| EC-TYPE EXAMINATION | MEDB000065Z |
| Revision No: | |
| CERTIFICATE (MODULE B) | 2 |
Roxtec sealing system with multidiameter technology: GH-, RS- and R-series (sandwich panel)
Regulation (EU) 2022/1157,
This Certificate is valid until 2024-12-02.
Issued at Høvik on 2023-04-11
Denmark CMC
Øyvind Hoff
| Marcin Tobiasz | Notified Body | on behalf of |
| No.: 0575 | ||
| Sverre Olav Bergli | ||
| Head of Notified Body |
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 1 of 2 |
| Job Id: | 344.1-004468-6 | ||
| Certificate No: | MEDB000065Z | ||
| Revision No: | 2 |
“Roxtec sealing system with multidiameter technology: GH-, RS- and R-series (sandwich panel)”
Roxtec sealing system with multidiameter technology: the GH-series is filled with Roxtec halogen free RM modules (RM,
RM Ex, RM FOC, RM ES, RM ES B, RM PE, RM PE B, RM BG, RM BG B, RM ES Ex, RM ES B Ex, RM PE Ex, RM ES
B Ex , RM BG Ex, RM BG B Ex), assembled with Roxtec Wedge, Roxtec ES Wedge, Roxtec Ex Wedge or Roxtec ES
Ex Wedge and corresponding stayplates. The GH-series is bolted to the sandwich panel.
Roxtec sealing system with multidiameter technology: the R-Series sealing system consist of a rubber frame filled with
Roxtec halogen free RM modules (RM, RM Ex, RM ES, RM ES B, RM PE, RM PE B, RM BG, RM BG B, RM ES Ex, RM
ES B Ex, RM PE Ex, RM ES B Ex , RM BG Ex, RM BG B Ex.). The R-seal is installed into a steel sleeve that is bolted to
the sandwich panel.
Roxtec sealing system with multidiameter technology: the RS cable penetration seal consist of two halves with
removable layers making it adaptable to a single cable of different diameters. It is available in different versions, RS, RS
OMD, RS EMC or RS EX, depending on application. The RS-seal is installed into a steel sleeve that is bolted to the
sandwich panel.
For further details see approved drawings listed below.
The penetrations are approved for use as a cable penetration system for approved ship cables in non-loadbearing
A-60/A-30 bulkheads made of sandwich panels type C.I.S-100 (A-60) manufactured by Norac AS with a thickness of
100 mm and a density of 150 kg/m3 or type G21 Fire Panel (A-60) manufactured by Interdam with a thickness of 100
mm and a density of 120 kg/m3 or equivalent constructed sandwich panels with A-60 rating.
Table 1: Approved cable penetration in A-60 bulkheads of sandwich constructions.
| Max. cable Sleeve | Sleeve |
| Sealing | Size |
| diameter | length |
| system | [mm] |
| [mm] | [mm] |
| G | 2x1 to 8+8x3 |
| G | 2x1 to 8+8x5 |
| RS | 31 to 125 |
| R | 50 - 200 |
Table 2: Approved cable penetration in A-30 bulkheads of sandwich constructions.
| Sealing | Size |
| diameter | length |
| system | [mm] |
| [mm] | [mm] |
| G | 2x1 to 8+8x3 |
Test report No. 3P07871 rev. 1 dated 11 October 2014 from SP Technical Research Institute of Sweden.
Test report No. 293615 Issue 1 dated 14 October 2014 from BRE, Watford, United Kingdom.
Test report No. RS-22/B-246/E dated 12 August 2022 from CTO, Gdańsk, Poland.
Drawing No. S1582715, rev. A: Insulation of GH frames dated 2022-08-25 from Roxtec
Drawing No. S1582819, rev. A: Insulation of R frames dated 2022-08-29 from Roxtec
Drawing No. S1582863, rev. A: Insulation of RS seal dated 2022-08-30 from Roxtec
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 2 of 2 |
