| EC-TYPE EXAMINATION | MEDB0000452 |
| Revision No: | |
| CERTIFICATE (MODULE B) | 2 |
Roxtec sealing system with multidiameter technology: S-series (steel)
Regulation (EU) 2022/1157,
IMO MSC.1/1488
This Certificate is valid until 2028-08-08.
Issued at Høvik on 2023-08-09
| DNV local unit: | Digitally Signed By: Øyvind Hoff |
| Denmark CMC | Location: DNV Høvik, Norway |
| on behalf of |
| Marcin Tobiasz | Notified Body | Sverre Olav Bergli |
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 1 of 3 |
| Job Id: | 344.1-000153-120 | ||
| Certificate No: | MEDB0000452 | ||
| Revision No: | 2 |
“Roxtec sealing system with multidiameter technology: S-series (steel)”
consists of Roxtec S-series frames with a depth of 60 mm (S, SF, SFHM, SO, SFO, SFOH, SR/T, SR/S, SRC r20, SRC
r40, SRC r60) in size 2-6 and width 60-120, and combinations thereof up to x4, welded or bolted to the steel sections, to
be used together with SE PPS extension frame. The extension frame is equipped with intumescent material strips.
The S-series is filled with Roxtec halogen free RM modules (Standard RM, RM Ex). Assembled with Roxtec Wedge and
corresponding stayplates.
Approved for use as single or multiple pipe penetration system in class A-0, A-15, A-30 and A-60 steel bulkheads and
decks. Other applications are subject to case-by-case approval.
Approved for use in class A-0, A-15 and A-30 when the penetration system is insulated as A-60 and in addition the
division is to be insulated with A-60 insulation at least 200 mm around the penetration.
Table 1 Approved pipe penetration in A-60 steel bulkhead
| Frame type | Size | Pipe type | Pipe | Frame | Frame | Frame | Frame insulation |
| diameter | length | thickness | position | ||||
| (OD) [mm] | [mm] | [mm] | |||||
| S-series frames 1) | 2-6 | PP, PE, | 16 - 50 | 60 | 10 | Symmetric | Partially insulated |
| PB, ABS | S1590856 No. 1 |
together with SE PPS extension frame with RM modules
Table 2 Approved pipe penetration in A-60 steel deck
| S-series frames 1) | 2 – 6x4 | PP, PE, | 16 - 50 | 60 | 10 | Symmetric, | Partially insulated |
| PB, ABS | unexposed | S1590856; No. 2 |
Test report No. PGB10111A dated 20 September 2021 from DBI, Hvidovre, Denmark.
Test report No. PGB10112A dated 20 September 2021 from DBI, Hvidovre, Denmark.
Test report No. PGB10113A dated 23 July 2021 from DBI, Hvidovre, Denmark.
Drawing No. S1590856 Rev.A dated 11 April 2023 from manufacturer.
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 2 of 3 |
| Revision No: | 2 |
Approved for penetration of plastic pipes in steel bulkheads limited to a pressure of 4 bar watertightness and 2.67 bar
For bolted versions with gasket and self tapping screws, the pressure is limited to 3.3 bar watertightness and 1.7 bar
Test report No. MLM 020401 dated 25 March 2002 from DNV Malmö (screws).
Test report No. SKM-04-4088 dated 16 June 2004 from DNV Stockholm.
Pressure tests with water and Helium according to Class Programme DNV-CP-0165.
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 3 of 3 |
