MEDB00006BG-revision1-optimized
EC-TYPE EXAMINATION MEDB00006BG
CERTIFICATE (MODULE B) 1
Roxtec sealing system with multidiameter technology: R-series (steel)
Regulation (EU) 2023/1667,
IMO MSC.1/1488
This Certificate is valid until 2029-05-07.
Issued at Høvik on 2024-05-08
Tessa Biever
Helge Bjørnarå Notified Body on behalf of
No.: 0575
Mydlak-Röder, Christine
Head of Notified Body
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 1 of 7
Job Id: 344.1-010272-2
Certificate No: MEDB00006BG
Revision No: 1
“Roxtec sealing system with multidiameter technology: R-series (steel)”,
consists of a rubber frame (R) that are filled with Roxtec RM modules of different sizes depending on the
number/Diameter of the pipes. It is available in standard, Ex and EMC versions depending on application.
The R-frame is installed into a steel sleeve (SL) that is welded, bolted, or attached by expansion (SLFR X) onto the steel
division.
Approved for use as empty, single, or multiple pipe penetration system in A-class steel divisions. Other applications are
subject to case-by case approval.
For A-15 and A-30 applications, the penetration shall be insulated as for A-60 and the division is to be fitted with A-60
insulation for a minimum distance of 200 mm around the penetration.
Table 1: Approved pipe penetration in A-60 steel bulkhead.
Frame Pipe Sleeve
Size diameters length
Type material Type
Steel Fully insulated1) on one side
R 50 – 200 6 – 30
Titanium (S1588636, 8)
Steel, Insulated Fully insulated1) on one side
R 50 – 200 6 – 54
Titanium side (S1588636, 9)
Fully insulated1) + 500 mm
Steel,
R 50 – 200 6 – 54 SLR-series2) 55 5.75 – 7 Symmetric along pipe on one side.
Titanium
(S1588636, 10)
Fully insulated1) + 600 mm
Copper,
R 50 6 – 10 SLR-series2) 55 6 Symmetric along pipe on one side.
CuNi
(S1588636, 11)
Copper,
CuNi
(S1588636, 12)
Bundle Fully insulated1) + 500 mm
R 50 – 200 pipe 8 – 50 SLR-series2) 55 5.75 – 7 Symmetric
(steel) (S1588636, 13)
Partially insulated on one
R 50 – 200 Empty NA SLR-series2) 55 5.75 – 7 Symmetric
(S1588636, 14)
Fully insulated* on both
Steel,
R 50 – 200 6 – 30 SL-series3) Up to 400 5.75 – 7 Any sides.
Titanium
(S1588787, 7)
Fully insulated1) on both
Steel, sides and 500 mm along
R 50 – 200 6 – 54 SL-series3) Up to 400 5.75 – 7 Any
Titanium pipe on one side.
(S1588787, 8)
Copper, sides and 600 mm along
R 50 6 – 10 SL-series3) Up to 400 6 Any
CuNi pipe on one side.
(S1588787, 9)
(S1588787, 10)
Bundle
R 50 – 200 pipe 8 – 50 SL-series3) Up to 400 5.75 – 7 Any
pipe on one side.
(steel)
(S1588787, 11)
Fully insulated on both
Steel,
R 70 – 200 6 – 53 SLFR X 55 5.75 – 7 Either sides.
Titanium
(S1588663, 3)
1) No insulation between pipes.
  1. SLR-series includes the following types: SLR, SLR Ex or sleeves with equal dimensions specified in drawing S1587721.
3) SL-series are longer versions of sleeves in SLR-series.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 2 of 7
Revision No: 1
Table 2: Approved pipe penetration in A-60 steel deck.
Frame Pipe Sleeve
type material type
Fully insulated1) on the
Steel, Top side,
R 50 – 200 6 – 50
Titanium symmetric
(S1588636, 1)
Fully insulated1) + 350 mm
Steel,
R 50 – 200 6 – 54 SLR-series2) 55 5.75 – 7 Any along pipe on the underside.
Titanium
(S1588636, 2)
Fully insulated1) + 400 mm
Steel, Top side,
R 50 – 200 6 – 95 SLR-series2) 55 5.75 – 7 along pipe on the underside.
Titanium symmetric
(S1588636, 3)
Fully insulated1) + 450 mm
Copper,
R 50 – 200 6 – 28 SLR-series2) 55 5.75 – 7 Any along pipe on the underside.
