MEDB000069T-Rev-2-optimized
MEDB000069T
2
Application of: Directive 2014/90/EU of 23 July 2014 on marine equipment (MED). This Certificate is issued by
DNV GL SE based on the notification of the Federal Maritime and Hydrographic Agency of Germany.
Roxtec GK Firestop Sealing Kit, GK FS SK KIT ROUND 89 - 273 and
GK FS SK KIT OVAL 200x150 - 250x170, 350x170, 450x170, 550x170 or 2x(250x170)
Regulation (EU) 2022/1157,
This Certificate is valid until 2028-07-16.
Issued at Hamburg on 2023-07-17
for DNV GL SE
Sweden CMC Digitally Signed By: Mydlak-Röder, Christine
Carsten Hunsalz Notified Body Christine Mydlak-Roeder
No.: 0098 Head of Notified Body
certificate (module D, E or F), as allowed by the “Agreement between the European Community and the United States of America on Mutual Recognition of
Certificates of Conformity for Marine Equipment”, signed February 27th, 2004, and amended by Decision No 1/2018 dated February 18th, 2019.
The mark of conformity may only be affixed to the above type approved equipment and a Manufacturer’s Declaration of Conformity issued when the production-
surveillance module (D, E or F) of Annex B of the MED is fully complied with and controlled by a written inspection agreement with a Notified Body. The product liability
rests with the manufacturer or his representative in accordance with Directive 2014/90/EU.
This certificate is valid for equipment, which is conform to the approved type. The manufacturer shall inform DNV GL SE of any changes to the approved equipment.
This certificate remains valid unless suspended, withdrawn, recalled or cancelled.
Should the specified regulations or standards be amended during the validity of this certificate, the product is to be re-approved before being placed on board a vessel
to which the amended regulations or standards apply.
Form code: MED 201.DEU Revision: 2023-02 www.dnv.com Page 1 of 4
Job Id: 344.1-010192-4
Certificate No: MEDB000069T
Revision No: 2
“GK FS SK sealing kit“ consisting of a fiberglass cloth with built in heat activated intumescent material to be wrapped
around cable bundles and fitted into circular or oval steel pipe sleeves. Folded back on each side with ends sealed off to
create a cold smoke tight seal and secured by metal cable ties.
“GK FS SK sealing kit“ is intended to be used for bundled cables or as a blank fire stop solution. The installation shall
be made in symmetrically welded or bolted pipe sleeves.
GK FS SK KIT ROUND A-60:
The coaming is welded or bolted symmetrically of the deck/bulkhead.
Installation details according drawings Roxtec No. S1571487 Rev. B, S1571524 Rev. B
Application Sleeve Sleeve Tested Tested maximum Tested cable
Size Ø (mm) Length (mm) minimum filling rate (%) maximum
filling rate diameter (mm)
Bulkhead 84 - 273 100 - 205 0 68 47
Deck 84 - 273 100 - 205 0 68 47
GK FS SK KIT OVAL A-60:
Application Sleeve Size (mm) Sleeve Tested Tested Tested cable
(Ø x L) Length minimum maximum maximum
(mm) filling rate filling rate diameter (mm)
Bulkhead 200x150 - 250x170 or 100 - 205 0 68 47
2x(250x170)
Deck 200x150 - 250x170 or 100 - 205 0 68 47
2x(250x170)
Bulkhead 350x170, 450x170, 550x170 100 - 205 0 68 90
Deck 350x170, 450x170, 550x170 100 - 205 0 68 90
GK FS SK KIT ROUND A-0:
Installation details according drawings Roxtec No. S1571522 Rev. B, S1571523 Rev. A
Application Sleeve Size Sleeve Tested Tested maximum Tested cable
(mm) (Ø x L) Length (mm) minimum filling rate (%) maximum
Deck 84 - 273 100 - 205 0 68 50
| Form code: MED 201.DEU | Revision: 2023-02 | www.dnv.com | Page 2 of 4 |
| Job Id: | 344.1-010192-4 |
| Certificate No: | MEDB000069T |
| Revision No: | 2 |
GK FS SK KIT OVAL A-0:
2x(250x170)
Deck 200x150 - 250x170 or 100 - 205 0 68 50
2x(250x170)
*Definition filling ratio:
Cable filing ratio = (The sum cross section of the cables) / (the inside cross section area of Coaming, including the cloth)
*Cross sectional of the cable=R2 x3.14
*R=Radius of Cable and the Seal.
