MEDB00006GS-optimized
MEDB00006GS
Application of: Directive 2014/90/EU of 23 July 2014 on marine equipment (MED), issued as “Forskrift
om Skipsutstyr” by the Norwegian Maritime Authority. This Certificate is issued by DNV GL AS under the
authority of the Government of Norway.
Roxtec sealing system with multidiameter technology: RS-series (Al)
Regulation (EU) 2020/1170,
item No. MED/3.26b. SOLAS 74 as amended, Regulation II-2/9, IMO MSC.1/Circ.1276, IMO
2010 FTP Code and IMO MSC.1/1488
This Certificate is valid until 2025-12-20.
Issued at Høvik on 2020-12-21
for DNV GL AS
DNV GL local station: Digitally Signed By: Schei-Nilsson, Mårten
Gothenburg FIS Location: DNV GL Høvik, Norway
, on behalf of
Roald Vårheim
Helge Bjørnarå Notified Body
A U.S. Coast Guard approval number will be assigned to the equipment when the production module has been completed and will appear on the
production module certificate (module D, E or F), as allowed by the “Agreement between the United States of America and the EEA EFTA states
on the mutual recognition of Certificates of Conformity for Marine Equipment” signed 17 October 2005, and amended by Decision No 1/2019
dated February 22nd, 2019.
The mark of conformity may only be affixed to the above type approved equipment and a Manufacturer’s Declaration of Conformity
issued when the production-surveillance module (D, E or F) of Annex B of the MED is fully complied with and controlled by a written
inspection agreement with a Notified Body. The product liability rests with the manufacturer or his representative in accordance with
Directive 2014/90/EU.
This certificate is valid for equipment, which is conform to the approved type. The manufacturer shall inform DNV GL AS of any
changes to the approved equipment. This certificate remains valid unless suspended, withdrawn, recalled or cancelled.
Should the specified regulations or standards be amended during the validity of this certificate, the product is to be re-approved
before being placed on board a vessel to which the amended regulations or standards apply.
LEGAL DISCLAIMER: Unless otherwise stated in the applicable contract with the holder of this document, or following from mandatory law, the
liability of DNV GL AS, its parent companies and subsidiaries as well as their officers, directors and employees (“DNV GL”) arising from or in
connection with the services rendered for the purpose of the issuance of this document or reliance thereon, whether in contract or in tort
(including negligence), shall be limited to direct losses and under any circumstance be limited to 300,000 USD.
Form code: MED 201.NOR Revision: 2020-01 www.dnvgl.com Page 1 of 4
© DNV GL 2014. DNV GL and the Horizon Graphic are trademarks of DNV GL AS.
Job Id: 344.1-000153-91
Certificate No: MEDB00006GS
“Roxtec sealing system with multidiameter technology: RS-series (Al)”,
consisting of an aluminium sleeve, bolted or welded or attached through expansion (RS X) to an
aluminium section. Sleeve is filled with a Roxtec RS or RS OMD seal (standard or EMC) in sizes 23-150.
Approved for use as single and bundle pipe penetration system in class A-0 to A-60 aluminium bulkheads
and decks as follows:
material position insulation
Steel,
RS / RS OMD 23 - 150 6 - 119
Titanium
RS / RS OMD 23 - 150 Copper
Bundle
RS / RS OMD 43 - 100 16 - 50
(Steel)
Bundle
RS / RS OMD 50 18 65 6 Any S1040796 Rev. C
(Copper)
RS / RS OMD 68 - 125 GRP 32 - 90 65 6-7 Any
Copper,
RS X 25 - 125 Steel, 6 - 108 65 4-7 Either
Titanium
Steel,
Titanium
Other applications are subject to case-by-case approval.
Deck or bulkhead to be insulated with approved insulation according to classification covering the edge
of the aluminium frame or fully insulated. See insulation drawings specified in the Type Approval
documentation. For fire class A-0, A-15 and A-30, the sleeve and pipes are to be insulated as for class A-
60.
Penetrations through structural divisions should not impair the structural strength of the division. Special
consideration should be given to bulkheads and decks with high stress locations (IMO MSC.1/Circ.1488).
The insulation materials used have to be approved according to the Marine Equipment Directive and bear
the Mark of Conformity.
Test reports No. P603001 dated 23 January 2007 from SP, Sweden.
Test reports No. PG11898 dated 17 April 2009 from DIFT, Hvidovre, Denmark.
Form code: MED 201.NOR Revision: 2020-01 www.dnvgl.com Page 2 of 4
Test reports No. PG11955 dated 17 April 2009 from DIFT, Hvidovre, Denmark.
Test reports No. RS-17/B-555/E dated 15 January 2018 from CTO, Gdansk, Poland.
Test reports No. RS-18/B-179/E dated 25 June 2018 from CTO, Gdansk, Poland.
Test reports No. PGA11371A dated 20 February 2019 from DBI, Hvidovre, Denmark.
Test reports No. RS-19/B-020/E dated 27 May 2019 from CTO, Gdansk, Poland.
Test reports No. RS-19/B-224/E dated 1 August 2019 from CTO, Gdansk, Poland.
Test reports No. PGB10016A dated 3 June 2020 from DBI, Hvidovre, Denmark.
Test reports No. PGB10031A dated 9 July 2020 from DBI, Hvidovre, Denmark.
Assessment report No. 9P02428 dated 13 September 2019 from RISE, Sweden.
Drawing No. S1040796 Rev. C dated 17 February 2015 from maker.
Drawing No. S1040877 Rev. A dated 18 August 2014 from maker.
Drawing No. S1040943 Rev. A dated 12 August 2014 from maker.
Drawing No. S1552313 Rev. A dated 11 February 2020 from maker.
Drawing No. S1552354 Rev. B dated 2 December 2020 from maker.
Tested according to IMO FTP Code Part 3 (IMO Res. A.754(18)) and in compliance with IMO 2010 FTP
Code Ch. 8 and IMO 2010 FTP Code Part 3.
The product or packing is to be marked with name and address of manufacturer, type designation, fire-
technical rating, Mark of Conformity and USCG approval if applicable (see first page).
Form code: MED 201.NOR Revision: 2020-01 www.dnvgl.com Page 3 of 4
consisting of an aluminium sleeve, bolted, welded or attached through expansion (RS X) to an aluminium
Approved for penetration in aluminium bulkheads or decks for steel and copper pipes limited to a
pressure of 4.00 bar watertightness and 2.67 bar gastightness, and GRP/GRE pipes limited to a pressure
of 4.00 bar watertightness and 2.00 bar gastightness.
For bolted versions with gasket and self-tapping screws, the pressure is limited to 3.33 bar
watertightness and 1.67 bar gastightness.
The penetration system shall not to be used for penetrating boundaries of tanks.
When requested to be used in watertight bulkheads on passenger ships and Special Purpose Ships (SPS),
the penetration system has to comply with the requirements given in SOLAS Ch. II-1 Reg. 13.2.3 (2009
issue). Penetrations passing through watertight bulkheads are subject for separate examination and
approval by actual flag administration.
Test report No. MLM 020106 dated 19 December 2001 from DNV Malmö.
Test report No. SKM-04-4088 dated 16 June 2004 from DNV Stockholm.
Test report No. MLM 060561 dated 1 December 2006 from DNV Malmö.
Form code: MED 201.NOR Revision: 2020-01 www.dnvgl.com Page 4 of 4