CuNi
(S1588636, 4)
Fully insulated1) + 800 mm
Copper,
CuNi
(S1588636, 5)
Bundle Fully insulated1) + 350 mm
R 50 – 200 pipe 8 – 50 SLR-series2) 55 5.75 – 7 Any
(steel) (S1588636, 6)
Partially insulated on the
Top side,
R 50 – 200 Empty NA SLR-series2) 55 5.75 – 7 underside.
symmetric
(S1588636, 7)
Steel,
R 50 – 200 6 – 50 SL-series3) Up to 400 5.75 – 7 Any underside.
Titanium
(S1588787, 1)
Steel,
R 50 – 200 6 – 54 SL-series3) Up to 400 5.75 – 7 Any along pipe on the underside.
Titanium
(S1588787, 2)
Steel,
R 50 – 200 6 – 95 SL-series3) Up to 400 5.75 – 7 Any along pipe on the underside.
Titanium
(S1588787, 3)
Copper,
R 50 – 200 6 – 28 SL-series3) Up to 400 5.75 – 7 Any along pipe on the underside.
CuNi
(S1588787, 4)
Copper,
CuNi
(S1588787, 5)
(steel) (S1588787, 6)
Fully insulated on the
Steel,
R 70 – 200 6 – 54 SLFR X 55 5.75 – 7 Either underside.
Titanium
(S1588663, 1)
Fully insulated + 350 mm
Steel,
R 70 – 200 6 – 54 SLFR X 55 5.75 – 7 Either along pipe on the underside.
Titanium
(S1588663, 2)
  1. SLR-series includes the following types: SLR, SLR Ex, SLFR, SLFR Ex, SLFO/RI or sleeves with equal dimensions specified in
drawing S1587721.
Table 3: Approved pipe penetration in A-0 steel bulkhead.
Frame Pipe Sleeve
type material type
None.
R 50 – 100 Steel
(S1588654, 9)
Steel, Fully insulated1) on one side
R 50 – 200 6 – 30
Titanium (S1588654, 10)
R 50 – 200 6 – 54
Titanium side (S1588654, 11)
Steel,
Titanium
(S1588654, 12)
Copper,
CuNi
(S1588654, 13)
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 3 of 7
Revision No: 1
Copper,
CuNi
(S1588654, 14)
(steel) (S1588654, 15)
(S1588654, 16)
Steel,
Titanium
(S1588796, 7)
(S1588796, 8)
(S1588796, 9)
(S1588796, 10)
Bundle
pipe on one side.
(steel)
(S1588796, 11)
Steel, Fully insulated on both sides
R 70 – 200
Titanium (S1588655, 3)
  1. No insulation between pipes.
  2. SLR-series includes the following types: SLR, SLR Ex or sleeves with equal dimensions specified in drawing S1587721.
Table 4: Approved pipe penetration in A-0 steel deck.
Frame Pipe Sleeve
type material type
None.
R 50 – 200 Steel
(S1588654, 1)
Steel, Top side,
R 50 – 200 6 – 50
Titanium symmetric
(S1588654, 2)
Steel,
R 50 – 200 6 – 54 SLR-series3) 55 5.75 – 7 Any along pipe on the underside.
Titanium
(S1588654, 3)
Steel, Top side,
R 50 – 200 6 – 95 SLR-series3) 55 5.75 – 7 along pipe on the underside.
Titanium symmetric
(S1588654, 4)
Copper,
R 50 – 200 6 – 28 SLR-series3) 55 5.75 – 7 Any along pipe on the underside.
CuNi
(S1588654, 5)
Copper,
CuNi
(S1588654, 6)
R 50 – 200 pipe 8 – 50 SLR-series3) 55 5.75 – 7 Any
(steel) (S1588654, 7)
Top side,
R 50 – 200 Empty NA SLR-series3) 55 5.75 – 7 underside.
symmetric
(S1588654, 8)
Steel,
R 50 – 200 6 – 50 SL-series4) Up to 400 5.75 – 7 Any underside.
Titanium
(S1588796, 1)
Steel,
R 50 – 200 6 – 54 SL-series4) Up to 400 5.75 – 7 Any along pipe on the underside.
Titanium
(S1588796, 2)
Steel,
R 50 – 200 6 – 95 SL-series4) Up to 400 5.75 – 7 Any along pipe on the underside.
Titanium
(S1588796, 3)
Copper, Fully insulated1) + 450 mm
R 50 – 200 6 – 28 SL-series4) Up to 400 5.75 – 7 Any
CuNi along pipe on the underside.