Water- / Gas- tightness: Not applicable
Approved for use as a blank, single or multiple cables penetration system (combined in one or more cable bundles) in
class A-60 and A-0 steel bulkheads and decks. Other applications are subject to case-by-case approval. Approved for
use in class A-15 and A-30 when the penetration system is insulated as A-60. In addition the division is to be insulated
with A-60 insulation at least 200 mm around the penetration.
Conformity. Each product is to be supplied with its actual manual for installation and use.
Maximum filling ratio of 68%.
In general approved maximum cable diameter: 50 mm / 90 mm (refer to tables under Product description).
The bolted sleeves shall be installed with screws + spring washer.
Sleeves with lengths L=100 to 205mm with or without intumescent strips can be used.
The systems must not be installed in bulkheads and decks if water- and gas- tightness is required.
Each product is to be supplied with its manual for installation, use and maintenance.
Test Reports A60 Fire Class:
RS-19/B-255/E, dated 2019-08-20; RS-19/B-225/E, dated 2019-08-01; RS-19/B-256/E,
dated 2019-08-20; RS-19/B-355/E, dated 2019-10-16; DMT-DO-53-112, dated 2019-05-22;
RS-21/B-242/E, dated 2021-06-30; PGB10113A, dated 2021-07-23;
PGB10176A, dated 2022-11-04; PGB10172A, dated 2022-06-17
Test Reports A0 Fire Class:
PGA11387A, dated 2019-07-05; RS-19/B-423/E, dated 2019-11-19; RS-20/B-081/E, dated 2020-03-31; 8P07092, dated
2019-09-27; 8P07094, dated 2019-09-23; PGA11610A, dated 2020-01-10;
RS-21/B-240/E, dated 2021-06-30; PGB10119A, dated 2021-11-15;
PGB10174A, dated 2022-07-13; PGB10178A, dated 2022-11-04
Test Reports Cold Smoke:
Roxtec No. 29092016-01, dated 2016-09-29; No. 22032017-01, dated 2017-03-22; No. 14122016-01, dated 2016-12-14
Form code: MED 201.DEU Revision: 2023-02 www.dnv.com Page 3 of 4
Revision No: 2
Installation Drawings:
Roxtec No. S1571487 Rev. B dated 2023-05-23, S1571524 Rev. B dated 2023-06-05, S1571522 Rev. B
dated 2023-05-23, S1571523 Rev. A dated 2022-03-22
General Arrangement Drawings:
Roxtec No. S1543766 Rev. B dated 2019-10-23, S1543765 Rev. B dated 2019-10-22, S1535797 Rev. C
dated 2019-10-22, S1558305 Rev. B dated 2021-05-19
Sleeve Drawings:
Roxtec No. S1535700 Rev. D dated 2021-12-06, S1550433 Rev. A dated 2019-12-17, S1577598 Rev. A
dated 2022-03-31
- IMO Res. MSC.307(88)-(2010 FTP Code), Annex 1: Part 3,
- MSC.1/Circ. 1488
For identification to this type examination certificate the product or packing is to be marked with:
- Manufacturer’s name
- Type designation and fire-technical rating
  • Mark of Conformity according to Article 10 of the Council Directive (MED):
END OF CERTIFICATE
Form code: MED 201.DEU Revision: 2023-02 www.dnv.com Page 4 of 4
