
No. 1
S1553577 Rev. A
RS PPS 31 - 200 Thermoplastic*
No. 2
S1553577 Rev. A
RS PPS 225 - 450 Thermoplastic*
No. 2
Pre-insulated S1553577 Rev. A
RS PPS 125 - 200 90 - 170
thermoplastic No. 3
RS PPS 225 - 400 151 - 315
thermoplastic No. 3
RS PPS 125 75
plastic bundle No. 4
S1573861 Rev. A
RS PPS/S 31 - 150 Thermoplastic*
No. 1
S1573861 Rev. A
RS PPS/S 31 - 100 PE/ALU/PE
No. 2
Pre-insulated S1573861 Rev. A
RS PPS/S 100 - 125 67 - 96
plastic bundle No. 11
  • PP, PVC, PB, ABS, PE, PVDF
S1553577 Rev. A
No. 5
S1553577 Rev. A
RS PPS 225 – 450 Thermoplastic*
No. 5
Top, S1553577 Rev. A
symmetric No. 6
symmetric No. 6
Pre-insulated Top, S1553577 Rev. A
thermoplastic symmetric No. 7
RS PPS 125 75
plastic bundle No. 8
RS PPS 125 75 - 96
plastic bundle symmetric No. 9
S1553577 Rev. A
RS PPS 31 - 150 PE/ALU/PE
No. 10
Form code: MED 201.NOR Revision: 2021-03 www.dnv.com Page 2 of 6
Revision No: 3
S1573861 Rev. A
RS PPS/S 31 - 150 Thermoplastic* 16 - 110 35 - 65 4-7 Any
No. 3+4
S1573861 Rev. A
RS PPS/S 31 - 68 PE/ALU/PE 16 - 32 35 - 65 4-7 Any
No. 5
Top, S1573861 Rev. A
RS PPS/S 31 - 125 PE/ALU/PE 16 - 75 35 - 65 4-7
symmetric No. 6
PE/ALU/PE
RS PPS/S 31 - 125 w/ thermal 16 - 75 35 - 65 4-7
symmetric No. 7
insulation
RS PPS/S 68 - 100 Plastic bundle 36 - 60 65 4-7
symmetric No. 8
Pre-insulated Top, S1573861 Rev. A
RS PPS/S 100 - 125 67 - 96 65 7
RS PPS/S 125 - 150 75 - 110 65 7
thermoplastic symmetric No. 10
Table 3: Approved pipe penetration in A-0 steel bulkhead
S1553578 Rev. A
No. 1
S1553578 Rev. A
RS PPS 68 - 150 Thermoplastic*
No. 2
S1553578 Rev. A
No. 2
S1553578 Rev. A
No. 3
S1553578 Rev. A
No. 3
Pre-insulated S1553578 Rev. A
thermoplastic No. 4
thermoplastic No. 4
RS PPS 125 75
plastic bundle No. 5
S1553578 Rev. A
RS PPS 31 - 68 PE/ALU/PE
No. 6
S1573859 Rev. A
RS PPS/S 31 - 100 Thermoplastic*
No. 1
S1573859 Rev. A
No. 2
S1573859 Rev. A
No. 3
Pre-insulated S1573859 Rev. A
plastic bundle No. 12
Table 4: Approved pipe penetration in A-0 steel deck
S1553578 Rev. A
No. 7
S1553578 Rev. A
No. 7
Top, S1553578 Rev. A
RS PPS 31 – 200 Thermoplastic*
symmetric No. 8
symmetric No. 8
Pre-insulated Top, S1553578 Rev. A
thermoplastic symmetric No. 9
| Form code: MED 201.NOR | Revision: 2021-03 | www.dnv.com | Page 3 of 6 |
| Job Id: | 344.1-000153-102 |
| Certificate No: | MEDB000036A |
| Revision No: | 3 |
| Pre-insulated | Top, | S1553578 Rev. A |
| RS PPS | 225 - 400 | 151 - 315 | 400 | 4-7 |
| thermoplastic | symmetric | No. 9 |
| RS PPS | 125 | 75 - 96 | 156 | 7 |
| plastic bundle | symmetric | No. 10 |
| Pre-insulated | S1553578 Rev. A |
| RS PPS | 125 | 75 | 156 | 7 | Any |
| plastic bundle | No. 11 |
S1553578 Rev. A
RS PPS 31 - 68 PE/ALU/PE 16 - 32 156 4-7 Symmetric
No. 12
S1553578 Rev. A
RS PPS 31 - 150 PE/ALU/PE 16 - 110 156 4-7 Top
No. 13
S1573859 Rev. A
No. 4+5
S1573859 Rev. A
No. 6
Top, S1573859 Rev. A
symmetric No. 7
PE/ALU/PE w/
RS PPS/S 31 - 125 thermal 16 - 75 35 - 65 4-7
symmetric No. 8
insulation
symmetric No. 9
Pre-insulated Top, S1573859 Rev. A
plastic bundle symmetric No. 10
thermoplastic symmetric No. 11
See insulation drawing specified in the Type Examination Documentation. Deck or bulkhead to be insulated with
approved A-60 insulation covering the edge of the steel frame.
