MEDB0000877-optimized
EC-TYPE EXAMINATION MEDB0000877
CERTIFICATE (MODULE B)
Roxtec Sealing system: H-series (Aluminium divisions)
Regulation (EU) 2022/1157,
This Certificate is valid until 2028-03-02.
Issued at Høvik on 2023-03-03
Øyvind Hoff
Kristin Grønnæss Hovden Notified Body on behalf of
No.: 0575
Sverre Olav Bergli
Head of Notified Body
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 1 of 3
Job Id: 344.1-012407-1
Certificate No: MEDB0000877
Roxtec Sealing system: H-series (Aluminium divisions),
is a single or multicable penetration system consisting of an aluminium sleeve welded to an aluminium division and filled
with a H seal of size 31 to 150.
For more details, see drawing listed under Type Examination documentation below.
Approved for use as single or multicable penetration system in class A-60 aluminium bulkheads or decks for approved
ship cables according to tables below. Other applications are subject to case-by-case approval.
the penetration.
Table 1: Approved cable penetration in A-60 aluminium bulkhead
Max. cable Sleeve Sleeve
Sleeve Sleeve
position insulation
H 31 - 150 50
Table 2: Approved cable penetration in A-60 aluminium deck
Sleeve Sleeve
position insulation
H 31 - 150 50
4-7
Unexposed
Test report No. RS-20/B-082/E dated 27 April 2020 from CTO, Gdansk, Poland.
Test report No. PGB10016A Rev.2 dated 3 June 2020 from DBI, Hvidovre, Denmark.
Test report No. PGB10076A Rev.1 dated 9 December 2020 from DBI, Hvidovre, Denmark.
Drawing No. S1583408 Rev. A dated 5 January 2023 from manufacturer.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 2 of 3
Approved for penetration in aluminium bulkheads or decks limited to a pressure of 4.00 bar watertightness and 2.67 bar
Test report No. N141XE2A Rev.02 dated 19 December 2020 from DNV GL Malmö, Sweden.
Pressure tested according to Class Programme DNV-CP-0165.
Form code: MED 201.NOR Revision: 2022-12 www.dnv.com Page 3 of 3
