MEDB0000453-revision1-optimized
MEDB0000453
Roxtec sealing system with multidiameter technology: S-series (aluminium)
Regulation (EU) 2022/1157,
IMO MSC.1/1488
This Certificate is valid until 2028-08-08.
Issued at Høvik on 2023-08-09
Digitally Signed By: Øyvind Hoff
Denmark CMC Location: DNV Høvik, Norway
on behalf of
Marcin Tobiasz Notified Body Sverre Olav Bergli
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 1 of 3
Job Id: 344.1-000153-121
Certificate No: MEDB0000453
Revision No: 1
“Roxtec sealing system with multidiameter technology: S-series (aluminium)”
consists of Roxtec S-series frames with a depth of 60 mm (S, SF, SFHM, SO, SFO, SFOH, SR/T, SR/S, SRC r20, SRC
r40, SRC r60) in size 2-6 and width 60-120, and combinations thereof up to x4, welded or bolted to the aluminum
sections, to be used together with SE PPS extension frame. The extension frame is equipped with intumescent material
strips.
The S-series is filled with Roxtec halogen free RM modules (Standard RM, RM Ex). Assembled with Roxtec Wedge and
corresponding stayplates.
Approved for use as single or multiple pipe penetration system in class A-0, A-15, A-30 and A-60 aluminium bulkheads
and decks. Other applications are subject to case-by-case approval.
Approved for use in class A-0, A-15 and A-30 when the penetration system is insulated as A-60 and in addition the
division is to be insulated with A-60 insulation at least 200 mm around the penetration.
Table 1 Approved pipe penetration in A-60 aluminium bulkhead
Frame type Size Pipe type Pipe Frame Frame Frame Frame insulation
diameter length thickness position
S-series frames 1) 2-6 PP, PE, 16 - 50 60 10 Symmetric Partially insulated from both
PB, ABS sides, S1590905 No. 1
together with SE PPS extension frame with RM modules
Table 2 Approved pipe penetration in A-60 aluminium deck
S-series frames 1) 2-6 PP, PE, 16 - 50 60 10 Symmetric, Partially insulated
PB, ABS unexposed S1590905; No. 2
Test report No. PGB10077A dated 10 December 2020 from DBI, Hvidovre, Denmark.
Test report No. RS-21/B-189/E dated 4 June 2021 from CTO, Gdansk Poland.
Test report No. RS-21/B-446/E dated 7 October 2021 from CTO, Gdansk Poland.
Drawing No. S1590905 Rev. A dated 14 April 2023 from manufacturer.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 2 of 3
Revision No: 1
“Roxtec sealing system with multidiameter technology: S-series (aluminum)”
strips.
Approved for plastic pipe penetration in aluminium bulkheads or decks limited to a pressure of 4 bar watertightness and
2.67 bar gastightness.
For bolted versions with gasket and self tapping screws, the pressure is limited to 3.3 bar watertightness and 1.7 bar
Test report No. MLM 020401 dated 25 March 2002 from DNV Malmö (screws).
Test report No. SKM-04-4088 dated 16 June 2004 from DNV Stockholm.
Pressure tests with water and Helium according to Class Programme DNV-CP-0165.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 3 of 3
