MEDB000074M-revision1-optimized
Certificate no.:
EC-TYPE EXAMINATION MEDB000074M
CERTIFICATE (MODULE B) 1
that the Penetrations through “A” class divisions: electric cable transits
Roxtec sealing system with multidiameter technology: H seals series (steel divisions)
issued to
Regulation (EU) 2023/1667,
This Certificate is valid until 2029-01-14.
Issued at Høvik on 2024-01-15
Denmark CMC
Kristin Grønnæss Hovden
Izabela Misztal Notified Body Norway
No.: 0575 on behalf of
Mydlak-Röder, Christine
Head of Notified Body
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 1 of 3
Job ID: 344.1-011101-2
Certificate no.: MEDB000074M
Revision No: 1
“Roxtec sealing system with multidiameter technology: H seals series (steel divisions)”,
is a single or multicable penetration system consisting of a steel sleeve welded to the division and filled with a H seal of
size 31 to 150.
Approved for use as a multicable penetration system in class A-0 and A-60 steel bulkheads or decks for approved ship
cables. Other applications are subject to case-by-case approval.
the penetration.
Table 1: Approved cable penetration in A-60 steel bulkhead
Max. cable Sleeve Sleeve
Cable Sleeve
type position
Fully insulated.
H 31 – 150 Marine
(S1558191, 1 and 2)
Table 2: Approved cable penetration in A-60 steel deck
Cable Sleeve
type position
Fully insulated.
H 31 – 150 Marine
(S1558191, 5 and 6)
Table 3: Approved cable penetration in A-0 steel bulkhead
Cable Sleeve
type position
None.
H 31 Marine
(S1558191, 3)
Fully insulated on the
H 32 – 150 Marine
(S1558191, 4)
Table 4: Approved cable penetration in A-0 steel deck
Cable Sleeve
type position
None.
H 31 – 150 Marine
(S1558191, 7 and 8)
Test report No. RS-19/B-424/E dated 27 November 2019 from CTO, Gdansk, Poland.
Test report No. PGA11610A dated 10 January 2020 from DBI, Hvidovre, Denmark.
Test report No. PGA11611A dated 11 January 2020 from DBI, Hvidovre, Denmark.
Test report No. RS-20/B-081/E dated 31 March 2020 from CTO, Gdansk, Poland.
Test report No. RS-20/B-083/E dated 20 April 2020 from CTO, Gdansk, Poland.
Installation drawing:
Drawing No. S1558191 Rev. A dated 7 December 2020 from manufacturer.
Product drawing:
Drawing No. S1559058 Rev. A dated 23 September 2020 from manufacturer.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 2 of 3
Revision No: 1
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 3 of 3