The plastic pipe penetrations are not approved for use in watertight bulkheads on passenger ships and special purpose
ships (SPS).
The penetration system shall not be used for penetrating boundaries of tanks.
Test Report No. P701755 dated 12 June 2007 from SP, Borås, Sweden.
Test Report No. 10608 dated 22 November 2007 from Roxtec, Karlskrona, Sweden.
Test Report No. P902394 dated 25 May 2009 from SP, Borås, Sweden.
Test Report No. PGA10025 dated 22 December 2011 from DBI, Hvidovre, Denmark.
Test Report No. PGA10141 dated 10 July 2012 from DBI, Hvidovre, Denmark.
Test Report No. 6P10024 dated 7 March 2017 from SP, Borås, Sweden.
Test Report No. RS-18/B-023/E dated 29 January 2018 from CTO, Gdansk, Poland.
Test Report No. 8P04040 dated 13 August 2018 from SP, Borås, Sweden.
Test Report No. RS-18/B-291/E dated 20 August 2018 from CTO, Gdansk, Poland.
Test Report No. RS-18/B-292/E dated 13 September 2018 from CTO, Gdansk, Poland.
Test Report No. RS-18/B-293/E dated 13 September 2018 from CTO, Gdansk, Poland.
Test Report No. RS-18/B-484/E dated 10 December 2018 from CTO, Gdansk, Poland.
Test Report No. PGA11302A dated 16 January 2019 from DBI, Hvidovre, Denmark.
Test Report No. RS-19/B-256/E dated 20 September 2019 from CTO, Gdansk, Poland.
Test Report No. RS-19/B-356/E dated 10 October 2019 from CTO, Gdansk, Poland.
Test Report No. RS-19/B-424/E dated 27 November 2019 from CTO, Gdansk, Poland.
Test Report No. 8P07094 dated 16 January 2020 from SP, Borås, Sweden.
Test Report No. RS-20/B-083/E dated 20 April 2020 from CTO, Gdansk, Poland.
Test Report No. PGB10030A dated 26 June 2020 from DBI, Hvidovre, Denmark.
Third part inspection report MLM070717 dated 22 November 2007 from DNV Malmö.
Form code: MED 201.NOR Revision: 2021-03 www.dnv.com Page 4 of 6
Revision No: 3
Assessment No. 103201.89 dated 4 August 2004 from SINTEF, Trondheim, Norway.
Drawing No. S1553577 Rev. A dated 19 October 2020 from maker.
Drawing No. S1553578 Rev. A dated 13 March 2020 from maker.
Drawing No. S1573859 Rev. A dated 26 November 2021 from maker.
Drawing No. S1573861 Rev. A dated 24 November 2021 from maker.
2010 FTP Code part 3.
Form code: MED 201.NOR Revision: 2021-03 www.dnv.com Page 5 of 6
Revision No: 3
consisting of a steel sleeve, bolted or welded to a steel section. Sleeve is fitted at both ends with Roxtec RS seals
(standard or EMC versions) and filled with intumescent material.
For RS PPS/S 31-150, the sleeve is only fitted with one RS frame with integrated intumescent material.
RS PPS 31-450:
gastightness for thermoplastic and PE/ALU/PE pipes and pressure of 2.00 bar watertightness and 1.00 bar gastightness
for pre-insulated thermoplastic pipes.
RS PPS/S 31-150:
Approved for penetration in steel bulkheads or decks limited to a pressure of 4.00 bar watertightness and 2.00 bar
for pre-insulated thermoplastic pipe.
The pipe penetrations are not approved for use in watertight bulkheads on passenger ships and special purpose ships
(SPS).
Test Report No. SKM-04-4088 dated 16 June 2004 from DNV Stockholm.
Test Report No. MLM 060511 dated 28 February 2006 from DNV Malmö.
Test Report No. MLM 070656 dated 18 April 2007 from DNV Malmö.
Test Report No. N141ZEM0 dated 15 May 2020 from DNV GL Malmö.
Test Report No. N141ZEM1 dated 15 May 2020 from DNV GL Malmö.
Test Report No. N141ZEM2 dated 15 May 2020 from DNV GL Malmö.
Test Report No. N142299W, Rev.01 dated 9 November 2020 from DNV GL Malmö.
Pressure tests with water and Helium according to DNV Type Approval Programme 8.471.19-1 and class programme
DNVGL-CP-0165 Chapter 4, October 2017.
Form code: MED 201.NOR Revision: 2021-03 www.dnv.com Page 6 of 6