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 4 of 7 |
| Job Id: | 344.1-010272-2 |
| Certificate No: | MEDB00006BG |
| Revision No: | 1 |
(S1588796, 4)
Copper,
CuNi
(S1588796, 5)
R 50 – 200 pipe 8 – 50 SL-series4) Up to 400 5.75 – 7 Any
(steel) (S1588796, 6)
Steel,
Titanium
(S1588655, 1)
Steel,
Titanium
(S1588655, 2)
2) SLR-series includes the following types: SLR, SLR Ex.
drawing S1587721.
4) SL-series are longer versions of sleeves in SLR-series.
Please note Installation instruction for Roxtec RX attached through expansion: Aperture irregularities are acceptable
within min and max diameters. (Max Ø = Min Ø + 2mm).
Test report No. 4P8662 dated 8 June 2015 from SP, Borås, Sweden.
Test report No. PGA10724A dated 5 February 2016 from DBI, Hvidovre, Denmark.
Test report No. PGA10799A dated 25 May 2016 from DBI, Hvidovre, Denmark.
Test report No. PGA10800A dated 26 May 2016 from DBI, Hvidovre, Denmark.
Test report No. 6P10022 dated 7 March 2017 from SP, Borås, Sweden.
Test report No. 8P04039 dated 6 August 2018 from SP, Borås, Sweden.
Test report No. 8P04040 dated 13 August 2018 from SP, Borås, Sweden.
Test report No. RS-18/B-291/E dated 20 August 2018 from CTO, Gdansk, Poland.
Test report No. RS-18/B-292/E dated 13 September 2018 from CTO, Gdansk, Poland.
Test report No. PGA11301A dated 22 November 2018 from DBI, Hvidovre, Denmark.
Test report No. PGA11302A dated 16 January 2019 from DBI, Hvidovre, Denmark.
Test report No. RS-19/B-225/E dated 8 August 2019 from CTO, Gdansk, Poland.
Test report No. PGB10046A dated 16 November 2020 from DBI, Hvidovre, Denmark.
Test report No. PGB10118A dated 15 November 2021 from DBI, Hvidovre, Denmark.
Test report No. RS-22/B-153/E dated 4 May 2022 from CTO, Gdansk, Poland.
Test report No. PGB10174A dated 13 July 2022 from DBI, Hvidovre, Denmark.
Test report No. RS-22/B-336/E dated 28 October 2022 from CTO, Gdansk, Poland.
Test report No. RS-22/B-337/E dated 28 October 2022 from CTO, Gdansk, Poland.
Test report No. RS-22/B-338/E dated 28 October 2022 from CTO, Gdansk, Poland.
Test report No. PGB10176A dated 4 November 2022 from DBI, Hvidovre, Denmark.
Test report No. RS-22/B-395/E dated 28 November 2022 from CTO, Gdansk, Poland.
Test report No. RS-23/B-340/E dated 3 November 2023 from CTO, Gdansk, Poland.
Test report No. 9P02428 dated 13 September 2019 from manufacturer.
Drawing No. S1588636 Rev. B dated 15 November 2023 from manufacturer.
Drawing No. S1588654 Rev. B dated 15 November 2023 from manufacturer.
Drawing No. S1588655 Rev. B dated 11 December 2023 from manufacturer.
Drawing No. S1588663 Rev. C dated 17 January 2024 rom manufacturer.
Drawing No. S1588787 Rev. B dated 15 November 2023 from manufacturer.
Drawing No. S1588796 Rev. B dated 17 November 2023 from manufacturer.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 5 of 7
Revision No: 1
2010 FTP Code part 3.
MED Mark of Conformity and/or USCG approval number if applicable (see page 1).
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 6 of 7
Revision No: 1
division.
Approved for penetration in steel bulkheads or decks limited to a pressure of 4.0 bar watertightness and 2.0 bar
gastightness for steel pipes.
For bolted versions with gasket, the pressure is limited to 2.5 bar watertightness and 1.0 bar gastightness.
For expansion version (SLFR X), the pressure is limited to 4.0 bar watertightness and 2.0 bar gastightness.
For longer version sleeves, the pressure is limited to 1.33 bar watertightness and 0.67 bar gastightness.
Test report No. MLM 010247 dated 28 September 2001 from DNV Malmö.
Test report No. N1429Y4V dated 21 March 2022 from DNV Sweden CMC.
Test report No. N142G50V dated 20 June 2022 from DNV Sweden CMC.
Test report No. N142JK51 dated 27 February 2023 from DNV Sweden CMC.
Pressure tests with water and helium according to DNV-CP-0165.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 7 of 7
