| EC-TYPE EXAMINATION | MEDB0000876 |
CERTIFICATE (MODULE B)
Roxtec sealing system: H-series (Aluminium divisions)
Regulation (EU) 2022/1157,
IMO MSC.1/1488
This Certificate is valid until 2028-03-02.
Issued at Høvik on 2023-03-03
Øyvind Hoff
| Kristin Grønnæss Hovden | Notified Body | on behalf of |
| No.: 0575 | ||
| Sverre Olav Bergli | ||
| Head of Notified Body |
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 1 of 3 |
| Job Id: | 344.1-012406-1 | ||
| Certificate No: | MEDB0000876 |
Roxtec sealing system: H-series (Aluminium divisions),
is a single or multiple pipe penetration system consisting of an aluminium sleeve welded to an aluminium division and
filled with a H seal of size 31 to 150.
For more details, see drawing listed under Type Examination documentation below.
Approved for use as single or multiple pipe penetration system in class A-60 aluminium bulkheads or decks according to
tables below. Other applications are subject to case-by-case approval.
the penetration.
Table 1: Approved pipe penetration in A-60 aluminium bulkhead
| Pipe | Sleeve | Sleeve |
| Type | Size | diameter |
| material | position | insulation |
| (OD) [mm] | [mm] | [mm] |
| H | 31 - 150 | Steel |
Table 2: Approved pipe penetration in A-60 aluminium deck
| Symmetric, | ||
| Unexposed |
Test report No. PGB10016A Rev. 2 dated 3 June 2020 from DBI, Hvidovre, Denmark.
Test report No. PGB10031A Rev. 1 dated 9 July 2020 from DBI, Hvidovre, Denmark.
Test report No. PGB10076A Rev. 1 dated 9 December 2020 from DBI, Hvidovre, Denmark.
Drawing No. S1583426 Rev. A dated 4 January 2023 from manufacturer.
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 2 of 3 |
Approved for penetration in aluminium bulkheads or decks limited to a pressure of 4.0 bar watertightness and 2.0 bar
Test report No. N142JK4Y dated 27 February 2023 from DNV, Sweden.
Pressure tested according to Class Programme DNV-CP-0165.
v
| Form code: MED 201.NOR | Revision: 2022-12 | www.dnv.com | Page 3 of 3 |
